ABAQUS IVOL integration point volume
浏览:1970 评论:1
1.IVOL is the volume associated with a particular integration point. For a reduced integration element (i.e., an element with only one integration point), IVOL will equal the element volume. For fully
integrated elements, IVOL will be some fraction of the element volume (e.g., for a 2X2X2 array of integration points, IVOL should be 1/8 of the element volume).
2.在record key中是76
Record key: 76(S) | Output variable identifier: IVOL |
Record type: Integration point volumeAttribute: 1 – Current integration point volume. Section point volume in the case of beams and shells. |
3.原贴https://abaqus.yahoogroups.narkive.com/cebWcZCV/ivol
