二/三维晶粒建模软件neper帮助文档学习2
neper每个模块下的例子命令
1Tessellation Module (-T)的例子
Below are some examples of use of neper -T.
1. Generate a Voronoi tessellation containing 100 cells.
$ neper -T -n 100
$ neper -V n100-id1.tess -datacellcol id -print img1
2. Generate a different Voronoi tessellation containing 100 cells (identifier = 2).
$ neper -T -n 100 -id 2
3. Use an elongated domain and generate a Voronoi tessellation containing 100 cells.
$ neper -T -n 100 -domain "cube(3,1,0.33)"
               neper -T -n 100 -domain "cylinder(2,4,500)"
               neper -V n100-id1.tess -showedge "cyl==0" -datacellcol id -print img1
            neper -T -n 1000 -domain "sphere(2,500)"
            neper -V n1000-id1.tess -showedge "polynb>1" -datacellcol id -print img1
               neper -T -n 100 -domain "cylinder(2,2,8)"
               neper -T -n 100 -domain "sphere(2,40)"
4. Generate a Voronoi tessellation containing 100 cells and apply regularization.
$ neper -T -n 100 -reg 1
5. Generate a 2D Voronoi tessellation containing 100 cells.
$ neper -T -n 100 -dim 2
                 neper -T -n 100 -dim 2 -domain "square(4,2)" -o rectangle1
                 neper -V rectangle1.tess -datacellcol id -print img1
                 neper -T -n 100 -dim 2 -domain "circle(3)" -o circ1
                 neper -V circ1.tess -datacellcol id -print img1
6. Generate a tessellation containing 100 cells with an x columnar axis.
$ neper -T -n 100 -morpho "columnar(x)"
7. Generate a tessellation containing 100 cells with a bamboo structure along x.
$ neper -T -n 100 -morpho "bamboo(x)"
8. Generate a tessellation containing 100 cells with experimental grain-growth morphological
properties.  gg代表 grain growth
$ neper -T -n 100 -morpho gg
9. Generate a tessellation containing 100 cells with experimental grain-growth morphological
properties and define groups by splitting cells based on their ids.
$ neper -T -n 100 -morpho gg -group "id<=50?1:2"
$ neper -V n100-id1.tess -datacellcol group -print img1
$ neper -V n100-id1.tess -datacellcol group -datacelltrs 0.5 -print img1
1.jpg10. Generate a tessellation containing 100 cells with experimental grain-growth morphological
properties and an aspect ratio of 2:1:0.5.
$ neper -T -n 100 -morpho "gg,aspratio(2,1,0.5)"
11. Generate a tessellation containing 100 cells with experimental grain-growth morphological
properties, and get the equivalent diameters and sphericities of the cells.
$ neper -T -n 100 -morpho gg -statcell diameq,sphericity
12. Generate a tessellation of specified absolute grain size distribution (the number of cells is
determined accordingly).
$ neper -T -n from_morpho -morpho
"diameq:lognormal(0.1,0.03),1-sphericity:lognormal(0.145,0.03)"
13. Generate a tessellation in a non-convex domain (by cutting the tessellation once generated).
-transform "cut(cylinder(1.2,0.5,0.5,0,1,0,0.4))"
14. Generate a 2-scale Voronoi tessellation containing 100 × 10 cells.
$ neper -T -n 100::10
15. Generate a 2-scale Voronoi tessellation containing 100×10 cells, with different tessellations
at scale 2 (identifier = 2) (identifier = 2).
$ neper -T -n 100::10 -id 1::2
16. Generate a 2-scale tessellation containing 10 primary cells with grain-growth morphological
properties, each one divided into lamellae of width 0.1.
$ neper -T -n 10::from_morpho -morpho "gg::lamellar(w=0.1)"
17. Generate a 2-scale Voronoi tessellation containing 10 primary cells with grain-growth mor-
phological properties, each one divided into lamellae of widths loaded from file lam_width
and plane normals loaded from file lam_normal.
$  neper -T -n 10::from_morpho -morpho "gg::lamellar(w=msfile(lam_
width),v=msfile(lam_normal))"
lam_width:
1 0.05
2 0.10
3 0.05
4 0.10
5 0.05
6 0.10
7 0.05
8 0.10
9 0.05
10 0.10
lam_normal:
1 1.000000 0.000000 0.000000
2 0.000000 1.000000 0.000000
3 1.000000 0.000000 0.000000
4 0.000000 1.000000 0.000000
5 1.000000 0.000000 0.000000
6 0.000000 1.000000 0.000000
7 1.000000 0.000000 0.000000
8 0.000000 1.000000 0.000000
9 1.000000 0.000000 0.000000
10 0.000000 1.000000 0.000000
18. Generate a 2-scale Voronoi tessellation containing 3 primary cells divided into 1, 10 and
100 secondary cells, respectively.
$ neper -T -n "3::msfile(myfile)" -id 1::1
myfile:
1 1
2 10
3 100
19. Generate a 2-scale Voronoi tessellation containing 2 × 3 cells with specific seed coordinates
at both scales (files coo1 and coo2).
$ neper -T -n 2::3 -id 1::1 \
-morphooptiini "coo:file(coo1),weight:0::coo:msfile(coo2),weight:0" \
-morpho voronoi
coo1:
0.25 0.50 0.50
0.75 0.50 0.50
coo2:
1 0.25 0.10 0.50
1 0.25 0.50 0.50
1 0.25 0.90 0.50
2 0.75 0.50 0.10
2 0.75 0.50 0.50
2 0.75 0.50 0.90
Note that coo1 is a simple position file (see Section B.4 [Position File], page 91) while coo2
is a multiscale cell file (see Section B.3 [Multiscale Cell File], page 90).
20. Generate a Voronoi tessellation containing 100 cells with uniformly distributed crystal ori-
entations and cubic crystal symmetry.
$ neper -T -n 100 -oricrysym cubic -ori uniform
21. Generate 100 uniformly distributed crystal orientations with cubic crystal symmetry (no
tessellation).
$ neper -T -n 100 -oricrysym cubic -ori uniform -for ori
2Meshing Module (-M)的例子
1. Mesh tessellation n100-id1.tess.
$ neper -M n100-id1.tess
2. Mesh 2D raster tessellation n100-id1.tesr.
$ neper -M n100-id1.tesr
3. Mesh tessellation n100-id1.tess with a mesh size of rcl = 0.5 and in 2nd-order elements.
$ neper -M n100-id1.tess -cl 0.5 -order 2
$ neper -V n100-id1.msh -dataelsetcol id -print msh1
$ neper -M n100-id1.tess -rcl 0.5 -order 2
4. Mesh tessellation n100-id1.tess with small elements for the interior cells and bigger ele-
ments for the boundary cells.
$ neper -M n100-id1.tess -rcl "body!=0?0.2:0.5"
5. Remesh mesh n150_def.msh (comprising poor-quality elements) into a clean, new mesh.
Transport the scalar data of file n150_def.data from the deformed mesh to the new mesh.
$ neper -M n150.tess,n150_def.msh -transport elt:real1:n150_def.data
-rcl 0.5 -o n150_new
6. Mesh tessellation n100-id1.tess and divide the mesh into 8 或 8*8 partitions (neper的编译需要用libscotch,否则不能使用-part,出现错误提示).
$ neper -M n100-id1.tess -rcl 0.4 -part 8
$ neper -M n100-id1.tess -part 8:8
7. Mesh tessellation n100-id1.tess into regular hexahedral elements (non-conformal mesh).
$ neper -M n100-id1.tess -rcl 0.5 -elttype hex
$ neper -M n100-id1.tess -rcl 0.2 -elttype hex
8. Mesh tessellation n100-id1.tess and get, for each element, its radius ratio and its volume.
$ neper -M n100-id1.tess -statelt rr,vol
9. Mesh tessellation n100-id1.tess and get the number of nodes and elements of the mesh.
$ neper -M n100-id1.tess -statmesh nodenb,eltnb
3、Simulation Module (-S)的例子
Below are some examples of use of neper -S.
1. Transform an FEPX raw result directory into a simulation directory (all results).
$ neper -S fepx-simulation
2. Transform an FEPX raw result directory into a simulation directory of specified name (all
results).
$ neper -S fepx-simulation -o foo
3. Transform an FEPX raw result directory into a simulation directory of specified results:
the nodal ‘coo’ and the elemental ‘ori’.
$ neper -S fepx-simulation -noderes coo -eltres ori
4. Transform an FEPX raw result directory into a simulation directory; get all results and the
element volumes.
$ neper -S fepx-simulation -eltres inputres,vol
5. Add the nodal x and the elemental vol and stress33 results to a simulation directory.
$ neper -S simulation -noderes x -eltres vol,rr
6. Add the elemental energy result, defined as 0.1234*(crss-crss(step=0))^2, to a simu-
lation directory.
$ neper -S -eltres "energy:0.1234*(crss-crss(step=0))^2"
7. Override the elemental energy result, newly defined as 0.5678*(crss-crss(step=0))^2,
$ neper -S -eltres ’!energy,energy:0.5678*(crss-crss(step=0))^2’
8. Add the elset stress result to a simulation directory (the stress result must exist for
elements).
$ neper -S simulation -eltres stress
