TCL自学笔记-02
*setvalue
Syntax
*setvalue entity_type <select_type>=<selection> <name1>=<value1> ?<name2>=<value2>? ... ?<nameN>=<valueN>? ?row=<row_index>? ?column=<column_index>? ?STATUS=<status>?
Examples
Update the attribute Rho of material ID 1 along with Status to value 1:
*setvalue mats id=1 Rho=1.1 STATUS=1
自学语句1:
*setvalue props name = $name STATUS = 1 95=$bihou
自学语句2:
*setvalue comps name=$name propertyid=$props_id
自学语句3:
*setvalue props id =$props_id materialid = $mats_ids
*createmark
Syntax
*createmark entity_type mark_id "?option?" list
Examples
To delete all elements in the database:
*createmark elems 1 "all"
*deletemark elems 1
自学语句1:
*createmark comps 1 all
*deletemark comps 1
*clearmarkall
Clear all entity IDs for all entity types from the specified mark.
Syntax
*clearmarkall mark_id
Examples
To clear the contents of mark 2 for all entity types:
*clearmarkall 2
hm_getmark
Returns the entity IDs of the passed entity type on the specified mark.
Syntax
hm_getmark entity_type mark_id ?panel_sensitive?
Examples
To return the components on mark 1:
hm_getmark comps 1
A mark of loads is created in the Delete panel. The Mask panel has been pushed using the command "hm_pushpanel mask". A mark of loads is created in the Mask panel. To get the list of loads on mark 1 created from the Mask panel:
hm_getmark loads 1 1
To get the list of loads on mark 1 created from the Delete panel:
hm_getmark loads 1 0
自学语句1:
set comps_id [hm_getmark comps 1]
坚持每天学习,时间会证明一切,加油!
