基于大语言模型辅助的 SimLab 热流道网格压印自动化开发实践
实 践 对 象 模流分析软件 SimLab 热流道区域网格压印自动化
开 发 工 具 TRAE 编程智能体(承担代码实现)
完 成 时 间 2026 年 10 月 16 日起,历时 2 天
关 键 词 大语言模型;软件二次开发;模流分析;网格压印;自动化
归 档 记 录 原始记录 19 页演示文稿(含操作录屏)
摘要与关键词 1
Abstract 1
1 引言 1
2.3 预期收益 1
3 开发方法 1
4 结果 1
5 讨论 1
5.5 局限性 1
6 结论 1
参考文献 1
摘要
模流分析前处理中的网格局部加密操作长期依赖人工完成,存在重复度高、效率低、难以标准化的问题。本文以热流道区域网格压印这一典型场景为对象,报告了一次由工程技术人员主导、利用大语言模型(Large Language Model, LLM)辅助完成的软件二次开发实践。
实践经历了三个阶段:早期基于录制脚本的自主改造尝试、以通用对话式 AI 工具直接生成代码的尝试,以及引入专用编程智能体后以录制脚本为输入的迭代式开发。分析表明,前两次失败的共同原因在于缺乏对生成结果的验收能力,而非生成能力本身不足;第三次成功的关键在于以真实录制的操作脚本作为输入基线,使需求的表达从抽象描述转为可验证的参照。最终交付的脚本共 924 行,人工编写代码为 0 行,从工具安装到稳定运行历时 2 天,自动化后单次操作仅需 3 次人工点选。本文进一步提出三条可复用的方法论原则,用于指导工程领域内类似自动化任务的选题评估、输入准备与能力要求设定。
关键词:大语言模型;软件二次开发;模流分析;网格压印;自动化;零代码
Abstract
Mesh refinement operations in mold-flow pre-processing have long been performed manually, characterized by high repetitiveness, low efficiency, and poor standardization. This paper reports a software secondary-development practice led by an engineer and assisted by a Large Language Model (LLM), targeting the circular-mesh imprinting operation in hot-runner regions.
The practice comprised three stages: an early attempt at self-modifying a recorded script, an attempt to generate code directly through general-purpose conversational AI tools, and an iterative development approach using a dedicated coding agent with the recorded script as the input baseline.
Analysis shows that the two earlier failures shared a common cause — the absence of capability to validate generated output, rather than insufficient generation capability — whereas the third attempt succeeded because using a genuinely recorded operation script as input transformed requirement description from abstract instruction into verifiable reference.
The delivered script comprises 924 lines with zero lines hand-written, achieved in 2 days from tool installation to stable operation, and reduces the automated operation to 3 manual selections. Three reusable methodological principles are proposed for task selection, input preparation, and competency requirement definition in similar automation efforts within engineering domains.
