I-DEAS 12M2 LIC破解文件!
浏览:146990 评论:5
SERVER this_host ANY 27000
DAEMON uglmd
PACKAGE IDEAS uglmd 22.000 0945D1985481 COMPONENTS="dotnet_runtime \
features_modeling gateway iges nx_material_system pstudio_cons \
pv_ugdatagenerator sla_3d_systems solid_modeling \
ug_collaborate ug_smart_models ugopen_menuscript nx_freeform_1 \
nx_freeform_2 assemblies mechanisms motion_kin geometric_tol \
nx_response_anlys nx_adv_durability id_durability \
nx_lam_composites" ck=58 SIGN=02FDAAD26F0E
PACKAGE TEST uglmd 22.000 63CDB1CC0EB9 COMPONENTS="Correlation \
NoisePathAnalysis StructuralModification ClosedLoopControl \
OrderTracking AcousticIntensityMeasurements Fatigue CORDS \
VoldKalmanFiltering MeasurementsHP3565 MeasurementsHPVXIE1431 \
MeasurementsHPVXIE1432 NI4472MeasurementDriver \
ZonicbookMeasurementDriver ABAQUS_Importer ANSYS_Importer \
NASTRAN_Importer SineTrackingMeasurements \
SineTrackingPostprocessing HEIM480MeasurementDriver \
SonyMeasurementDriver TEACMeasurementDriver \
HEIM160MeasurementDriver VBOI BASE_TEST TestGeometry \
TimeProcessing OrderSlicing BasicModal AdvancedModal \
StationaryProcessing TransientProcessing ChannelLimit \
SineProcessing VXI_BaseDriver Sony_EX_BaseDriver \
Heim_A480_BaseDriver NI_BaseDriver SourceOption TachOption \
ThroughputOption MultipleMainframe CANBUS StrainOption \
TapeOption FEC_NastranUpdating FE_CalibratorBase FEC_Shape \
FEC_FRF PretestAnalysis MatlabBasicInterface" ck=174 \
SIGN=C422413ABB38
PACKAGE TRANSLATORS uglmd 22.000 21CFF9996B88 \
COMPONENTS="id_catia_sa_trans id_cadds5_trans \
id_ug_stndalon_trans id_proe_trans id_catia_sa_trans \
id_nissan_trans" ck=134 SIGN=47B536B4FB94
PACKAGE MFG uglmd 22.000 CC95A68492B1 COMPONENTS="assemblies cam_base \
cavity_milling drafting dxf_to_ug dxfdwg features_modeling \
fix_axis_surf_mill flow_cut free_form_modeling gateway \
graphical_tool_path grip_execute iges nc_external_program \
planar_milling pv_ugdatagenerator sequential_milling shop_doc \
solid_modeling std_ug_library step_ap203 step_ap214 \
surface_milling tol_cavity_milling ufunc_execute \
ug_collaborate ug_post_exe ug_smart_models ug_to_dxf \
ug_to_vericut ug_visualize var_axis_surf_mill" ck=73 \
SIGN=13283F82BC02
PACKAGE UGS1 uglmd 22.000 821C78CF5FAF COMPONENTS="gateway \
3d_to_2d_flattener adv_ug_library adv_turning assemblies \
adv_assemblies adv_sheet_metal_dsgn cam_facets cam_base \
cam_dialogs cam_uif cavity_milling contour_profile \
design_optimization curved_flat_pattern c4x \
cutting_optimization die_face_design die_engineering drafting \
drive_curve_lathe fix_axis_surf_mill free_form_modeling \
features_modeling facing_milling flow_cut foreign_geometry \
flat_patterns grip_execute prog_die_wizard kanji_characters \
jama_customization lathe multi_part_gridding material_removal \
graphical_tool_path milling_express nx_sheet_metal \
nurb_output_enabler nc_external_program prt_cfg_asst \
proc_pt_asst planar_milling ug_body_design ug_prod_des_advisor \
ug_emboss ug_mfg_advisor ug_isv_full ug_isv_basic \
ug_opt_wizard ug_var_axis_profile ug_smart_models \
ug_holemaking ug_comp_flattener ug_healing ug_feature_rec \
ug_tool_boring ug_post_kinematics ugweld ug_visualize \
ug_turning ug_post_adv_bldr ug_post_mill ug_mold_design \
ugopen_plus_plus ug_to_vericut ug_post_lathe ufunc_execute \
ug_post_exe ugfast ugopen_menuscript shops_shell shops_design \
shops_ff swarf_cutting surface_milling solid_modeling \
sequential_milling shops_die_mold thread_milling shop_doc \
unc_mill_simulation unc_lathe_simulation wave \
wire_edm_machining shops_docs shops_die_mold surfseg \
sheet_metal_nesting sheet_metal_fab tol_cavity_milling visual \
var_axis_surf_mill usr_defined_features sheet_metal" ck=199 \
SIGN=0CDBC4D281EA
PACKAGE UGS2 uglmd 22.000 35B6F4005E6B COMPONENTS="gateway \
auto_solid_meshing ansys_meshers adv_gear_wizard adv_routing \
cattoug casting_wizard cmold composites clear_analysis_cons \
composites_exp ds_studio dxfdwg design_studio dfx_to_ug \
direct_geometry door_des_wizard edf nx_general_packaging \
internal dmu_partitioned_hlr grip_development gfem gear_wizard \
gfem_postprocessor gfem_nastran gfem_ansys geometric_tol \
gm_proprietary interleaf_if iges icad_interface icad mold_flow \
mold_flow_interface motion_kin motion_dyn mm_assembly_stackup \
