案例解析|潜艇外流场分析
摘要:
舰船自航评估和研究通常是由拖曳水池自航试验实现,实施周期长,耗资大。船舶三维多面体OPENFOAM
潜艇外流场分析报告
项目概述
该项目展示了如何模拟潜艇周围的外部流体流动的示例
舰船自航评估和研究通常是由拖曳水池自航试验实现,实施周期长,耗资大。采用流体动力数值仿真分析技术,能够系统分析和研究各种水下航行器的航行性能,指导水下航行器设计,提出优化设计方案和改进航行性能的措施。
本项目对潜艇的水动力航行性能进行了分析和研究。
模型简化
本算例使用几何来源simscale官网,几何模型如图1所示。
潜艇几何简化模型
网格设置
本算例采用snappyHexMesh对几何模型进行网格划分(如图2),详细参数设置如下所示:
geometry
{solid_0
{type triSurfaceMesh;
file "solid_0.stl";
innerbox1
{type searchableBox;
min (-10 -15 -10);
max ( 80 15 15);
innerbox2
min (-75 -15 -10);
max ( 90 15 15);
castellatedMeshControls
{maxLocalCells 2000000;
maxGlobalCells 4000000;
minRefinementCells 1;
maxLoadUnbalance 0.2;
nCellsBetweenLevels 4;
resolveFeatureAngle 30;
allowFreeStandingZoneFaces false;
features
{file "solid_0.extendedFeatureEdgeMesh";
level 4;
refinementSurfaces
{solid_0
{level (4 4);
patchInfo
{ type wall;
inGroups (solid_0Group);
refinementRegions
{solid_0
{mode distance;
levels ((1 4));
innerbox1
{mode inside;
levels ((1E15 2));
innerbox2
{mode inside;
levels ((1E15 1));
locationInMesh (-120 0 0);
snapControls
{nSmoothPatch 3;
tolerance 3.0;
nSolveIter 300;
nRelaxIter 5;
nFeatureSnapIter 10;
implicitFeatureSnap true;
explicitFeatureSnap false;
multiRegionFeatureSnap false;
addLayersControls
{relativeSizes true;
layers
"solid_0_.*"
{nSurfaceLayers 5;
expansionRatio 1.3;
finalLayerThickness 0.3;
minThickness 0.001;
nGrow 0;
featureAngle 180;
slipFeatureAngle 75;
nRelaxIter 5;
nSmoothSurfaceNormals 1;
nSmoothNormals 3;
nSmoothThickness 10;
maxFaceThicknessRatio 0.5;
maxThicknessToMedialRatio 0.3;
minMedianAxisAngle 90;
nBufferCellsNoExtrude 0;
nLayerIter 50;
nRelaxedIter 20;
meshQualityControls
{maxNonOrtho 65;
maxBoundarySkewness 20;
maxInternalSkewness 4;
maxConcave 80;
minVol 1e-13;
minTetQuality 1e-15;
minArea -1;
minTwist 0.01;
minDeterminant 0.001;
minFaceWeight 0.02;
minVolRatio 0.01;
minTriangleTwist -1;
nSmoothScale 4;
errorReduction 0.75;
relaxed
{maxNonOrtho 75;
writeFlags
(scalarLevels // write volScalarField with cellLevel for postprocessing
layerSets // write cellSets, faceSets of faces in layer
layerFields // write volScalarField for layer coverage
mergeTolerance 1E-6;
潜艇网格划分
网格信息参数及网格质量参数如下所示:
网格信息参数
网格总数
数量 1544724 4346105 1402876
网格类型
类型 hexahedra prisms tet wedges polyhedra 数量 1280641 21250 25 100957 网格质量
评价指标 最大纵横比 最小体积 最大非正交性 最大歪斜率 值 19.795 6.38e-005 64.11 5.33
边界条件参数
该算例湍流模型选用K-Omega SST模型。外流场壁面应用对称平面边界条件,进出口边界条件见表1。
表1 边界条件参数
边界条件 参数
速度进口 15m/s 压力出口 0Pa
求解器参数设置
fvSchemes设置
ddtSchemes {
default steadyState;
gradSchemes {
default Gauss linear;
grad(U) Gauss linear;
grad(p) Gauss linear;
divSchemes {
default none;
div(phi,U) bounded Gauss upwind;
div(phi,omega) bounded Gauss upwind;
div((nuEff*dev2(T(grad(U))))) Gauss linear;
div(phi,k) bounded Gauss upwind;
laplacianSchemes {
default Gauss linear corrected;
laplacian(nuEff,U) Gauss linear corrected;
laplacian((1|A(U)),p) Gauss linear corrected;
laplacian(nu,U) Gauss linear corrected;
interpolationSchemes {
default linear;
interpolate(HbyA) linear;
snGradSchemes {
default corrected;
fluxRequired {
default no;
p ;
wallDist
{method meshWave;
fvSolution设置
solvers {
p {
relTol 0.005;
cacheAgglomeration on;
nPreSweeps 0;
agglomerator faceAreaPair;
nCellsInCoarsestLevel 10;
solver GAMG;
nPostSweeps 0;
mergeLevels 1;
smoother GaussSeidel;
tolerance 1e-06;
k {
relTol 0.01;
preconditioner DILU;
tolerance 1e-06;
solver PBiCG;
U {
relTol 0.01;
tolerance 1e-05;
solver PBiCG;
omega {
relTol 0.01;
tolerance 1e-06;
solver PBiCG;
relaxationFactors {
fields {
p 0.3;
equations {
omega 0.7;
k 0.7;
U 0.7;
SIMPLE {
pRefValue 0.0;
residualControl {
p 1e-06;
k 1e-06;
U 1e-06;
omega 1e-06;
nNonOrthogonalCorrectors 0;
pRefCell 0;
controlDict设置
application simpleFoam;
startFrom startTime;
stopAt endTime;
purgeWrite 0;
writeFormat ascii;
writePrecision 12;
writeCompression on;
timeFormat general;
timePrecision 12;
runTimeModifiable yes;
deltaT 1.0;
startTime 0.0;
writeInterval 1000;
adjustTimeStep no;
endTime 2000.0;
writeControl timeStep;
functions {
计算结果
本算例计算总步长为1272步时云图如下所示:
