9.7_Calculation-for-Standard-straight-bevel-gear_TechnicalData_KGSTOCKGEARS.pdf
2023-03-22
下载
大小:384.97KB
伞齿轮计算
113
9.7 Calculation for Standard straight bevel gear
1. Number of teeth of pinion z1 =1z
2. Number of teeth of gear z2 =2z
3. Module =m
4. Reference pressure angle =α
5. Facewidth =b
6. Bottom clearance m.c 250=
7. Addendum == mha
8. Dedendum == m.hf 251
9.节选段落二:
Chordal height
111
cos)cos1(
d
smRmh δθυ +−+=
222
cos)cos1(
d
smRmh δθυ +−+=
Note ∗ Table of Chordal tooth thickness can be used assuming Standard spur gear with Number of teeth Zν=z/cos δ .
114
Standard angular straight bevel gear
Calculation for Standard angular straight bevel gear is节选段落三:
the same as 9.7 except (12) and (22)
Gear terms Pinion 1 Gear 2
12.
113
3. Module =m
5. Facewidth =b
7. Addendum == mha
9.节选段落二:
Chordal height
111
cos)cos1(
d
smRmh δθυ +−+=
222
cos)cos1(
d
smRmh δθυ +−+=
114
12.