mf_mold_advisor metris moldiq moldflow_ppa \
moldware_manufacture moldware_integrated moldware_design \
mechanisms mechanisms_batch mesh_list_element mf_mold_advisor \
nx_freeform_1 nx_posture nx_jacktkapi nx_advfem nx2d_autocad \
nx2d_cadam nx2d_plotting nx_2d_iges nx2d_dxf nx_freeform_2 \
nx_advfem pfea_static_modal pstudio_cons proetoug \
pv_ugdatagenerator ug_checkmate ug_human ug_expr_manager \
ug_composites ug_process_aid ug_model_quality_ck \
ug_comp_pipeline ug_cadam ug_packs ug_3d_minmax \
ug_vibration_wizard ug_kp ug_kf_execute ug_kf_author \
ug_remote_ui ug_ipw ug_kf_feature ug_quick_stack" ck=143 \
SIGN=448CA3EEA82E
PACKAGE UGS3 uglmd 22.000 2294BC081904 COMPONENTS="gateway \
c_p_p_author c_p_p_runtime mold_lib_1 mold_lib_2 mold_lib_3 \
mold_lib_4 mold_lib_5 mold_lib_6 mold_lib_7 mold_lib_8 \
mold_lib_9 mold_lib_10 mold_lib_11 mold_lib_12 ot_pub_markup \
pstudio_auth_cae pstudio_auth pipemaster punchpress_optimize \
punchpress punch_optimization ug_fast ug_kf_new_geom \
ug_kf_interop ug_kf_checker ug_vki_meshers ug_strength_wizard \
ug_die_design ug_nx_2d ug_pcb_exchange ug_pcb_modeler \
ug_kf_airfoil_band ug_alm ug_maya_exchange ug_maya_modeler \
ug_pv_interop ug_library_genius ug_shapescan ug_epak \
routing_combined routing_electrical routing_mechanical \
routing_hvac routing_flex_hose routing_steelwork \
routing_wiring routing_raceway routing_conduit routing_tubing \
routing_piping routing_base routing_isogen ufunc_development \
vda_4955_checker vda_fs_tanslator vcheck ug_to_dfx ug_rasna \
ug_schematics ugmx_api_development ugmx_api_runtime \
ugmx_drafting ugmx_dxf ugmx_iges ugmx_para_design \
ug_composites_exp ug_kf_designer qs_translator qs_package \
qs_pack qs_inspection qs_iges_to_polys qs_dyn_temp qs_des4mfg \
quickshape ug_data_pipeline ug_kf_update ugremarx scstrp \
sheet_metal_die_eng sheet_metal_design ug_composites_step \
ug_composites_iges" ck=57 SIGN=12A8661EA0EA
PACKAGE UGS4 uglmd 22.000 9EF9D590DC72 COMPONENTS="gateway \
dcade_stamping_usr dotnet_author dotnet_runtime \
genius_4000_machine genius_4000_stock genius_4000_api \
genius_4000_nc_prog genius_4000_tool genius_4000_base \
genius_4000_fixture genius_4000_access genius_4000_fsm \
kab_centric kbe_udo_object ug_1 ug_2 ug_3 ug_4 ug_5 ug_6 ug_7 \
ug_8 ug_9 ug_10 pv_collaborate pv_conference pv_configure \
pv_configure_a pv_configure_b pv_fly pv_frame pv_iges \
pv_iges_translator pv_interfere pv_measure pv_mockup \
pv_network pv_pe_consumer pv_pe_reviewer pv_section \
pv_seq_create pv_sequence pv_step pv_step_translator pv_stl \
pv_stl_translator pv_view pv_vispro pv_visualizer pv_vrml \
pv_vrml_translator tceng_auto_edition tceng_gm_overlay \
tceng_auto_edition visview_base visview_mockup visview_pro \
visview_std ug_struct_pe_solver ug_collaborate \
ug_library_fixtures ug_studio ug_aml ug_advfem ug_photo \
ui_styler ug_scenario ug_reality ug_fly_through ug_web_express \
shapescan studio_visualize studio_analyze studio_free_form \
std_ug_library studio_render simulation step_ap214 step_ap203 \
sla_3d_systems single_geometry wiring_harness" ck=149 \
SIGN=A71AADEAF8B8
INCREMENT IDEAS uglmd 22.000 permanent 999 B7796ED89286 SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=151 SIGN=7DA6DE081F68
INCREMENT TEST uglmd 22.000 permanent 999 75F328B14D32 SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=61 SIGN=A6F95D64F514
INCREMENT TRANSLATORS uglmd 22.000 permanent 999 C92487480967 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=58 \
SIGN=90578DFA6356
INCREMENT MFG uglmd 22.000 permanent 10 2A722D64D9BB SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=125 SIGN=E8D4BC461128
INCREMENT UGS1 uglmd 22.00000 permanent 999 E699BA5CBAD9 SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=172 SIGN=31B0F9BC201C
INCREMENT UGS2 uglmd 22.00000 permanent 999 68740DA17005 SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=97 SIGN=0DF467A43BF2
INCREMENT UGS3 uglmd 22.00000 permanent 999 51C50CBE6E09 SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=107 SIGN=1B220CC040EA
INCREMENT UGS4 uglmd 22.00000 permanent 999 19E8972BB4CD SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=148 SIGN=A6BD6F587F94
INCREMENT gateway uglmd 22.000 permanent 999 FEB06F633CDD SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=174 SIGN=F0E97E982132
