Finite element modeling of push-out tests for large stud shear connectors.pdf
2021-06-09 下载:10
下载
大小:2.27MB
如何去实现文献中的钢与混凝土之间的粘结滑移,其中的cohesive层怎么去实现?有偿求助
Journal of Constructional Steel Research 65 (2009) 1909–1920
Contents lists available at ScienceDirect
journal homepage: www.elsevier.com/locate/jcsr
Huu Thanh Nguyen, Seung Eock Kim ∗
节选段落二:
Finite element modeling of shear connection can provide
an efficient alternative to full scale push-out tests.Many researches
investigated the behaviour of stud shear connections using the
finite element model.
节选段落三:
Introduction
Geometry of push-out test
General
Finite element type and mesh
Interaction and constrain conditions
Loading and boundary conditions
Analysis method
Concrete material model
Structural
