ansys之——浇筑混凝土
浏览:522881 评论:1 收藏:1
!大伙看看,有何问题,如何改进?
!100*80*10基岩上浇筑混凝土50*40*10,每三天浇筑1米高(第一天浇完,剩下两天窝工),
!共用一个月时间,分为十层(layer)浇筑,模型、条件均为假设
!建模
/filename,test
/PREP7
BLOCK,,50,,10,,40,
BLOCK,-25,75,-10,0,-20,60
ET,1,70
LSEL,S,,,9,12,1
LESIZE,ALL,,,10
LSEL,S,,,21,24,1
LESIZE,ALL,,,20
LSEL,S,,,2,4,2
LSEL,A,,,5,7,2
LESIZE,ALL,,,10
LSEL,S,,,14,16,2
LSEL,A,,,17,19,2
LESIZE,ALL,,,20
LSEL,S,,,1,3,2
LSEL,A,,,6,8,2
LESIZE,ALL,,,10
LSEL,S,,,13,15,2
LSEL,A,,,18,20,2
LESIZE,ALL,,,5
allsel
MP,DENS,1,2400.0 !混凝土材料
MP,KXX ,1,300.89
MP,C,1,0.94500
MAT,1
VMESH,1
MP,DENS,2,2600.0 !基岩材料
MP,KXX ,2,300.89
MP,C,2,0.94500
MAT,2
VMESH,2
nummrg,all
!热分析
/SOLU
NROPT,FULL !Specifies the Newton-Raphson options in full transient analysis
ESEL,S,MAT,,2 !MAT2 IS 基岩
NSLE,S
IC,all,TEMP,16.4, !加基岩初温
ASEL,S,,,7,9,1
ASEL,A,,,11,12,1
NSLA,S,1
SF,all,HFLUX,0 !加基岩绝热边界条件
NSEL,S,LOC,Y,-0.1,0.1
ASEL,S,,,3
NSLA,U,1
SF,ALL,CONV,2016,20 !加基岩第三边界条件(和空气接触面)
!加初始条件
ALLSEL,ALL
ESEL,U,MAT,,2
NSLE,S
EKILL,ALL !KILL 混凝土
IC,all,TEMP,35, !混凝土浇筑时温度为35度
ANTYPE,TRANSIENT,new !分析类型
!日子的流逝
*DO,LAYER,1,10,1
!激活第N层单元
ALLSEL,ALL
NSEL,S,LOC,Y,(LAYER-1),LAYER !第一层从Y=0~1米,第二层从Y=1~2米,...
ESLN,S ,1
EALIVE,ALL
*DO,DAY,LAYER*3-2,LAYER*3,1 !每三天浇筑一层
ALLSEL,ALL
ASEL,S,,,1,2,1
ASEL,A,,,5,6,1
NSLA,S,1
NSEL,R,LOC,Y,0,LAYER
NSEL,A,LOC,Y,LAYER-0.1,LAYER+0.1
SF,ALL,CONV,2016,20 !加混凝土第三类对流边界条件
*DO,LOOP,1,LAYER,1
ALLSEL,ALL
NSEL,R,LOC,Y,LOOP-1,LOOP
ESLN,S,1
TDAY=DAY-(LOOP-1)*3 !已经完工的天数
HE00=47880*(TDAY/(0.862+TDAY)-(TDAY-1)/(0.862+TDAY-1))
BFE,ALL,HGEN, ,HE00 !加水化热
*ENDDO
!计算设置
ALLSE
TRNOPT,FULL
LUMPM,0
TIME,DAY
AUTOTS,0
DELTIM,1, , ,1
KBC,0
TSRES,ERASE
OUTRES,ALL,ALL,
SOLVE
*ENDDO
ESEL,S,MAT,,1
NSLE,S,
SFEDELE,ALL,ALL,CONV !删对流边界条件
SFDELE,ALL,CONV
*ENDDO
FINISH
!结构分析
/PREP7
ET,1,SOLID65 !变热单元为结构单元
*DIM,EXX,ARRAY,30 !考虑变化的EX
EXX(1)=0.325E10,0.57778E10,0.78E10,0.94545E10,0.10833E11,0.12E11,0.13E11,0.13867E11,0.14625E11,0.15294E11, 0.15889E11, 0.1642E11 ,0.169E11, 0.17333E11, 0.17727E11, 0.18087E11,0.18417E11,0.1872E11
EXX(19)=0.190E11, 0.19259E11, 0.195E11, 0.19724E11, 0.19933E11, 0.20129E11,0.20312E11, 0.20485E11, 0.20647E11, 0.208E11, 0.20944E11, 0.21081E11
*DO,I,1,30,1 !定义材料,混凝土浇筑完每过一天变一种材料
MP,DENS,I,2400
MP,EX,I,EXX(I)
MP,PRXY,I,0.167
MP,ALPX,I,0.9E-5
MP,REFT,I,15
*ENDDO
MP,DENS,31,2600 !定义基岩材料
MP,EX,31,0.20800E+11
MP,PRXY,31,0.167
MP,ALPX,31,0.9E-5
ESEL,S,MAT,,,2
MPCHG,31,ALL, !!变热材料为结构材料
ALLSEL
/SOLU
NROPT,FULL !Specifies the Newton-Raphson options in a full transient analysis
NLGEOM,ON
NSLA,S,,,7,9,1
NSLA,A,,,11,12,1
D,all,ALL !加基岩约束
!KILL THE CONCRETE ELEMENT
ESEL,U,MAT,,1
NSLE,S
EKILL,ALL !KILL 混凝土
*DO,DAY,1,30,1 !随时间改变,变换材料
*DO,LAYER,1,10
*IF,DAY,GT,LAYER*3-3,THEN
NSEL,S,LOC,Y,LAYER-1,LAYER
ESLN,S,1
EALIVE,ALL !ACTIVE NEXT LAYER
MPCHG,DAY-(LAYER-1)*3,ALL, !CHANG MAT
ALLSEL,ALL
*ENDIF
*ENDDO
ALLSEL,ALL
ACEL,0,0,-9.8, !GRAVITY LOAD
LDREAD,TEMP,,,DAY, ,'TEST','rth',' ' !TEMP LOAD Reads results from the results file and applies them as loads.
