HyperMesh二次开发技术—鼠标调整插件UI界面位置
1.代码实例
#新建过程subWindow
proc subWindow {} {
    toplevel .subWindow -background {black}
    wm overrideredirect .subWindow true
    wm attribute .subWindow -topmost true
    wm geometry .subWindow 296x120+300+250
    frame .subWindow.f -relief flat
    label .subWindow.f.label01 -text "" -width 1 -height 5 -background {black}
    grid .subWindow.f.label01 -column 0 -row 0 -padx 2 -sticky ew
    labelframe .subWindow.f.part01 -text "workPath" -width 25 -height 100
    label .subWindow.f.part01.label00 -text "HomeDir"  -font {arial 8 bold} -width 8
    label .subWindow.f.part01.label10 -text "" -width 20 -height 2 -relief groove -borderwidth 4
    button .subWindow.f.part01.button -text "Select" -width 5  -font {arial 8 bold}
    grid .subWindow.f.part01.label00 -column 0 -row 0 -pady 18 -padx 2 -sticky ew
    grid .subWindow.f.part01.label10 -column 1 -row 0 -pady 18 -padx 2 -sticky ew
    grid .subWindow.f.part01.button -column 1 -row 1 -pady 5 -padx 4 -sticky e
    grid .subWindow.f.part01 -column 1 -row 0 -padx 3 -pady 1 -sticky ew
    labelframe .subWindow.f.part02 -text "Import/Export" -width 23 -height 100
    button .subWindow.f.part02.button00 -text "Import" -width 5 -font {arial 8 bold}
    button .subWindow.f.part02.button01 -text "Export" -width 5 -font {arial 8 bold}
    button .subWindow.f.part02.button02 -text "-Back-" -width 5 -font {arial 8 bold} -command {destroy .subWindow}
    grid .subWindow.f.part02.button00 -column 0 -row 0 -pady 5 -padx 2 -sticky ew
    grid .subWindow.f.part02.button01 -column 0 -row 1 -pady 5 -padx 2 -sticky ew
    grid .subWindow.f.part02.button02 -column 0 -row 2 -pady 5 -padx 2 -sticky ew
    grid .subWindow.f.part02 -column 2 -row 0 -padx 3 -pady 1 -sticky ew
    pack .subWindow.f -padx 0 -pady 1
    global Dx Dy nextId
    set nextId 0
    set Dx 0
    set Dy 0
    set Mx 0
    set My 0
#绑定鼠标左键,当鼠标左键被按下执行"{}"内脚本
    bind .subWindow.f.label01 <ButtonPress-1> {
        set Mx %X;
        set My %Y;
        set relPosit [mouRelSubPosit $Mx $My];
        set Dx [lindex $relPosit 0];
        set Dy [lindex $relPosit 1];
        set nextId 1
#绑定鼠标光标,当光标移动执行"{}"内脚本
    bind .subWindow.f.label01 <Motion> {
        set Mx %X;
        set My %Y;
        set windPosit [windowPosit $Mx $My $Dx $Dy];
        if {$nextId == 1} {
            wm geometry .subWindow +[lindex $windPosit 0]+[lindex $windPosit 1]
#绑定鼠标,当鼠标被释放执行"{}"内脚本
    bind .subWindow.f.label01 <ButtonRelease> {
        set nextId 0
        break
#新建过程,计算光标位置与界面左顶点X与Y方向距离
proc mouRelSubPosit {Mx My} {
    upvar #1 Mx mx
    upvar #1 My my
    set relPosit ""
    set SizePosit [wm geometry .subWindow]
    set PositX [lindex [split $SizePosit +] 1]
    set PositY [lindex [split $SizePosit +] 2]
    set dx [expr $mx-$PositX]
    set dy [expr $my-$PositY]
    set relPosit [concat $relPosit $dx $dy]
    return $relPosit
#新建过程,计算界面新位置坐标
proc windowPosit {Mx My Dx Dy} {
    upvar #1 Mx mx
    upvar #1 My my
    upvar #1 Dx dx
    upvar #1 Dy dy
    set windPosit ""
    set windPositX [expr $mx-$dx]
    set windPositY [expr $my-$dy]
    set windPosit [concat $windPosit $windPositX $windPositY]
    return $windPosit
#调用subWindow过程
subWindow
2.代码解析
(1) 绑定鼠标左键,当鼠标左键被按下执行"{}"内脚本
        #将光标x坐标值赋给变量Mx
        set Mx %X;
        #将光标y坐标值赋给变量My
        set My %Y;
        #调用mouRelSubPosit过程,返回光标位置与界面左顶点的距离数列赋给变量relPosit,0位置为x方向距离,1位置为y方向          #距离
        #数列"relPosit" 0 位置数值赋给变量Dx
        #数列"relPosit" 0 位置数值赋给变量Dy
        #改变nextId,用于辨识是否改变界面位置
        set nextId 1;
    #新建mouRelSubPosit过程,功能:返回光标位置与界面左顶点的距离数列
        upvar #1 Mx mx
        upvar #1 My my
        set relPosit ""
        #获取界面尺寸及位置信息,赋值给变量SizePosit
        #获得界面x坐标信息,赋值给变量PositX
        #获得界面y坐标信息,赋值给变量PositY
        #光标位置与界面左顶点的x方向距离,赋值给变量dx
        #光标位置与界面左顶点的y方向距离,赋值给变量dy
        #将dx及dy连接成数列relPosit
        #将数列返回
        return $relPosit
(2) 绑定鼠标光标,当光标移动执行"{}"内脚本
        #将光标x坐标值赋给变量Mx
        set Mx %X;
        #将光标y坐标值赋给变量My
        set My %Y;
        #调用windowPosit过程,返回界面的新位置坐标数列,0位置为x方向坐标,1位置为y方向坐标
        #更改界面位置
        if {$nextId == 1} {
    #新建过程,计算界面新位置坐标
        upvar #1 Mx mx
        upvar #1 My my
        upvar #1 Dx dx
        upvar #1 Dy dy
        set windPosit ""
        #计算界面x方向位置值
        #计算界面y方向位置值
        #将 windPositX及windPositY连接成数列windPosit
        #将数列返回
        return $windPosit
(3) 绑定鼠标,当鼠标被释放执行"{}"内脚本
        #恢复辨识码nextId
        set nextId 0
        #跳出绑定
        break
(4) bind命令创建绑定
bind "组件" <事件> {执行脚本}
<事件>:Key或者KeyPress—按下按键
               KeyRelease—释放按键
               Button或者ButtonPress—按下鼠标
               ButtonRelease—释放鼠标键
               Enter—移动鼠标到组件内
               Leave—从组件上移开鼠标光标
               Motion—在某个组件内,将鼠标光标移到另一个点
               MouseWheel—用户移动鼠标滚轮
               FocusIn—组件接收键盘焦点
               FocusOut—组件失去键盘焦点
               Configure—在开始时显示组件,或者改变它的尺寸、位置或边缘宽度
               Map—组件可见
               Unmap—组件不再可见
               Destroy—删除组件
3.启动插件,利用鼠标调整界面位置
HyperMesh二次开发技术—鼠标调整插件UI界面位置的图2
HyperMesh二次开发技术—鼠标调整插件UI界面位置的图3
案例源码进群:756716776下载
