procast砂型重力铸造步骤.doc
2022-11-03 下载:4
下载
大小:2.70MB
procast经典版本的砂型重力铸造步骤,可以观看照做,望各位成功。
Gravity-Sand
This tutorial will guide you step by step in the ProCAST set-up of a sand casting simulation.
The geometry used for this tutorial is composed of a:
·casting
·sand box
·cores
本指南将指导你在 ProCAST 中一步一步地建立一个砂型铸件模拟。
节选段落二:
本指南中需要的几何模型包括:
·铸件
·砂型
·砂芯
1 Load the sand.mesh model in PreCAST
1、在PreCAST中加载 sand.mesh 模型
Please enter first the case name under the 'Case' field of the file manager and press the PreCAST menu
PreCAST will load first a ProCAST file (d.dat) if it is present in the current directory.
节选段落三:
9 Save and Exit PreCAST
9、保存并退出PreCAST
10 Run DataCAST and ProCAST
10、运行DataCAST 和 ProCAST
11 Visualize the results in ViewCAST
11、在 ViewCAST中 显示结果
Position the model using the picture manipulation tools (zoom, drag, rotate, ...).
用图像处理工具 (zoom, drag, rotate, ...)定位模型
Select the casting material.