INCREMENT iman_consumer uglmd 22.000 permanent 999 9EAF74ADCE77 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=239 \
SIGN=C11210F46938
INCREMENT iman_author uglmd 22.000 permanent 999 3DE539564939 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=145 \
SIGN=A0B9AD7C979E
INCREMENT iman_web_server uglmd 22.000 permanent 999 9EDE472FF525 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=152 \
SIGN=17328338939A
INCREMENT iman_server uglmd 22.000 permanent 999 0DFCEB3E836B \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=119 \
SIGN=6BEDECF695C2
INCREMENT iman_qpl_usr uglmd 22.000 permanent 999 6F09BD4985BD \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=167 \
SIGN=4F265DA82A12
INCREMENT iman_qpl_srvr uglmd 22.000 permanent 999 01403C278450 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=49 \
SIGN=56FC2CCCD284
INCREMENT iman_inclass_usr uglmd 22.000 permanent 999 B08BA8432806 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=80 \
SIGN=32B7F9D6446C
INCREMENT iman_inclass_srv uglmd 22.000 permanent 999 192BC727684D \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=55 \
SIGN=8123BC485304
INCREMENT iman_proe_manager uglmd 22.000 permanent 999 DE311DEAAD9B \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=174 \
SIGN=0D1AF8D694D0
INCREMENT iman_proe uglmd 22.000 permanent 999 6D26EF20D021 SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=88 SIGN=39B8A33E1292
INCREMENT iman_adv_cm_client uglmd 22.000 permanent 999 2D05E2C6782F \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=88 \
SIGN=A4DA6BCEF2E8
INCREMENT iman_adv_cm_server uglmd 22.000 permanent 999 D562E3B6EC7D \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=113 \
SIGN=57C4CEEC59AA
INCREMENT iman_solidedge_mgr uglmd 22.000 permanent 999 573C3EC1E8F7 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=142 \
SIGN=F2A239D42900
INCREMENT iman_solidedge uglmd 22.000 permanent 999 6D2EF240D093 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=130 \
SIGN=CB7C5CEA0A60
INCREMENT iman_mfg_struct_vwr uglmd 22.000 permanent 10 B0CA2FB0662E \
SIGN=E8431BD8F0A6
INCREMENT iman_emp_connect uglmd 22.000 permanent 999 0587F7A2A6A9 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=156 \
SIGN=DE0BCB96B67A
INCREMENT iman_cc_editor_usr uglmd 22.000 permanent 10 8672637A2F1C \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=118 \
SIGN=765CE1A4E1CE
INCREMENT iman_webdav_server uglmd 22.000 permanent 999 42432FF92B6B \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=122 \
SIGN=9A880BB05EF4
INCREMENT iman_adv_eintegrator uglmd 22.000 permanent 999 \
195DBCCA9F4D SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=198 \
SIGN=CD020320BD2E
INCREMENT iman_cam_mgr_ext uglmd 22.000 permanent 999 27E0C4E7DF88 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=109 \
SIGN=E9A061F80616
INCREMENT iman_rdv_client uglmd 22.000 permanent 999 0DCB15ABA0B9 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=124 \
SIGN=E0DA238223E4
INCREMENT iman_rdv_server uglmd 22.000 permanent 999 7C9770E55531 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=89 \
SIGN=32CC37E43D66
INCREMENT iman_solidworks_mgr uglmd 22.000 permanent 999 6266130B28E4 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=73 \
SIGN=6B0C20740830
INCREMENT iman_solidworks uglmd 22.000 permanent 999 C91B057E2825 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=105 \
SIGN=EEF5B454D89E
INCREMENT iman_propdm_dmu uglmd 22.000 permanent 999 669BA2E5F4D2 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=175 \
SIGN=7EBD79C2E030
INCREMENT iman_prointralnk_dmu uglmd 22.000 permanent 999 \
E5CA155A40F3 SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=88 \
SIGN=D509FDC619C2
INCREMENT iman_ideas uglmd 22.000 permanent 999 5D653182F17B \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=65 \
SIGN=1A17106A8BE2
INCREMENT iman_dominodco uglmd 22.000 permanent 999 9EACF310E73F \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=184 \
SIGN=D49BF28A26E6
INCREMENT iman_dominodoc uglmd 22.000 permanent 999 FD683B5C431B \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=160 \
SIGN=C0AC25B21038
INCREMENT iman_documentun uglmd 22.000 permanent 999 7F9EE2FBD6BD \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=190 \
