*** Error 20001 (STR+1)
    input error found in structured input
    reading tie nodes with failure control card no 1
    line number 102507 contains improperly formatted data
**************************************** line# 102507
This problem may be solved by using long=s option.
这个是报错内容,显示我节点分离法用的不对,我的建模和网格不管是从HM导入还是LS-prepost建模与划分都出现这个问题,用的S-ALE算法,材料模型为JC本构。查看k文件节点分离法关键词:
*CONSTRAINED_TIED_NODES_FAILURE
$#    nsid      eppf     etype
         1       0.6         1
查看报错指示处102507行前后:
51136        13.95569       -3.935914            17.0       0       0
   51137        13.95569       -3.935914            17.0       0       0
   51138        13.95569       -3.935914            17.0       0       0
   51139        13.47437       -3.800166            17.5       0       0
   51140        13.47437       -3.800166            17.5       0       0
   51141        13.47437       -3.800166            17.5       0       0
   51142        13.95569       -3.935914            17.5       0       0
   51143        13.95569       -3.935914            17.5       0       0
   51144        13.95569       -3.935914            17.5       0       0
   51145        13.95569       -3.935914            17.5       0       0
无相关信息,都是网格信息
暂无数据