Key words: Large Language Model; secondary development; mold-flow analysis; mesh imprinting; automation; zero-code
1 引言
模流分析(mold-flow analysis)的前处理阶段需要对浇注系统周边区域进行网格局部加密,以保证热流道附近的温度场与压力场具备足够的计算精度。在本文所用软件环境中,该操作通过“圆圈压印”功能实现:先在模型上选取热流道所在的面,再于该面上绘制圆形范围并执行压印,最后设定加密区域的网格尺寸。整个过程不包含任何工程判断,其操作序列在每一次执行中完全一致。
然而,该操作具备两个使其难以依靠人工消化的特征:一是单次操作耗时 1~3 min,一个项目往往包含多个热流道位置,累计耗时随位置数量线性增长;二是操作步骤分散在软件的多个功能入口,使用者需要反复在菜单与工具栏之间切换。上述特征使得该任务成为软件二次开发中优先级较高的自动化对象。
在通用意义上的“以脚本替代人工”讨论之外,本文关注一个更具体的问题:非编程背景的工程技术人员,在大语言模型辅助下完成此类二次开发时,其成败的决定因素是什么。围绕这一问题,本文完整记录了一次实践的三个阶段,分析两次失败与一次成功的共性与差异,并据此提炼可迁移的方法论。
本文的工作范围限定于单一商业模流软件的一个具体功能点,属工程实践报告而非受控对比实验。文中全部量化数据来自作者本人的测试记录,原始记录以演示文稿形式归档。
2 问题描述与自动化对象评估
本节对目标操作作形式化描述,并在此基础上给出自动化对象的筛选准则与预期收益模型。
2.1 目标操作的形式化描述
将单个热流道位置的网格压印过程表示为固定序列 S = ⟨s1, s2, s3, s4⟩:
• s1(选面):在模型上选中热流道所在的面;
• s2(画圆):按预设规则手动绘制圆圈范围;
• s3(压印):调用圆圈压印功能生成加密区域;
• s4(设定尺寸):输入加密区域网格尺寸并确认。
该序列具备三个性质:操作对象与操作顺序在项目之间不变;同一功能入口在不同项目中均可复用;执行过程中不含任何需要工程判断的决策环节。
2.2 自动化对象的筛选准则
基于上述性质,本文在启动开发前采用如下准则评估候选操作是否值得自动化:
判据:同一操作能否连续重复十次而无需任何决策。
该判据同时排除了两类不适合自动化的任务——规则不固定导致每次都需要重新判断的任务,以及单次执行耗时极短以致自动化收益不足以覆盖开发成本的任务。圆圈压印在两个维度上均满足要求,因而被确定为本次实践的目标对象。
2.3 预期收益
按项目典型热流道位置数量估算,原手工模式的总耗时为 Tmanual = n · t,其中 n 为位置数、t 为单次操作耗时(1~3 min)。自动化后预期总耗时为 Tauto = tsetup + k · tsel,其中 tsetup 为脚本启动开销,k 为单次运行所需的人工交互次数。这一预期在第 4 节的实测结果中得到验证。
3 开发方法
本次实践跨越三个阶段。各阶段在输入形态、人机分工与失败模式上存在系统性差异,构成了本文分析的核心对象。
3.1 三个阶段的总体设计
三个阶段的时间、工具形态、输入形态、人机分工与结果对照如表 1 所示。
表 1 三个阶段的总体设计与结果对照
阶段 |
时间 |
工具形态 |
输入形态 |
人机分工 |
结果 |
阶段一 |
早期 |
软件自带录制功能 |
录制脚本 |
人读懂并改写代码 |
失败 |
阶段二 |
2025 年 |
通用对话式 AI 工具 |
自然语言描述 |
人验收 AI 输出 |
失败 |
阶段三 |
2026 年 10 月 16 日起 |
专用编程智能体 |
录制脚本 + 自然语言 |
人描述需求与验收,AI 改写 |
成功 |
3.2 阶段一:录制脚本的自主改造
第一阶段的想法是利用软件自带的功能录制一段完整的压印操作,将得到的脚本改写为参数化工具。录制本身是成功的,所得脚本结构完整、可以执行。
改造的难点出现在将脚本重构为可复用工具的过程中。该重构要求使用者理解 Python 的类组织方式、异常处理机制与模块导入规则。测试者不具备相应的编程基础,数次尝试后放弃该路径,回归手工操作。
阶段结论:路径本身可行,失败原因在于不具备阅读与修改代码的能力,而非路径设计有误。
3.3 阶段二:通用对话式 AI 工具的代码生成
第二阶段转向通用对话式 AI 工具(如 DeepSeek、豆包),以自然语言描述需求,试图直接生成可运行的压印脚本。
该路径的失败模式与第一阶段不同:AI 能够输出代码,但输出结果的错误率较高,反复重试后仍难以直接运行。更关键的是,使用者无法判断输出结果的正确性——一旦报错,只能从头重来。
阶段结论:AI 具备生成代码的能力,但缺乏验收能力时,该能力无法转化为可用成果。
3.4 阶段三:以录制脚本为输入基线的迭代开发
第三阶段于 2026 年 10 月 16 日启动。方法上未做根本改变,仍是“描述需求、由 AI 改写”,但调整了三项关键设定。