SIGN=500B83F4B044
INCREMENT iman_dm_srvr_ext uglmd 22.000 permanent 999 6C141EB06CCE \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=140 \
SIGN=02528A963762
INCREMENT iman_p3r_acc_user uglmd 22.000 permanent 999 0B2F06A030E1 \
SIGN=4492450EAE0A
INCREMENT iman_res_mgr_user uglmd 22.000 permanent 999 1C448A86FDEB \
SIGN=6EFCF1C4B5CA
INCREMENT iman_proc_plnr_user uglmd 22.000 permanent 999 7DC2750E7DAF \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=100 \
SIGN=2FAB911E9336
INCREMENT iman_wpp_intf uglmd 22.000 permanent 999 271956A76A4A \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=67 \
SIGN=2AFE27ECA30C
INCREMENT iman_wpp_user uglmd 22.000 permanent 999 815073C0E6E3 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=72 \
SIGN=87E7E228C0B4
INCREMENT iman_fcad_intf uglmd 22.000 permanent 999 3A189A6B385E \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=101 \
SIGN=656A2024913C
INCREMENT iman_tcm_xsrv_ext uglmd 22.000 permanent 999 65F335F1C1C2 \
SIGN=79132E9A9408
INCREMENT iman_workflow uglmd 22.000 permanent 999 4FABD549CB09 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=181 \
SIGN=13A410BED2D4
INCREMENT iman_psm uglmd 22.000 permanent 999 8BBE28777B22 SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=82 SIGN=8EF36EC61990
INCREMENT iman_iview uglmd 22.000 permanent 999 EF020F1ED9B1 \
SIGN=BD43CCBC51F2
INCREMENT iman_1 uglmd 22.000 permanent 999 1B318D91A656 SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=93 SIGN=8AF31528DA80
INCREMENT iman_2 uglmd 22.000 permanent 999 DB25087A2DA1 SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=119 SIGN=30DAE374BA2E
INCREMENT iman_3 uglmd 22.000 permanent 999 13207BBFA8E8 SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=126 SIGN=C66668EA2A88
INCREMENT iman_ uglmd 22.000 permanent 999 FA6A9BE9EB5F SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=167 SIGN=316602FC06C2
INCREMENT iman_4 uglmd 22.000 permanent 999 61092678D783 SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=69 SIGN=FB6C3B00221E
INCREMENT iman_5 uglmd 22.000 permanent 999 0365A16D5A12 SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=91 SIGN=D8317FEC847A
INCREMENT iman_6 uglmd 22.000 permanent 999 F5DBACE6A19D SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=194 SIGN=09446E829514
INCREMENT iman_7 uglmd 22.000 permanent 999 2BFF7FABDC64 SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=170 SIGN=9B971D649074
INCREMENT iman_8 uglmd 22.000 permanent 999 831DFA04EBAF SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=124 SIGN=FD6D6DDAE642
INCREMENT iman_9 uglmd 22.000 permanent 999 76CA05E9DE7E SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=129 SIGN=DC7A9A4622B0
INCREMENT iman_10 uglmd 22.000 permanent 999 BB828B863A8B SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=138 SIGN=2F6E2E7CEE38
INCREMENT iman_11 uglmd 22.000 permanent 999 97568E7826AA SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=146 SIGN=35A188DA4664
INCREMENT iman_12 uglmd 22.000 permanent 999 975E8D7A2AAD SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=153 SIGN=E89BD1BE837C
INCREMENT iman_13 uglmd 22.000 permanent 999 CAEB887CBE0C SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=189 SIGN=5C8F7952F1C8
INCREMENT iman_14 uglmd 22.000 permanent 999 87B8A75E2AFF SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=174 SIGN=B6BE31FA9118
INCREMENT iman_15 uglmd 22.000 permanent 999 67CCAA6036FE SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=145 SIGN=E7C5ED0C14AA
INCREMENT iman_16 uglmd 22.000 permanent 999 67C4A9622A01 SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=89 SIGN=73821C36CC0A
INCREMENT iman_17 uglmd 22.000 permanent 999 8CACA4443E00 SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=146 SIGN=F8AEABA682F6
INCREMENT iman_18 uglmd 22.000 permanent 999 56A4F3562A23 SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=87 SIGN=8CE54362A428
INCREMENT iman_19 uglmd 22.000 permanent 999 3A9DF6283602 SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=104 SIGN=67A68592223C
INCREMENT iman_20 uglmd 22.000 permanent 999 6B8FA45B2B00 SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=113 SIGN=4CEE49C473A6
