HILL48 +各向同性Voce硬化umat子程序
!  HILL48 PLASTICITY UMAT WITH VOCE ISOTROPIC HARDENING
!  IMPLEMENTATION: GENERALIZED RADIAL-RETURN IN EIGENSPACE
! AUTHOR:
!  Mohammad Hasaninia
!  Computational Advanced Manufacturing and Materials Laboratory (CAMML)
!  Department of Mechanical Engineering
!  University of Wyoming
! REFERENCE:
!  Versino, D. and Bennett, K.C. (2018). Generalized radial-return mapping
!  algorithm for anisotropic von Mises plasticity framed in material
!  eigenspace. Int. J. Numer. Meth. Engng, 116: 202-222.
!  https://doi.org/10.1002/nme.5921
! INPUT PROPERTIES (PROPS) DEFINITION:
!  PROPS(1) : Young's Modulus (E)
!  PROPS(2) : Poisson's Ratio (nu)
!  PROPS(3) : Initial Yield Stress (Sigma_Y0)
!  PROPS(4) : Saturation Stress (Q_inf) - Voce Parameter
!  PROPS(5) : Hardening Rate (b)    - Voce Parameter
!  PROPS(6) : Hill F
!  PROPS(7) : Hill G
!  PROPS(8) : Hill H
!  PROPS(9) : Hill L
!  PROPS(10) : Hill M
!  PROPS(11) : Hill N
! STATE VARIABLES (STATEV) OUTPUT:
!  STATEV(1) : Equivalent Plastic Strain (alpha)
!  STATEV(2) : Current Yield Stress
!  STATEV(3-8) : Plastic Strain Tensor (11, 22, 33, 12, 13, 23)
!  STATEV(9) : Convergence Flag (0=Converged, 1=Failed)
SUBROUTINE UMAT(STRESS, STATEV, DDSDDE, SSE, SPD, SCD, RPL,     &
        DDSDDT, DRPLDE, DRPLDT, STRAN, DSTRAN, TIME, DTIME, &
        TEMP, DTEMP, PREDEF, DPRED, CMNAME, NDI, NSHR, NTENS, &
        NSTATV, PROPS, NPROPS, COORDS, DROT, PNEWDT,     &
        CELENT, DFGRD0, DFGRD1, NOEL, NPT, LAYER, KSPT,   &
        KSTEP, KINC)
  IMPLICIT NONE
  ! Abaqus UMAT interface variables
  CHARACTER*80 CMNAME
  INTEGER NDI, NSHR, NTENS, NSTATV, NPROPS
  INTEGER NOEL, NPT, LAYER, KSPT, KSTEP, KINC
  REAL(8) STRESS(NTENS), STATEV(NSTATV), DDSDDE(NTENS,NTENS)
  REAL(8) SSE, SPD, SCD, RPL, DRPLDT, DTIME, TEMP, DTEMP, PNEWDT, CELENT
  REAL(8) STRAN(NTENS), DSTRAN(NTENS), TIME(2), PREDEF(1), DPRED(1)
  REAL(8) PROPS(NPROPS), COORDS(3), DROT(3,3), DFGRD0(3,3), DFGRD1(3,3)
  REAL(8) DDSDDT(NTENS), DRPLDE(NTENS)
  ! Local variables for plasticity computation
  REAL(8) :: alpha_tr, alpha, StressYield, s_y, s_y_D, s_y_tr, f_gamma_tr
  REAL(8) :: Sigma_Y0, Q_inf, b_voce
  REAL(8) :: MatM(6,6), MatD(6,6), MatI(6,6)
  REAL(8) :: MatM_copy(6,6), Mat_inv(6,6)
  REAL(8) :: W(6), Q(6,6), Gamma(6,6), K(6,6), dK_dDelta_gamma_matrix(6,6)
  REAL(8) :: s_tr(6), strain_p(6), Stress_New(6), s_tilde_tr(6)
  REAL(8) :: Vec(6), dev_corrected(6)
  REAL(8) :: E, XNUE, EBULK3, EG2, EG, ELAM
  REAL(8) :: HillF, HillG, HillH, HillL, HillM, HillN
  REAL(8) :: pressure, d_ga, omega, d_al, f_gamma_delta, delta_alpha
  REAL(8) :: Df_gamma_d_d_gamma, d_omega_d_d_gamma, d_sy_d_d_gamma
  REAL(8) :: TOLERANCE, exp_term
  INTEGER :: iteration, K3, K5, K6, K7, K8, INFO
  LOGICAL :: converged
  ! Extract material properties
  E = PROPS(1)       ! Young's modulus
  XNUE = PROPS(2)     ! Poisson's ratio
  Sigma_Y0 = PROPS(3)   ! Initial yield stress
  Q_inf = PROPS(4)     ! Saturation stress (Q∞)
  b_voce = PROPS(5)    ! Voce hardening rate parameter
  HillF = PROPS(6)     ! Hill parameter F
  HillG = PROPS(7)     ! Hill parameter G
