Tresca本构模型VUMAT-3D(源代码免费)
二维Tresca本构模型VUMAT,请参考(完全免费):https://www.jishulink.com/post/1867025
一、ABAQUS自带Tresca本构与VUMAT-3D对比
图1 模型示意图
图2 ABAQUS 自带计算应力云图
图3 VUMAT-Tresca-3D 计算应力云图
图4 Tresca应力对比(Path1)
图5 S11应力对比(Path1)
表5 Job监控数据对比
二、Tresca本构模型介绍和算法实现
本人已在二维模型中写明,在此不作赘述,请参考:https://www.jishulink.com/post/1867025
三、Tresca-3 VUMAT 源代码(完整)
module mymod
integer,parameter::Q=8
real(Q),parameter::zero=0.0D0,one=1.D0,two=2.0D0,three=3.0D0,
& four=4.0D0,ref=3.D-6,half=0.5D0
contains
subroutine ElasticMatrix(E,v,M)
real(Q),intent(out),dimension(6,6)::M
real(Q),intent(in)::E,v
M(1,1:6)=(/one-v,v,v,zero,zero,zero/)
M(2,1:6)=(/v,one-v,v,zero,zero,zero/)
M(3,1:6)=(/v,v,one-v,zero,zero,zero/)
M(4,1:6)=(/zero,zero,zero,half*(one-two*v),zero,zero/)
M(5,1:6)=(/zero,zero,zero,zero,half*(one-two*v),zero/)
M(6,1:6)=(/zero,zero,zero,zero,zero,half*(one-two*v)/)
M=M*E/((one+v)*(one-two*v))
end subroutine ElasticMatrix
subroutine Matrix_inverse(M,Inve)
real(Q),intent(in),dimension(3,3)::M
real(Q),intent(out),dimension(3,3)::Inve
real(Q),dimension(3,3)::temp
integer::i,j
real(Q)::Det
temp(1,1)=M(2,2)*M(3,3)-M(2,3)*M(3,2)
temp(2,1)=M(2,3)*M(3,1)-M(2,1)*M(3,3)
temp(3,1)=M(2,1)*M(3,2)-M(2,2)*M(3,1)
temp(3,2)=M(1,2)*M(3,1)-M(1,1)*M(3,2)
temp(2,2)=M(1,1)*M(3,3)-M(1,3)*M(3,1)
temp(3,3)=M(1,1)*M(2,2)-M(1,2)*M(2,1)
temp(1,2)=M(1,3)*M(3,2)-M(1,2)*M(3,3)
temp(1,3)=M(1,2)*M(2,3)-M(1,3)*M(2,2)
temp(2,3)=M(1,3)*M(2,1)-M(1,1)*M(2,3)
Det=M(1,1)*temp(1,1)+M(1,2)*temp(2,1)+M(1,3)*temp(3,1)
Inve=temp/Det
end subroutine Matrix_inverse
subroutine returntoplane(p,s)
real(Q),intent(inout)::p
real(Q),intent(in)::s
real(Q)::a,b,c,d,t
dimension::p(3),s(4)
t=-(s(1)*p(1)+s(2)*p(2)+s(3)*p(3)+s(4))/two!!!!(a**2+b**2+c**2)
p(1)=s(1)*t+p(1)
p(2)=s(2)*t+p(2)
p(3)=s(3)*t+p(3)
end subroutine returntoplane
subroutine returntoline(p,l)
real(Q),intent(in)::l
real(Q)::t
dimension::p(3),l(3)
t=(p(1)+p(2)+p(3)-l(1)-l(2)-l(3))/three
p(1:3)=(/t+l(1),t+l(2),t+l(3)/)
end subroutine returntoline
subroutine modi_pstress(s,c)
integer::rp
real(Q),intent(inout),dimension(3)::s
real(Q),intent(in)::c
real(Q)::plane,line,f1,f2,f3,f4,f5,f6,two3,four3
dimension ::plane(4),line(6)
two3=c*two/three
four3=c*four/three
f1=s(1)-s(2)-c*2.0D0
f2=s(2)-s(1)-c*2.0D0
f3=s(2)-s(3)-c*2.0D0
