Required Material Properties and Curve Settings inputs
Modulus of Elasticity (Ey), Engineering Yield Stress (sig_ys) and Engineering Ultimate Tensile Stress (sig_uts) must be specified at the temperature of interest.
Derating factor (DF) is applied to the Yield Stress (sig_ys) and the Ultimate Tensile Stress (sig_uts) to obtain σys and σuts as defined and used in ASME [ASME 2013 VIII Div.2 / KD-231.4, ASME VIII div.3]
Material Type must be selected from the drop list according to ASME [Table 3-D.1, ASME 2013 VIII Div.2 / Table KD-230.5, ASME VIII Div.3]
Number points is the number of points used in ANSYS true stress true plastic strain curve.
More points are placed where the slope is greater. Points are not equally spaced.
Curve Start Point is the first point of the ANSYS true stress true plastic strain curve.
The input required to define ANSYS multilinear hardening is the true stress – true plastic strain data points, starting at the point where true plastic strain is zero.
The true stress – true total strain curve prescribed by ASME is a smooth curve, transitioning from the elastic to the inelastic range.
Data points may be included by the user below the minimum yield stress.
全部评论 (0)