  HillH = PROPS(8)     ! Hill parameter H
  HillL = PROPS(9)     ! Hill parameter L
  HillM = PROPS(10)    ! Hill parameter M
  HillN = PROPS(11)    ! Hill parameter N
  ! Initialize state variables
  IF (TIME(2) < 1.0D-6) THEN
    alpha_tr = 0.0D0
    ! Voce: σ_y0 = σ_Y0 + Q∞(1 - e^0) = σ_Y0
    StressYield = Sigma_Y0
    strain_p = 0.0D0
    STATEV(1:9) = 0.0D0
  ELSE
    alpha_tr = STATEV(1)
    StressYield = STATEV(2)
    strain_p(1:6) = STATEV(3:8)
  END IF
  ! Create elasticity matrix
  EBULK3 = E/(1.0D0-2.0D0*XNUE)
  EG2 = E/(1.0D0+XNUE)
  EG = EG2/2.0D0
  ELAM = (EBULK3-EG2)/3.0D0
  MatD = 0.0D0
  MatD(1:3,1:3) = ELAM
  DO K3 = 1, 3
    MatD(K3,K3) = EG2 + ELAM
  END DO
  DO K3 = 4, 6
  MatD(K3, K3) = EG
  END DO
  ! Create Hill anisotropy matrix
  MatM = 0.0D0
  MatM(1,1) = HillG + HillH
  MatM(2,2) = HillF + HillH
  MatM(3,3) = HillF + HillG
  MatM(1,2) = -HillH
  MatM(1,3) = -HillG
  MatM(2,3) = -HillF
  MatM(2,1) = MatM(1,2)
  MatM(3,1) = MatM(1,3)
  MatM(3,2) = MatM(2,3)
  MatM(4,4) = 2.0D0*HillN
  MatM(5,5) = 2.0D0*HillM
  MatM(6,6) = 2.0D0*HillL
  ! Identity matrix
  MatI = 0.0D0
  DO K5 = 1, 6
    MatI(K5,K5) = 1.0D0
  END DO
  ! Compute trial stress (elastic predictor)
  Vec = MATMUL(MatD, DSTRAN)
  Stress_New = Vec + STRESS
  s_tr = Stress_New
  ! Extract deviatoric part
  pressure = (Stress_New(1)+Stress_New(2)+Stress_New(3))/3.0D0
  s_tr(1:3) = s_tr(1:3) - pressure
  ! Eigendecomposition of anisotropy tensor
  MatM_copy = MatM
  CALL compute_eigendecomposition(MatM_copy, W, Q, Gamma, INFO)
  IF (INFO /= 0) THEN
    WRITE(*,*) 'Error in eigendecomposition, INFO = ', INFO
    RETURN
  END IF
  ! Transform trial stress to eigenspace
  s_tilde_tr = MATMUL(TRANSPOSE(Q), s_tr)
  ! Initialize trial values
  s_y_tr = StressYield
  ! Compute trial yield function
  f_gamma_tr = 0.5D0 * DOT_PRODUCT(s_tilde_tr, MATMUL(Gamma, s_tilde_tr)) - s_y_tr**2
  ! Check yield condition
  IF (f_gamma_tr <= 0.0D0) THEN
    ! Elastic step
    STRESS = Stress_New
    d_ga = 0.0D0
    alpha = alpha_tr
    s_y = StressYield
  ELSE
    ! Plastic step - Newton-Raphson iteration
    tolerance = 5.0D-4
    d_ga = 0.0D0
    alpha = alpha_tr
    converged = .FALSE.
    DO iteration = 1, 250
      ! Build K matrix (diagonal)
      K = 0.0D0
      DO K6 = 1, 6
        K(K6,K6) = Gamma(K6,K6) / (1.0D0 + 2.0D0*EG*d_ga*Gamma(K6,K6))**2
      END DO
      ! Compute auxiliary variable omega
      omega = SQRT(0.5D0 * DOT_PRODUCT(s_tilde_tr, MATMUL(K, s_tilde_tr)))
      IF (omega <= 1.0D-14) THEN
        WRITE(*,*) 'Warning: omega is too small'
        EXIT
      END IF
      ! Update alpha
      delta_alpha = 2.0D0 * d_ga * omega
      alpha = alpha_tr + delta_alpha
      ! VOCE HARDENING MODEL
      ! σ_y = σ_Y0 + Q∞(1 - exp(-b·α))
      exp_term = EXP(-b_voce * alpha)
      s_y = Sigma_Y0 + Q_inf * (1.0D0 - exp_term)
      ! Derivative: ∂σ_y/∂α = Q∞·b·exp(-b·α)
      s_y_D = Q_inf * b_voce * exp_term
      ! Compute residual function
      f_gamma_delta = (s_y / omega) - 1.0D0
      ! Check convergence
      IF (ABS(f_gamma_delta) <= tolerance) THEN
        StressYield = s_y
        converged = .TRUE.
