Cyclic tests on a hybrid coupled wall utilizing a rocking mechanism.pdf
提出双肢摇摆墙概念的初始文献!!
DOI: 10.1002/eqe.832
mechanism
Toko Hitaka1,∗,†,‡ and Kenji Sakino2,§
1Disaster Prevention Research Institute, Kyoto University, Gokasho, Uji, Kyoto 611-0011, Japan
2Graduate School of Human-Environment Studies, Kyushu University, 6-10-1 Hakozaki节选段落二:
INTRODUCTION
The topic of this paper is a new type of hybrid coupled wall (HCW) system incorporating a rocking
mechanism as shown in Figure 1(b), which can be utilized in the damage control concept.节选段落三:
Dyn. 2008; 37:1657–1676
DOI: 10.1002/eqe
CYCLIC TESTS ON A HYBRID COUPLED WALL 1671
where � is the factor for estimating the compressive strength of concrete resisting in a truss
mechanism [11] and c�B is the cylinder test strength.
mechanism
INTRODUCTION
DOI: 10.1002/eqe
Cyclic tests on a hybrid coupled wall utilizing a rocking mechanism.pdf的相关案例教程
设计仿真 | MSC Nastran Utilities介绍
MSC Nastran具备静力学、动力学、非线性、优化、气弹等全面的结构分析功能,同时支持采用DMAP语言或者用户子程序的方式进行二次开发。除此之外,MSC Nastran还内置了很多工具(MSC Nastran Utilities)来帮助用户方便快捷的完成若干模型转换、信息提取汇总等工作。 MSC Nastran Utilities所包含的工具以及其功能简介如下表所示。下面主要对其中较为常用的几
数据标签工具(Data Label Utilities)
1. 引言 数据标签工具(Data Label Utilities)本身不参与计算,主要用来在图形上显示用户定义的数据,增强图形的可视化功能。这个笔记简要总结了数据标签工具相关的命令和FISH函数。 2. Data Label命令 Data Label命令共有5个,这些命令在FLAC3D/3DEC/UDEC中通用,它们分别是: (1) data label create 这个命令在空间的一个点上创
制冷实用程序:Refrigeration Utilities安装包
热管理必备工具
Cyclic tests on a hybrid coupled wall utilizing a rocking mechanism.pdf的评论0条
Cyclic tests on a hybrid coupled wall utilizing a rocking mechanism.pdf的相关视频课程
项目客服
培训客服