INCREMENT iman_21 uglmd 22.000 permanent 999 A89BA1613305 SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=79 SIGN=DCBABF787E9C
INCREMENT iman_22 uglmd 22.000 permanent 999 908F9E3F3B02 SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=115 SIGN=5D29E1DAA66E
INCREMENT iman_23 uglmd 22.000 permanent 999 8098A3253BFF SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=134 SIGN=267DC0CC3D32
INCREMENT iman_24 uglmd 22.000 permanent 999 9B4188732BAC SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=143 SIGN=69D4838ADB2C
INCREMENT iman_25 uglmd 22.000 permanent 999 D335856923B1 SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=110 SIGN=8FDD15127114
INCREMENT iman_26 uglmd 22.000 permanent 999 ACB6A277BBEE SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=165 SIGN=AC3FAE409C56
INCREMENT iman_27 uglmd 22.000 permanent 999 AED1877DBB0B SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=168 SIGN=F6AF2EE00634
INCREMENT iman_28 uglmd 22.000 permanent 999 AD524C6B3BD8 SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=142 SIGN=218F7D2AA07A
INCREMENT iman_29 uglmd 22.000 permanent 999 C53E697123BD SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=116 SIGN=FF1FF4FCE28A
INCREMENT iman_30 uglmd 22.000 permanent 999 E23D1198D861 SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=62 SIGN=4F6EB4ECC754
INCREMENT iman_pv_viewer_pro uglmd 22.000 permanent 999 7FAB1F936EE8 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=177 \
SIGN=CD106B66A770
INCREMENT iman_pv_viewer_base uglmd 22.000 permanent 999 CB5C2E0321A4 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=102 \
SIGN=F8FB8C9ED61C
INCREMENT iman_pv_viewer_adv uglmd 22.000 permanent 999 A62FAE40B24A \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=95 \
SIGN=8E4C590080FA
INCREMENT iman_pv_moratorium uglmd 22.000 permanent 999 215418A11DA6 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=7 \
SIGN=356C0F18572A
INCREMENT iman_image_services uglmd 22.000 permanent 999 63C1B5F699FE \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=129 \
SIGN=0B23F74C9A66
INCREMENT iman_lotus uglmd 22.000 permanent 999 98A18DB43B45 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=110 \
SIGN=5FBBCB1C81C6
INCREMENT iman_oracle uglmd 22.000 permanent 999 AD83C03CFFC7 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=164 \
SIGN=A2DBFB4A0040
INCREMENT iman_sap uglmd 22.000 permanent 999 4035B15D5FF7 SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=91 SIGN=9F49896486A6
INCREMENT iman_mentor_graphics uglmd 22.000 permanent 999 \
5F45FF709789 SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=120 \
SIGN=DDF89400C7E8
INCREMENT iman_catia uglmd 22.000 permanent 999 2C2F18E1885E \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=139 \
SIGN=1B5ABEC032B2
INCREMENT iman_autocad uglmd 22.000 permanent 999 D6AC2EC8B947 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=143 \
SIGN=8F7FD17806F6
INCREMENT iman_browser uglmd 22.000 permanent 999 EB99F8999E5B \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=197 \
SIGN=683B6FFC2A3C
INCREMENT iman_document uglmd 22.000 permanent 999 448E5CE6EB3F \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=125 \
SIGN=E2CC655E8E3A
INCREMENT iman_erp_interface uglmd 22.000 permanent 999 63E77CF53FBF \
SIGN=489DEE228014
INCREMENT iman_step uglmd 22.000 permanent 999 B651CF4DDD9E SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=207 SIGN=6EDC7DB63864
INCREMENT iman_step_ap214 uglmd 22.000 permanent 999 2743688FC1A0 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=127 \
SIGN=953C360AAE7A
INCREMENT iman_step_ap203 uglmd 22.000 permanent 999 0F07C69A321E \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=155 \
SIGN=BC64973295F0
INCREMENT iman_distributed_usr uglmd 22.000 permanent 999 \
A2D8831B565A SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=49 \
SIGN=2C77AED6228E
INCREMENT iman_distributed_srv uglmd 22.000 permanent 999 \
DF1D1F0F5A57 SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=163 \
SIGN=FC722364A594
INCREMENT iman_hockup_api uglmd 22.000 permanent 999 DBE7D86F2976 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=158 \
SIGN=103569920D16
INCREMENT iman_markup_workstn uglmd 22.000 permanent 999 44BDDE253CA9 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=137 \
