Contact in LS-DYNA.pdf
2025-11-25
下载
大小:2.70MB
Contact in LS-DYNA
Penetration Search Methods
‘Old’ Node-based search
(Sect. 26.6 in LS-DYNA Theory Manual [2006])
Used by non-automatic contacts
Not good for disjoint or irregular meshes
Requires correct orientation of segments
Shell thickness is optional
Bucket Sort Approach
(Sects. 26.8.1 and 26.11 in LS-DYNA节选段落二:
p. 5.88
MPP Contact
MPP = Massively Parallel Processing (or Distributed
Memory Parallel)
SMP = Shared Memory Parallel
One of the main differences between MPP LS-DYNA and
SMP LS-DYNA is the implementation of the contact
algorithms.
When the same input deck is run with SMP and MPP,
results may节选段落三:
CORPORATION Contact p. 5.110
Exercise 3
Specifying contact in LS-DYNA®.
Using the interface force file.
p. 5.88
MPP Contact
Memory Parallel)
algorithms.
results may节选段落三:
Exercise 3
