基于CentOS8.0 远程桌面VNC配置
设置工作站远程桌面(linux CentOS8.0)
Prerequisites
A system running CentOS 8 Desktop operating system.
A root password is configured on your server.
Getting Started
By default, SELinux is enabled in CentOS 8 operating system and the VNC server will not work properly if SELinux is enabled. So it is a good idea to disable the SELinux in your system. You can disable it by editing the following file:
nano /etc/sysconfig/selinux
找到如下命令
SELINUX=enforcing
更改为:
SELINUX=disabled
保存,重启,reboot
Install VNC Server
By default, TigerVNC is available in the CentOS 8 default repository. You can install it by running the following command:
dnf install tigervnc-server tigervnc-server-module -y
Once the installation has been completed, you can proceed to the next step.
Create New User and Set VNS Password
vncpasswd
Set VNS Password
Password: Verify: Would you like to enter a view-only password (y/n)? n A view-only password is not used
设置config
vim ~/.vnc/config session=gnome geometry=1920x1200 localhost alwaysshared
设置用户桌面号
nano /etc/tigervnc/vncserver.users
:1=root :2=abaqus :3=ansys
systemctl daemon-reload
启动VNC
systemctl start vncserver@:1.service
设置随开机启动
systemctl enable vncserver@:1.service
sudo systemctl enable vncserver@:1 --now
设置防火墙
firewall-cmd --add-service=vnc-server --permanent
重启防火墙
sudo firewall-cmd --reload
参考文献:
https://www.linuxfordevices.com/tutorials/centos/install-vnc-server-on-centos-8
https://www.how2shout.com/linux/how-to-install-and-configure-vnc-server-on-centos-8/
https://www.howtoforge.com/how-to-install-and-configure-vnc-server-on-centos-8/
附带在linux下设置开机启动licence
定义sh文件 abq2020.sh
/lmgrd 路径/imgrd -c /licence路径/ABAQUSLM__lmgrd__SSQ.lic
比如
/DATA/ABAQUS2020/license/lmgrd -c /DATA/ABAQUS2020/_SolidSQUAD_/SolidSQUAD_License_Servers/Vendors/DSSimulia/Licenses/ABAQUSLM__lmgrd__SSQ.lic
接着,修改abq2020.sh属性
sudo chmod +xrw abq2020.sh
chkconfig --add abq2020.sh
chkconfig abq2020.sh on
reboot
通过命令行在linux下启动abaqus
abaqus cae -mesa
全部评论 (0)