SIGN=129853788068
INCREMENT iman_workstation uglmd 22.000 permanent 999 BEE658B7189A \
SIGN=145D3E5ADCA4
INCREMENT iman_markup_pc uglmd 22.000 permanent 999 7FE988DF8503 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=161 \
SIGN=127B45103E50
INCREMENT iman_x_terminal uglmd 22.000 permanent 999 AFC07805E850 \
SIGN=F7DA9C169CD2
INCREMENT iman_report_user uglmd 22.000 permanent 999 E190E59EED75 \
SIGN=ADD01EEC1290
INCREMENT iman_report_writer uglmd 22.000 permanent 999 641CFC79C089 \
SIGN=F5235A207BD8
INCREMENT iman_ug uglmd 22.000 permanent 999 AA3CD8787A0C SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=133 SIGN=60DBD02611D4
INCREMENT iman_nth uglmd 22.000 permanent 999 7D6D8F42EC29 SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=62 SIGN=DD5377EEC5E0
INCREMENT iman_1st uglmd 22.000 permanent 999 1CEE4DAFD16F SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=161 SIGN=A00A637A7A24
INCREMENT iman_rtk uglmd 22.000 permanent 999 E9CDD1DD0D8F SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=145 SIGN=DBD4949E7B62
INCREMENT iman_dtk uglmd 22.000 permanent 999 025F276F2725 SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=67 SIGN=28F8B5E85AE8
INCREMENT iman_acm uglmd 22.000 permanent 999 8FE8DB984C89 SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=127 SIGN=136C6022101A
INCREMENT iman_hetero uglmd 22.000 permanent 999 C3E0544253B3 \
SIGN=61C911245FA2
INCREMENT iman_mac uglmd 22.000 permanent 999 E8A9597E76C7 SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=141 SIGN=5F37E9BAD2C0
INCREMENT iman_pc uglmd 22.000 permanent 999 6E33194B85CD SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=108 SIGN=B040E2088BE8
INCREMENT iman_ug_manager uglmd 22.000 permanent 999 FFFDDE8352FE \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=128 \
SIGN=653035906830
INCREMENT iman_design_context uglmd 22.000 permanent 999 95656F32FA71 \
SIGN=3E48CAF2A1AC
INCREMENT iman_reviewer uglmd 22.000 permanent 999 3460F44E4E5F \
SIGN=C738E2C63960
INCREMENT iman_myriad uglmd 22.000 permanent 999 E766EAF2833D \
SIGN=B3A4677C4BB6
INCREMENT iman_altris uglmd 22.000 permanent 999 02C63EED49C7 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=159 \
SIGN=B473673EFB88
INCREMENT iman_web_author uglmd 22.000 permanent 999 5EBF3D0FF9D5 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=141 \
SIGN=1E9A74AA2AA4
INCREMENT iman_dm_server_ext uglmd 22.000 permanent 999 B335934A7D02 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=108 \
SIGN=07A16D221E86
INCREMENT iman_genealogy_client uglmd 22.000 permanent 999 \
D6AA4E8C8B73 SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=108 \
SIGN=04F59DCA732A
INCREMENT iman_genealogy_server uglmd 22.000 permanent 999 \
92736411E91C SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=106 \
SIGN=2245592E899E
INCREMENT iman_webserver uglmd 22.000 permanent 999 74DE570B52CE \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=131 \
SIGN=95AF50882B94
INCREMENT pv_portal_mkp uglmd 22.000 permanent 999 020A28E85761 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=86 \
SIGN=4A8665E44792
INCREMENT pv_portal_std uglmd 22.000 permanent 999 EC7667C3B387 \
SIGN=364212AAFA76
INCREMENT nx_masterfem uglmd 22.000 permanent 999 9E97D40E5503 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=117 \
SIGN=C90F38282D4C
INCREMENT nx_design_sim uglmd 22.000 permanent 999 5CE0F8F89101 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=123 \
SIGN=30EDFCB4DA70
INCREMENT proenx uglmd 22.000 permanent 999 46D8D7F70D8B SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=144 SIGN=97CEB1FA9588
INCREMENT nx_electrode_wizard uglmd 22.000 permanent 999 7219692E272A \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=64 \
SIGN=AB54EAB2CAB4
INCREMENT catv5_nx uglmd 22.000 permanent 999 B74B548DDF2D SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=171 SIGN=072B923402BC
INCREMENT nx_ship_concept uglmd 22.000 permanent 999 D56B79D19CD2 \
SIGN=B98D7BEE0A2A
INCREMENT aero_sheet_metal uglmd 22.000 permanent 999 8ABBD5FCC6E3 \
SIGN=C71759EA489E
INCREMENT nx_thermal_solver uglmd 22.000 permanent 999 13EA86F934E2 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=94 \
SIGN=5D81A65A4BDA
INCREMENT nx_space_therm_solv uglmd 22.000 permanent 999 A80DC0C217B8 \
