MEMORY存储芯片AK4430ET中文规格书.pdf
2021-02-04
下载
大小:270.93KB
85°C
Small Package: 16pin TSSOP (6.4mm x 5.0mm)
LRCK
BICK
SDTI
Audio
Data
Interface
MCLK
ΔΣ
Modulator AOUTL
8X
Interpolator
SCF
LPF
AOUTR
VDD
VSS1
Control
Interface
Clock
Divider
ΔΣ
8X
Interpolator
SCF
LPF
Charge
Pump
CP CN VEE VSS2 CVDD
1μ 1μ
VREFHSMUTE
DIF
Modulator
2.2μ
[AK4430]
■ Ordering Guide
AK4430ET
节选段落二:
Digital de-emphasis - X - - -
I/F format 24-bit MSB/I²S I²S 24-bit MSB/I²S 24-bit MSB/I²S 24-bit MSB/I²S
Pin out Pin#3 SMUTE DEM SMUTE SMUTE SMUTE
Pin#8 DIF SMUTE DIF DIF* DIF*
Pin#13 DZF DZF DZF DZF VREFH
THD+N -92dB -92dB -92dB (-3dBFS) -92dB -91dB
DR 105dB 105dB 102dB 102dB 104dB
Operating
Temperature
ET
节选段落三:
: -20 ∼ +85°C
VT: -40 ∼ +85°C ET: -20 ∼ +85°C ET: -20 ∼ +85°C ET: -20 ∼ +85°C ET: -20 ∼ +85°C
(-: Not available, X: Available)
*: Internal pull up (100kΩ)
MS1196-E-01 2011/03
[AK4430]
PIN/FUNCTION
No.