设定一:以录制脚本为输入基线。 测试者先完成一次真实的压印操作并录制,将录制所得脚本连同自然语言描述一并提交给编程智能体。这一调整使需求表达从抽象描述转变为可验证的参照:AI 无需推测操作序列,测试者也无需在描述中穷举每一个界面细节。
设定二:放弃直接改写代码的尝试。 全程未打开代码编辑器,代码的编写与调试交由 AI 完成。测试者的职责收缩为问题描述与结果验收。
设定三:确保结果可当场验证。 压印后的网格形态是否符合预期、应选取何种类型的节点作为压印圆心,这些判断依赖模流分析领域的既有经验,可在运行后立即完成。判断依据因此完全来自使用者自身。
在此设定下,测试者于两天内完成全部工作,全程未人工修改一行代码。第二次尝试即基本可用。
3.5 零代码迭代流程
阶段三采用的迭代流程由五个环节构成,构成一轮;未跑通则重复第三、四环节,直至无需人工补位。
1. 录制操作脚本:录制一段真实的手工压印全过程,作为 AI 的输入基线;
2. 提交给 AI:将脚本与自然语言描述一并提交,说明改造目标;
3. 测试运行:实际执行脚本,暴露报错、选不中、顺序错误等问题;
4. 提示修正:以日常语言描述问题,由 AI 自行定位并修正;
5. 重复至成功:重复第三、四环节,直至无需人工介入。
第四环节是整个流程的关键。该环节对表达精度的要求低于编程要求——例如“完成后压一下圆圈网格”“自适应 Node、直接选节点坐标”等表述均不含代码术语。真正需要使用者投入的是把问题描述得足够具体,使 AI 能够定位到需要修改的位置。
4 结果
本节从交付成果的量化指标、脚本执行链路、需求迭代过程与最终交付形态四个方面,给出本次实践的实测结果。
4.1 交付成果的量化指标
表 2 交付成果的量化指标
指标 |
数值 |
说明 |
脚本总行数 |
924 行 |
从录制片段演化为可复用工具 |
人工手写代码 |
0 行 |
开发期间未修改代码 |
开发周期 |
2 天 |
从工具安装到稳定运行 |
自动化运行的人工交互 |
3 次点选 |
整条链路其余环节自动执行 |
原手工单次操作耗时 |
1~3 min |
选面、画圆、压印、设定尺寸 |
以项目含 5 个热流道位置为例,原手工模式总耗时为 5~15 min,自动化后为一次脚本运行加 3 次点选,量级差异明显。
4.2 脚本执行链路
最终脚本的执行链路包含六个环节,其中仅三个需要人工交互。
表 3 脚本执行链路与交互方式
步骤 |
动作 |
交互方式 |
01 |
运行脚本 |
人工点选 |
02 |
弹窗提示选择面 |
人工点选 |
03 |
弹窗提示选择节点 |
人工点选 |
04 |
自动压印圆圈网格 |
自动执行 |
05 |
弹窗提示重划分网格尺寸 |
人工点选 |
06 |
网格重划分结束 |
自动执行 |
第三步的节点选择支持两类输入:手动创建的孤立节点(分析前单独建点,用于定位压印圆心)与模型上已存在的网格节点(直接选取现成坐标)。脚本通过官方 API 自动判定节点类型,操作者按提示点选即可。
实现上遵循两项原则:其一,仅在需要工程判断的环节引入弹窗交互,其余环节全部自动执行;其二,每一步输出日志,可在软件窗口中查看执行进度,API 调用失败时回退 tkinter 界面,不中断主流程。
4.3 需求迭代过程
功能并非一次成型。开发过程中共完成四轮需求迭代,每轮均在实际运行验证通过后才提出下一轮。
表 4 需求迭代过程与验证结果
版本 |
目标 |
需求内容 |
验证结果 |
V1 |
能跑 |
将“网格节点”与“孤立节点”各写一份独立脚本 |
两个脚本分别运行均正常,先确认可执行性 |
V2 |
一次判断 |
合并为一份脚本,中间由人工确认节点类型 |
合并后运行正常;统一调用入口,以一次人工确认换取可维护性 |
V3 |
零判断 |
不再人工确认,由脚本自动判定节点类型 |
自动识别后运行正常,操作者无需理解类型判定逻辑 |
V4 |
零门槛 |
封装为软件菜单项与工具栏按钮 |
无需查找脚本文件、无需记忆参数,可直接投入使用 |
该迭代序列呈现出清晰的递进逻辑:从“可执行”到“少交互”再到“无需理解内部逻辑”,每一轮的改造目标均由上一轮的实际运行结果引出。需求由使用者拆分并描述,代码由 AI 修改,每轮以实际运行结果作为验收依据。
4.4 最终形态与成果分发
最终交付形态为软件内置功能:菜单栏新增“SimLab 二次开发工具集”作为统一入口,工具栏新增“热进浇点”按钮实现一键直达。使用者无需知道脚本的存在,即可完成调用。
在此基础上,成果进一步被打包为单个安装程序(EXE)。二次开发功能与其依赖脚本一并封装,接收方双击安装程序即按提示完成安装,无需配置 Python 环境或依赖库;在未安装过该功能的计算机上,双击 EXE 即可完成装入并直接调用。
该步骤的意义在于将成果的适用范围从“作者本地可用”扩展为“他人可用”。自动化工具的价值往往在其交付分发时才充分兑现——因为工具的真正成本不在于开发,而在于使用者的接入门槛。
5 讨论
本节对三个阶段的结果作归因分析,说明输入基线与能力要求各自的作用,并据此提炼可迁移的方法论原则与适用边界。
5.1 两次失败的共性归因
