询问:ansys cfx模拟密封容器晃动时边界怎么设定
浏览:38895
试着用做密封储液罐的流固双向耦合,不知该怎么设定,就全部设计成了fsi-wall,边界设定出了问题,求解决
问题:In Analysis 'Flow Analysis 1': Export results are unavailable as no suitable boundaries exist for use as export surfaces. Mesh motion on a boundary invalidates its use as an export surface.