        EXIT
      END IF
      ! Compute derivatives for Newton-Raphson
      dK_dDelta_gamma_matrix = 0.0D0
      DO K7 = 1, 6
        dK_dDelta_gamma_matrix(K7,K7) = -4.0D0*EG*Gamma(K7,K7)**2 &
          / (1.0D0 + 2.0D0*EG*d_ga*Gamma(K7,K7))**3
      END DO
      d_omega_d_d_gamma = (1.0D0 / (4.0D0 * omega)) &
        * DOT_PRODUCT(s_tilde_tr, MATMUL(dK_dDelta_gamma_matrix, s_tilde_tr))
      ! Chain rule: ∂σ_y/∂Δγ = (∂σ_y/∂α)·(∂α/∂Δγ)
      d_sy_d_d_gamma = 2.0D0 * s_y_D * (omega + d_ga * d_omega_d_d_gamma)
      ! Derivative of residual
      Df_gamma_d_d_gamma = (1.0D0 / omega) * d_sy_d_d_gamma &
        - (s_y / (omega**2)) * d_omega_d_d_gamma
      ! Newton-Raphson update
      d_ga = d_ga - f_gamma_delta / Df_gamma_d_d_gamma
    END DO
    ! Update stress after Newton loop
    Mat_inv = 0.0D0
    DO K8 = 1, 6
      Mat_inv(K8,K8) = 1.0D0 / (1.0D0 + 2.0D0*EG*d_ga*Gamma(K8,K8))
    END DO
    dev_corrected = MATMUL(Q, MATMUL(Mat_inv, MATMUL(TRANSPOSE(Q), s_tr)))
    ! Assemble full Cauchy stress
    STRESS(1:3) = dev_corrected(1:3) + pressure
    STRESS(4:6) = dev_corrected(4:6)
    IF (.NOT. converged) THEN
      WRITE(*,*) 'WARNING: Newton-Raphson did not converge!'
      StressYield = s_y
      STATEV(9) = 1.0D0
    END IF
  END IF
  ! Consistent tangent operator
  DDSDDE = MatD
  ! Update state variables
  STATEV(1) = alpha          ! Equivalent plastic strain
  STATEV(2) = s_y           ! Current yield stress
  strain_p = strain_p + d_ga * MATMUL(MatM, dev_corrected)
  STATEV(3:8) = strain_p(1:6)    ! Plastic strain components
  RETURN
  CONTAINS
  SUBROUTINE compute_eigendecomposition(A, W, Q, Gamma, INFO)
    IMPLICIT NONE
    INTEGER, INTENT(OUT) :: INFO
    REAL(8), DIMENSION(6,6), INTENT(INOUT) :: A
    REAL(8), DIMENSION(6), INTENT(OUT) :: W
    REAL(8), DIMENSION(6,6), INTENT(OUT) :: Q
    REAL(8), DIMENSION(6,6), INTENT(OUT) :: Gamma
    INTEGER :: LWORK, i, j
    REAL(8), DIMENSION(:), ALLOCATABLE :: WORK
    LOGICAL :: is_symmetric
    ! Check symmetry
    is_symmetric = .TRUE.
    DO i = 1, 6
      DO j = i + 1, 6
        IF (ABS(A(i,j) - A(j,i)) > 1.0D-12) THEN
          is_symmetric = .FALSE.
          EXIT
        END IF
      END DO
      IF (.NOT. is_symmetric) EXIT
    END DO
    IF (.NOT. is_symmetric) THEN
      WRITE(*,*) "Error: Matrix not symmetric"
      INFO = -1
      RETURN
    END IF
    ! LAPACK eigendecomposition
    LWORK = -1
    ALLOCATE(WORK(1))
    CALL DSYEV('V', 'U', 6, A, 6, W, WORK, LWORK, INFO)
    LWORK = INT(WORK(1))
    DEALLOCATE(WORK)
    ALLOCATE(WORK(LWORK))
    IF (INFO == 0) THEN
      Q = A
      Gamma = 0.0D0
      DO i = 1, 6
        Gamma(i,i) = W(i)
      END DO
    ELSE
      WRITE(*,*) "Eigendecomposition failed, INFO:", INFO
      Gamma = 0.0D0
    END IF
    DEALLOCATE(WORK)
  END SUBROUTINE compute_eigendecomposition
END SUBROUTINE UMAT
!*****************************BOTTOM*****************************
原始链接:https://github.com/mhasaninia/Hill48-Voce-UMAT/tree/main
HILL48 +各向同性Voce硬化umat子程序的图1