阶段一与阶段二的失败原因表面上不同:前者需要理解代码而测试者不具备该能力,后者能够获得代码却无法判断其对错。合并考察后可归并为同一判断:两次失败均发生在“验收能力缺失”这一环节,而非“生成能力不足”这一环节。
阶段一中,脚本由测试者自行录制并改造,问题出在改造所需的编程能力;阶段二中,代码由 AI 生成,问题出在判断结果正确性的能力。两次尝试都要求测试者同时承担“实现”与“验证”两项超出其能力范围的任务。而在阶段三中,实现任务被完整地移交给 AI,测试者仅保留验证任务——而验证恰好是领域经验可以直接支撑的部分。
这一解释与阶段三的实测结果一致:同一使用者、同一操作对象、同一软件环境,仅调整人机分工方式即改变了结果。
5.2 输入基线的决定性作用
阶段三相对前两次的另一个关键差异在于输入形态。阶段二以自然语言为唯一输入,AI 须依靠推测重建操作序列,任何对界面细节的误判都会导致生成结果不可用;阶段三以真实录制的脚本为输入基线,AI 面对的是已验证可执行的参照物,需求表达则退化为对该参照物的改造说明。
这一差异可推广表述为:当工程操作本身可以被录制时,录制结果比语言描述更精确、更廉价、也更易于验收。语言描述需要使用者具备将隐性经验显性化的能力,而录制则直接捕获了已发生的操作。
5.3 工程人员能力要求的重新定位
本文实践所依赖的核心能力并非编程能力,而是结果判断能力。具体而言,包括:判断应选取何种类型的节点作为压印圆心、判断压印后生成的网格形态是否符合预期、判断脚本的自动化边界是否合理。
这些判断无法由 AI 替代,因为它们依赖对模流分析对象与数值计算结果的领域理解。AI 在本次实践中承担的是代码实现工作,而全部工程决策仍由人完成。
由此可以提出一个关于效率来源的判断:本次实践获得的效率提升,其来源是需求描述与持续反馈,而非编程能力本身。该路径不要求编码能力,但要求能够判断输出是否符合预期。
5.4 方法论提炼
综合三个阶段的经验,可提炼出三条可复用的原则。
原则一:优先选择规则明确、重复度高的操作。 判断标准为同一操作能否连续重复十次而无需决策。本例的圆圈压印满足该条件。
原则二:以录制的真实操作为起点。 前两次失败与第三次成功的差别主要在此。口头描述需求只能由 AI 推测;以录制脚本为输入,起点明确,首次尝试即接近可用。
原则三:结果判断能力比编码能力更关键。 起作用的是领域经验形成的判断力。代码由 AI 编写,判断仍由人完成。
5.5 局限性
本文报告的是单一软件、单一功能点上的个人实践,存在以下局限:其一,样本量为 1,所得结论的普适性有待更多案例检验,尤其缺少与专业开发者路径的对照数据;其二,各项耗时数据为作者自行记录,未采用仪器化计时;其三,脚本在作者所用环境与版本下验证,其他版本或环境下的适用性未作考察;其四,本文不涉及代码质量的工程评价维度,924 行的规模是否适合长期维护尚无判断依据。
6 结论
本文报告了一次非编程背景工程技术人员主导、由大语言模型辅助完成的模流分析软件二次开发实践。实践历时 2 天,交付脚本 924 行,人工编写代码 0 行,自动化后单次操作仅需 3 次人工点选。
实践表明,此类任务的成败决定因素并非 AI 的代码生成能力,而是两项被分离出来的工作:能否为 AI 提供可验证的输入基线,以及能否对输出结果作出专业判断。据此,本文提出以录制操作为输入基线、以结果判断能力为核心要求的开发范式,并给出用于筛选自动化对象、准备输入与设定能力要求的三条原则。
对工程领域而言,这一实践的意义不在于“AI 可以写代码”,而在于它重新划定了工程人员与技术实现的分工边界:AI 承担实现,工程师承担判断。对模具与模流这类领域经验密集、规则相对固定的工作,该分工具有现实可行性。
参考文献
1. Python Software Foundation. Python documentation: tkinter — GUI programming[EB/OL].
2. SimLab. SimLab 官方帮助文档:网格操作与脚本接口说明[EB/OL].
3. TRAE. TRAE 编程智能体产品文档[EB/OL].
4. 中华人民共和国国家质量监督检验检疫总局, 中国国家标准化管理委员会. 信息与文献 参考文献著录规则: GB/T 7714—2015[S]. 北京: 中国标准出版社, 2015.
附录 A 试验记录摘要
本附录汇总正文引用的实测数据,原始记录以演示文稿形式归档,共 19 页,含操作录屏。
表 A.1 试验记录摘要
记录项 |
数据 |
开发工具 |
TRAE 编程智能体 |
起始日期 |
2026 年 10 月 16 日 |
结束状态 |
2 天跑通,脚本稳定运行 |
脚本规模 |
924 行 |
人工手写 |
0 行 |
原手工单次耗时 |
1~3 min / 位置 |
自动化后人工交互 |
3 次点选 / 次运行 |
迭代轮次 |
4 轮(V1 至 V4) |
失败路径 |
2 次(录制脚本自主改造、通用对话式 AI 直接生成) |
交付形态 |
菜单项 + 工具栏按钮 + 单文件 EXE 安装包 |
评论0