f4=s(3)-s(2)-c*2.0D0
f5=s(3)-s(1)-c*2.0D0
f6=s(1)-s(3)-c*2.0D0
if ((f1>=f4*2.D0).and.(f1>=f6*2.D0).and.(f1>=0.D0)) then
plane(1:4)=(/one,-one,zero,-c*two/)
call returntoplane(s,plane)
else if((f2>=f3*2.D0).and.(f2>=f5*2.D0).and.(f2>=0.D0))then
plane(1:4)=(/-one,one,zero,-c*two/)
else if((f3>=f2*2.D0).and.(f3>=f6*2.D0).and.(f3>=0.D0))then
plane(1:4)=(/zero,one,-one,-c*two/)
else if((f4>=f1*2.D0).and.(f4>=f5*2.D0).and.(f4>=0.D0))then
plane(1:4)=(/zero,-one,one,-c*two/)
else if((f5>=f2*2.D0).and.(f5>=f4*2.D0).and.(f5>=0.D0))then
plane(1:4)=(/-one,zero,one,-c*two/)
else if((f6>=f3*2.D0).and.(f6>=f1*2.D0).and.(f6>=0.D0))then
plane(1:4)=(/one,zero,-one,-c*two/)
else if((f1<f4*2.D0).and.(f4<f1*2.D0).and.(f1>=0.D0))then
line(1:3)=(/two3,-four3,two3/)
call returntoline(s,line)
else if((f4<f5*2.D0).and.(f5<f4*2.D0).and.(f4>=0.D0))then
line(1:3)=(/-two3,-two3,four3/)
else if((f2<f5*2.D0).and.(f5<f2*2.D0).and.(f2>=0.D0))then
line(1:3)=(/-four3,two3,two3/)
else if((f2<f3*2.D0).and.(f3<f2*2.D0).and.(f3>=0.D0))then
line(1:3)=(/-two3,four3,-two3/)
else if((f3<f6*2.D0).and.(f6<f3*2.D0).and.(f6>=0.D0))then
line(1:3)=(/two3,two3,-four3/)
else if((f6<f1*2.D0).and.(f1<f6*2.D0).and.(f6>=0.D0))then
line(1:3)=(/four3,-two3,-two3/)
end if
end subroutine modi_pstress
subroutine getnewstress(Ematrix,Pstress,newstress)
real(Q),intent(out),dimension(6)::newstress
real(Q)::Pstress,Ematrix,inve,temp
dimension::Ematrix(3,3),Pstress(3),inve(3,3),temp(3,3)
call Matrix_inverse(Ematrix,Inve)
Ematrix(1:3,1)=Ematrix(1:3,1)*Pstress(1)
Ematrix(1:3,2)=Ematrix(1:3,2)*Pstress(2)
Ematrix(1:3,3)=Ematrix(1:3,3)*Pstress(3)
temp=matmul(Ematrix,Inve)
newstress(1:3)=(/temp(1,1),temp(2,2),temp(3,3)/)
newstress(4:6)=(/temp(1,2),temp(2,3),temp(1,3)/)
end subroutine getnewstress
end module mymod
C***********************************************************************
C*************************** VUMAT ***********************************
subroutine vumat(
C Readonly-
1 nblock,ndir,nshr,nstatev,nfieldv,nprops,lanneal,
2 stepTime,totalTime,dt,cmname,coordMp,charLength,
3 props,density,strainInc,relSpinInc,
4 tempOld,stretchOld,defgradOld,fieldOld,
5 stressOld,stateOld,enerInternOld,enerInelasOld,
6 tempNew,stretchNew,defgradNew,fieldNew,
C Writeonly-