SIGN=AB2DFD16F05E
INCREMENT nx_esc_solv uglmd 22.000 permanent 999 4A69E9BC4333 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=99 \
SIGN=050789C87BE2
INCREMENT id_esc_solv uglmd 22.000 permanent 999 A8899E3078CE \
SIGN=A4EDE1C0A424
INCREMENT id_tmg_solver uglmd 22.000 permanent 999 43BA3609EBF8 \
SIGN=899AB40434A4
INCREMENT id_tmg_advanced uglmd 22.000 permanent 999 1B60CD99251E \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=56 \
SIGN=919990F6547E
INCREMENT nx_flow_solver uglmd 22.000 permanent 999 8ADFEC31B832 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=134 \
SIGN=BD85C5927D9E
SIGN=A4EDE1C0A424
INCREMENT view_only uglmd 22.000 permanent 999 00A398C3E18D SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=151 SIGN=5D5D1D307262
INCREMENT nx_ftk uglmd 22.000 permanent 999 455369C5BC3E SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=81 SIGN=A4605A182332
INCREMENT nx_thermal_ui uglmd 22.000 permanent 999 E0388732E7DA \
SIGN=C79504823040
INCREMENT nx_flow_ui uglmd 22.000 permanent 999 1EC6664C7D3E \
SIGN=DBFC64C81E32
INCREMENT nx_space_therm_ui uglmd 22.000 permanent 999 700210828DE8 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=39 \
SIGN=9C65751878DE
INCREMENT nx_esc_ui uglmd 22.000 permanent 999 D46FEF9A493D SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=193 SIGN=EB9F43D6D406
INCREMENT nx_nastran_import uglmd 22.000 permanent 999 44D253807000 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=19 \
SIGN=5E9C60F8DEAE
INCREMENT nx_nastran_export uglmd 22.000 permanent 999 6542F0CA4638 \
SIGN=DA45009AF600
INCREMENT ug_nas_bn uglmd 22.000 permanent 999 7023047E8CF1 SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=95 SIGN=1D8ED7A4B750
INCREMENT nx_nas_bn_basic_dsk uglmd 22.000 permanent 999 FBBA59606B6B \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=146 \
SIGN=D669CCC87894
INCREMENT nx_nas_bn_basic_ent uglmd 22.000 permanent 999 8CE3F181888A \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=98 \
SIGN=E8F8E67E0C04
INCREMENT ug_nas_des uglmd 22.000 permanent 999 9DCA4EF1CCDC \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=182 \
SIGN=1B1FBCC0E1F2
INCREMENT nx_abaqus_import uglmd 22.000 permanent 999 3B7A174CA083 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=92 \
SIGN=A13A82A86608
INCREMENT nx_abaqus_export uglmd 22.000 permanent 999 BBCBF0ED2279 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=180 \
SIGN=8634F856F3E8
INCREMENT nx_ansys_import uglmd 22.000 permanent 999 9DDD45F3E4F9 \
SIGN=9FDE71182CAE
INCREMENT nx_ansys_export uglmd 22.000 permanent 999 208E252B88E6 \
SIGN=8460A3B6683E
INCREMENT simulation uglmd 22.000 permanent 999 2527AC87704D \
SIGN=F43480B43494
INCREMENT nx_nas_aero_dsk uglmd 22.000 permanent 999 E6A6291B1294 \
SIGN=9C9F0934C7DC
INCREMENT nx_nas_aero_ent uglmd 22.000 permanent 999 33AE80740D70 \
SIGN=5409A3FA80AE
INCREMENT nx_nas_basic_dsk uglmd 22.000 permanent 999 C246FD717FD1 \
SIGN=766F467AF186
INCREMENT nx_nas_basic_ent uglmd 22.000 permanent 999 3067A7DFF31B \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=91 \
SIGN=6EF218FCECCA
INCREMENT nx_nas_dmap_dsk uglmd 22.000 permanent 999 0F6DB8E2FE94 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=154 \
SIGN=071E4C265170
INCREMENT nx_nas_dmap_ent uglmd 22.000 permanent 999 A3493D67B502 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=71 \
SIGN=D9FF7F2C0020
INCREMENT nx_nas_dyn_dsk uglmd 22.000 permanent 999 041847E417EE \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=59 \
SIGN=E14A2118DDC6
INCREMENT nx_nas_dyn_ent uglmd 22.000 permanent 999 C08EF63854CB \
SIGN=7CD33AEC8422
INCREMENT nx_nas_nonlin_dsk uglmd 22.000 permanent 999 772E8823F473 \
SIGN=6E445AFCD44A
INCREMENT nx_nas_nonlin_ent uglmd 22.000 permanent 999 91DC4250D5DA \
SIGN=D3D6F40A2E92
INCREMENT nx_nas_optim_dsk uglmd 22.000 permanent 999 876DFF0880F5 \
SIGN=AB72F648FDB8
INCREMENT nx_nas_optim_ent uglmd 22.000 permanent 999 DBB4E1DCCE3B \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=209 \
SIGN=9DAE0070EEF0
INCREMENT nx_nas_supel_dsk uglmd 22.000 permanent 999 729F8D8BAF04 \
SIGN=EB8541D21020
INCREMENT nx_nas_supel_ent uglmd 22.000 permanent 999 478A57796B06 \
SIGN=C792680E9334
