『求助』利用vb对solidworks二次开发中的零件尺寸如何改
浏览:60793 回答:1
Private Sub Command1_Click()
Dim swapp As Object
Dim newpart As Object
Dim part As Object
Dim strfilename As String
Dim longstatus As Long
Dim d1 As Integer
Dim d2 As Integer
Dim h As Single
Set swapp = CreateObject("sldworks.application")
swapp.Visible = ture
Set newpart = swapp.NewDocument("E:\program files\solidworks\data\templates\零件.prtdot", 0, 0#, 0#)
Set newpart = swapp.ActivateDoc("part1")
Set swapp = CreateObject("Sldworks.application")
swapp.Visible = True
Set swapp = Nothing
If Dir(strfilename) = "" Then
MsgBox ("文件不存在,请检查路径:" & vbCrLf & strfilename)
Exit Sub
End If
strfilename = "F:\solidworkszuoye\垫圈.sldprt"
Set part = swapp.OpenDoc4(strfilename, 1, 0, "", longstatus)
Set part = swapp.ActivateDoc("垫圈")
Set part = Nothing
Set swapp = Nothing
Exit Sub
End If
strfilename = App.Path + "\" + "垫圈.sldprt"
ProgressBar1.Value = 4
d1 = Text1.Text
d2 = Text2.Text
h = Text3.Text
Debug.Print d1, d2, h
strfilename = "@垫圈.sldprt"
part.Parameter("d1@草图1" & strfilename).SystemValue = d1 / 1000
part.Parameter("d2@草图1" & strfilename).SystemValue = d2 / 1000
part.Parameter("h@拉伸1" & strfilename).SystemValue = h / 1000
part.EditRebuild
ProgressBar1.Value = 9
Set part = Nothing
Set swapp = Nothing
ProgressBar1.Value = 100
End Sub
总是出现对象变量或者with块变量未设置
这个在VB里修改solidworks中的垫圈尺寸,有什么问题呢?
刀刀1991
你好,想跟你请教一下solidworks参数化建模
2017年4月12日
