有限元热力耦合,显示下面警告怎么解决?
2022年4月20日 浏览:1607
Whenever a translation (rotation) dof at a node is constrained by a kinematic coupling definition the translation (rotation) dofs for that node cannot be included in any other constraint including mpcs, rigid bodies, etc. The option *temperature is used but the option *initial conditions,type=temperature is not. The initial temperature values are assumed to be zero. MPCS (EXTERNAL or INTERNAL, including those generated from rigid body definitions), KINEMATIC COUPLINGS, AND/OR EQUATIONS WILL ACTIVATE ADDITIONAL DEGREES OF FREEDOM Node set assembly_m_set-10 has no members and will be ignored. Nodes defined in this set may have been deleted because they were not connected to any elements. Node set assembly_m_set-11 has no members and will be ignored. Nodes defined in this set may have been deleted because they were not connected to any elements. Node set assembly_set-12 has no members and will be ignored. Nodes defined in this set may have been deleted because they were not connected to any elements. 242 nodes have dof on which incorrect boundary conditions may have been specified. The nodes have been identified in node set WarnNodeBCIncorrectDof. 242 nodes have dof on which incorrect boundary conditions may have been specified. The nodes have been identified in node set WarnNodeBCIncorrectDof.
点赞 评论 收藏