INCREMENT nx_nas_zona_dsk uglmd 22.000 permanent 999 8A7488BE2724 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=132 \
SIGN=296C81E6CE36
INCREMENT nx_nas_zona_ent uglmd 22.000 permanent 999 230C738B2240 \
SIGN=E72441A8EC4C
INCREMENT nx_nas_dmp_dsk uglmd 22.000 permanent 999 B77FDB18D1B0 \
SIGN=611094583144
INCREMENT nx_nas_dmp_ent uglmd 22.000 permanent 999 8C6F02743E35 \
SIGN=F72F2AFACEC6
INCREMENT nx_nas_rotodyn_dsk uglmd 22.000 permanent 999 0A516DB5E84D \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=46 \
SIGN=F1BB51F690EA
INCREMENT nx_nas_rotodyn_ent uglmd 22.000 permanent 999 A91B2D7450CF \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=104 \
SIGN=3A5EE9F4E984
INCREMENT nx_nas_advnlin uglmd 22.000 permanent 999 FB2132E098BD \
SIGN=644580BE87E0
INCREMENT nx_nas_advnlin_exp uglmd 22.000 permanent 999 2DA801D3FEED \
SIGN=9C3B35F2F1BA
INCREMENT BASE_TEST uglmd 22.000 permanent 999 99A7273BEB2D SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=138 SIGN=AFF3951A538A
INCREMENT TimeProcessing uglmd 22.000 permanent 999 11117F6C5264 \
SIGN=A1AEA504E92A
INCREMENT TestGeometry uglmd 22.000 permanent 999 4727660D4F63 \
SIGN=87E9FC0856C0
INCREMENT BasicModal uglmd 22.000 permanent 999 C5533DFEB881 \
SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=162 \
SIGN=A1F37976CC54
INCREMENT StructuralModification uglmd 22.000 permanent 999 \
82C20F128ED3 SUPERSEDE DUP_GROUP=UHD ISSUED=1-oct-2006 ck=159 \
SIGN=F49D4ED25BB4
INCREMENT Correlation uglmd 22.000 permanent 999 3F1D471B8C5F \
SIGN=D29DA72625DE
INCREMENT Fatigue uglmd 22.000 permanent 999 7C5EBA81C98A SUPERSEDE \
DUP_GROUP=UHD ISSUED=1-oct-2006 ck=110 SIGN=DAF3B6A24DDC
SIGN=A1F37976CC54
FEATURE server_id uglmd 22.000 permanent 999 BA8F5362BF6A \
VENDOR_STRING=UGS user_info=Spotted_Cuscus ISSUER=ISO ck=131 \
SIGN=43A9E44E7010
DAEMON uglmd
SIGN=C422413ABB38
SIGN=13283F82BC02
SIGN=0CDBC4D281EA
SIGN=448CA3EEA82E
SIGN=A71AADEAF8B8
SIGN=90578DFA6356
SIGN=C11210F46938
SIGN=A0B9AD7C979E
SIGN=17328338939A
SIGN=6BEDECF695C2
SIGN=4F265DA82A12
SIGN=56FC2CCCD284
SIGN=32B7F9D6446C
SIGN=8123BC485304
SIGN=0D1AF8D694D0
SIGN=A4DA6BCEF2E8
SIGN=57C4CEEC59AA
SIGN=F2A239D42900
SIGN=CB7C5CEA0A60
SIGN=E8431BD8F0A6
SIGN=DE0BCB96B67A
SIGN=765CE1A4E1CE
SIGN=9A880BB05EF4
SIGN=CD020320BD2E
SIGN=E9A061F80616
SIGN=E0DA238223E4
SIGN=32CC37E43D66
SIGN=6B0C20740830
SIGN=EEF5B454D89E
SIGN=7EBD79C2E030
SIGN=D509FDC619C2
SIGN=1A17106A8BE2
SIGN=D49BF28A26E6
SIGN=C0AC25B21038
SIGN=500B83F4B044
SIGN=02528A963762
SIGN=4492450EAE0A
SIGN=6EFCF1C4B5CA
SIGN=2FAB911E9336
SIGN=2AFE27ECA30C
SIGN=87E7E228C0B4
SIGN=656A2024913C
SIGN=79132E9A9408
SIGN=13A410BED2D4
SIGN=BD43CCBC51F2
SIGN=CD106B66A770
SIGN=F8FB8C9ED61C
SIGN=8E4C590080FA
SIGN=356C0F18572A
SIGN=0B23F74C9A66
SIGN=5FBBCB1C81C6
SIGN=A2DBFB4A0040
SIGN=DDF89400C7E8
SIGN=1B5ABEC032B2
SIGN=8F7FD17806F6
SIGN=683B6FFC2A3C
SIGN=E2CC655E8E3A
SIGN=489DEE228014
SIGN=953C360AAE7A
SIGN=BC64973295F0
SIGN=2C77AED6228E
SIGN=FC722364A594
SIGN=103569920D16
SIGN=129853788068
SIGN=145D3E5ADCA4
SIGN=127B45103E50
SIGN=F7DA9C169CD2
SIGN=ADD01EEC1290
SIGN=F5235A207BD8
SIGN=61C911245FA2
SIGN=653035906830
SIGN=3E48CAF2A1AC
SIGN=C738E2C63960
SIGN=B3A4677C4BB6
SIGN=B473673EFB88
SIGN=1E9A74AA2AA4
SIGN=07A16D221E86
SIGN=04F59DCA732A
SIGN=2245592E899E
SIGN=95AF50882B94
SIGN=4A8665E44792
SIGN=364212AAFA76
SIGN=C90F38282D4C
SIGN=30EDFCB4DA70
SIGN=AB54EAB2CAB4
SIGN=B98D7BEE0A2A
SIGN=C71759EA489E
SIGN=5D81A65A4BDA
SIGN=AB2DFD16F05E
SIGN=050789C87BE2
SIGN=A4EDE1C0A424
SIGN=899AB40434A4
SIGN=919990F6547E
SIGN=BD85C5927D9E
SIGN=A4EDE1C0A424
SIGN=C79504823040
SIGN=DBFC64C81E32
SIGN=9C65751878DE
SIGN=5E9C60F8DEAE
SIGN=DA45009AF600
SIGN=D669CCC87894
SIGN=E8F8E67E0C04
SIGN=1B1FBCC0E1F2
SIGN=A13A82A86608
SIGN=8634F856F3E8
SIGN=9FDE71182CAE
SIGN=8460A3B6683E
SIGN=F43480B43494
SIGN=9C9F0934C7DC
SIGN=5409A3FA80AE
SIGN=766F467AF186
SIGN=6EF218FCECCA
SIGN=071E4C265170
SIGN=D9FF7F2C0020
SIGN=E14A2118DDC6
SIGN=7CD33AEC8422
SIGN=6E445AFCD44A
SIGN=D3D6F40A2E92
SIGN=AB72F648FDB8
SIGN=9DAE0070EEF0
SIGN=EB8541D21020
SIGN=C792680E9334
SIGN=296C81E6CE36
SIGN=E72441A8EC4C
SIGN=611094583144
SIGN=F72F2AFACEC6
SIGN=F1BB51F690EA
SIGN=3A5EE9F4E984
SIGN=644580BE87E0
SIGN=9C3B35F2F1BA
SIGN=A1AEA504E92A
SIGN=87E9FC0856C0
SIGN=A1F37976CC54
SIGN=F49D4ED25BB4
SIGN=D29DA72625DE
SIGN=A1F37976CC54
SIGN=43A9E44E7010