CNVTOL,F, ,0.2,2,200, !Sets convergence values for nonlinear analyses.
TIME,DAY
AUTOTS,0
DELTIM,1, , ,1
KBC,0
TSRES,ERASE !Defines an array of keytimes at which the time-stepping strategy changes
OUTRES,ALL,ALL,
SOLVE
*ENDDO
!1、定义重力集散地是应为正值:ACEL,0,0,9.8
!2、砼单元边长(1*4*5)相差5倍,对计算精度的影响会不会较大?
!3、热单元SOLID70对应的结构单元为SOLID45,改为SOLID65是否合适?
!4、原分析得到的结果与实际情况比较如何?
!5、如何体现气温的变化?
!建模
/filename,test
/PREP7
BLOCK,,50,,10,,40,
ET,1,70
LSEL,S,,,9,12,1
LESIZE,ALL,,,10
LSEL,S,,,21,24,1
LESIZE,ALL,,,20
LSEL,S,,,2,4,2
LSEL,A,,,5,7,2
LESIZE,ALL,,,10
LSEL,S,,,14,16,2
LSEL,A,,,17,19,2
LESIZE,ALL,,,20
LSEL,S,,,1,3,2
LSEL,A,,,6,8,2
LESIZE,ALL,,,10
LSEL,S,,,13,15,2
LSEL,A,,,18,20,2
LESIZE,ALL,,,5
allsel
MP,KXX ,1,300.89
MP,C,1,0.94500
MAT,1
VMESH,1
MP,KXX ,2,300.89
MP,C,2,0.94500
MAT,2
VMESH,2
nummrg,all
!热分析
/SOLU
NSLE,S
ASEL,S,,,7,9,1
ASEL,A,,,11,12,1
NSLA,S,1
ASEL,S,,,3
NSLA,U,1
!加初始条件
ALLSEL,ALL
ESEL,U,MAT,,2
NSLE,S
EKILL,ALL !KILL 混凝土
!日子的流逝
*DO,LAYER,1,10,1
!激活第N层单元
ALLSEL,ALL
ESLN,S ,1
EALIVE,ALL
ALLSEL,ALL
ASEL,S,,,1,2,1
ASEL,A,,,5,6,1
NSLA,S,1
*DO,LOOP,1,LAYER,1
ALLSEL,ALL
ESLN,S,1
*ENDDO
!计算设置
ALLSE
TRNOPT,FULL
LUMPM,0
TIME,DAY
AUTOTS,0
DELTIM,1, , ,1
KBC,0
TSRES,ERASE
OUTRES,ALL,ALL,
SOLVE
*ENDDO
ESEL,S,MAT,,1
NSLE,S,
SFDELE,ALL,CONV
*ENDDO
FINISH
!结构分析
/PREP7
MP,DENS,I,2400
MP,EX,I,EXX(I)
MP,PRXY,I,0.167
MP,ALPX,I,0.9E-5
MP,REFT,I,15
*ENDDO
MP,PRXY,31,0.167
MP,ALPX,31,0.9E-5
ESEL,S,MAT,,,2
ALLSEL
/SOLU
NLGEOM,ON
NSLA,S,,,7,9,1
NSLA,A,,,11,12,1
D,all,ALL !加基岩约束
ESEL,U,MAT,,1
NSLE,S
EKILL,ALL !KILL 混凝土
*DO,LAYER,1,10
ESLN,S,1
ALLSEL,ALL
*ENDIF
*ENDDO
ALLSEL,ALL
TIME,DAY
AUTOTS,0
DELTIM,1, , ,1
KBC,0
OUTRES,ALL,ALL,
SOLVE
*ENDDO
!5、如何体现气温的变化?
