Ansys_CFD-Post_Users_Guide.pdf
Ansys_CFD-Post_Users_Guide 2022R1
This manual contains the following chapters:
• Overview of CFD-Post (p. 31) describes CFD-Post functionality and advanced features.
• Starting CFD-Post (p. 35) describes how to start CFD-Post and the environment variables that affect
how CFD-Post operates.
• CFD-Post Graphical Interface (p. 45) describes the CFD-Post interface.
• CFD-Post in Ansys Workbench (p. 101) describes how to run CFD-Post in Workbench, including workflow, journaling and scripting, tips, and limitations.
• CFD-Post 3D Viewer (p. 117) describes how to use the CFD-Post 3D Viewer.
• CFD-Post Workflow (p. 137) describes common ways to use CFD-Post.
• CFD-Post File Menu (p. 141) describes the functionality available from the File menu and the file types that CFD-Post supports.
• CFD-Post Edit Menu and Options (Preferences) (p. 197) describes the functionality available from the Edit menu, such as customizing CFD-Post by setting your preferences on the Options dialog box.
• CFD-Post Monitor Menu (p. 209) describes how to view solution data while the solver is running.
• CFD-Post Session Menu (p. 211) describes how to record and replay session files. (Session files contain a record of the commands issued during a CFD-Post session.)
• CFD-Post Insert Menu (p. 215) describes how to create new objects (such as locators, tables, charts,
and so on), variables, and expressions by using the Insert menu.
• CFD-Post Tools Menu (p. 325) describes how to use the CFD-Post Tools menu, which offers access to quantitative analysis utilities, the animation editor and the timestep selector.
• CFD-Post Help Menu (p. 375) describes the commands available in the Help menu.
• Turbo Workspace (p. 377) describes how to use the CFD-Post Turbo workspace, which improves and speeds up post-processing for turbomachinery simulations.
• CFX Command Language (CCL) in CFD-Post (p. 413) describes how to use the CFX Command Language (CCL) and the CFX Expression Language (CEL).
• CFX Expression Language (CEL) in CFD-Post (p. 415) describes the CFX Expression Language (CEL) in detail.
• Command Actions (p. 417) describes how to use commands in CFD-Post to edit or create graphic
objects and to perform basic input and output operations.
• Line Interface Mode (p. 429) describes running CFD-Post in line-interface mode (that is, without using a user interface, but with a viewer that shows objects you create on the command line) and in batch
mode (where a viewer is not provided and you cannot enter commands at a command prompt).
• Fluent Field Variables Listed by Category (p. 433) describes how to convert variable names in a Fluent file to CFX variable names for use in CFD-Post.
. - Contains proprietary and confidential information
of ANSYS, Inc. and its subsidiaries and affiliates.
CFD-Post User's Guide
3.6.3.1.节选段落二:
of ANSYS, Inc. and its subsidiaries and affiliates.vi
5.3.4.节选段落三:
9.2.1.4.4.