7 stressNew,stateNew,enerInternNew,enerInelasNew)
C
use mymod
include 'vaba_param.inc'
dimension props(nprops),density(nblock),
1 coordMp(nblock,*),
2 charLength(*),strainInc(nblock,ndir+nshr),
3 relSpinInc(*),tempOld(*),
4 stretchOld(*),defgradOld(*),
5 fieldOld(*),stressOld(nblock,ndir+nshr),
6 stateOld(nblock,nstatev),enerInternOld(nblock),
7 enerInelasOld(nblock),tempNew(*),
8 stretchNew(*),defgradNew(*),fieldNew(*),
9 stressNew(nblock,ndir+nshr),stateNew(nblock,nstatev),
1 enerInternNew(nblock),enerInelasNew(nblock)
character*80 cmname
real(Q)::nam,f1,f2,f3,f4,f5,f6,c,
& E,DELAS,dstrain,pstrain,yield,
& tstress,pstress,pvec,p,Ematrix,newstress,pvecc
integer::bi,ji,ki,li
C logical::yield
dimension::DELAS(6,6),stressNewInt (6,1),stressinc(6,1),
& tstress(nblock,6),pstress(nblock,3),pvec(nblock,3,3),p(3),
& pstrain(nblock,3),Ematrix(3,3),strainIncInt(6,1),newstress(6),
& pvecc(3,3)
C get soil properties
E = props(1)
nam = props(2)
c = props(3)
call ElasticMatrix(E,nam,DELAS)
C if(totaltime.gt.0)then
C read * !输入回车,继续运行
C end if
do 200 bi=1,nblock
strainIncInt ( 1:3 , 1 ) = strainInc( bi,1:3 )
strainIncInt ( 4 , 1 ) = 2.0D0*strainInc( bi,4 )
strainIncInt ( 5 , 1 ) = 2.0D0*strainInc( bi,5 )
strainIncInt ( 6 , 1 ) = 2.0D0*strainInc( bi,6 )
stressinc=matmul(DELAS,strainIncInt)
do 300 ji=1,6
tstress(bi,ji)=stressOld(bi,ji)+stressinc(ji,1)
300 continue
200 continue
call vsprind(nblock,tstress,pstress,pvec,3,3)
C***************************** Begin the main loop **************************************
do 100 bi=1,nblock
!to check if yield
p(1:3)=pstress(bi,1:3)
f1=p(1)-p(2)-c*2.0D0
f2=p(2)-p(1)-c*2.0D0
f3=p(2)-p(3)-c*2.0D0
f4=p(3)-p(2)-c*2.0D0
f5=p(3)-p(1)-c*2.0D0
f6=p(1)-p(3)-c*2.0D0
if((max(f1,f2,f3,f4,f5,f6)<=0.D0).or.(Totaltime<=1.0D0))then
stressNew(bi,1:6)=tstress(bi,1:6)
else
call modi_pstress(p,c)
pvecc(1,1)=pvec(bi,1,1)
pvecc(2,1)=pvec(bi,1,2)
pvecc(3,1)=pvec(bi,1,3)
pvecc(1,2)=pvec(bi,2,1)
pvecc(2,2)=pvec(bi,2,2)
pvecc(3,2)=pvec(bi,2,3)
pvecc(1,3)=pvec(bi,3,1)
pvecc(2,3)=pvec(bi,3,2)
pvecc(3,3)=pvec(bi,3,3)
call getnewstress(pvecc,p,newstress)
do ji=1,6
stressNew(bi,ji)=newstress(ji)
end do
end if
100 continue
end
以上为完整的Tresca-3D VUMAT源代码
如需包含注释的版本,请参考付费内容,感谢打赏辛苦费,您的支持是我更新的动力。
该付费内容为:包含注释源代码和验证用的CAE文件
2张图片 包含2个附件 0人购买
