大佬们我检查了四五遍了,也没发现问题,是软件卡了吗?
浏览:2308
Error in job Job-3-ceshi: THE SECONDARY SURFACE ASSEMBLY__PICKEDSURF41474 HAS 192 NODES IN COMMON WITH ITS MAIN SURFACE ASSEMBLY__PICKEDSURF41475.
Job Job-3-ceshi: Analysis Input File Processor aborted due to errors.
Error in job Job-3-ceshi: Analysis Input File Processor exited with an error - Please see the  Job-3-ceshi.dat file for possible error messages if the file exists.
Job Job-3-ceshi aborted due to errors.
重启也试过了
