Contact FE analysis .pdf
2015-11-24 下载:22
下载
大小:1.02MB
Contact FE analysis
Using this computing model, we
conducted static and dynamic contact analyses. In static
contact analysis, the position on the contact surface does not
change with respect to time. On the other hand, in dynamic
contact analysis, the position on the contact surface changes
节选段落二:
The contact analysis of the
hinges can be realized through the contact domain and the
non-contact domain of the hinge in the deployable structure.
节选段落三:
In future work, a mechanism will be analyzed using
contact analysis The time history of the contact force on the
hinges causes hysteresis of the displacement.
