LS-DYNA R13.1.1已经发布
更新于2022年8月27日 15:16软件生成时间:2022-06-30
正式发布时间:2022-07-25
LS-DYNA version history:
*** revision R13.1_1 07/25/2022 *** updated ansys license
*** revision R13.1_0 03/11/2022
*** revision F14_0_0 01/09/2022 **** for Ansysform only
*** revision F12_1_0 10/29/2021 ****
*** revision R13_0_0 07/19/2021 ****
*** revision R11_2_2 05/03/2021 ****
*** revision R11_2_1 02/05/2021 ****
*** revision R11_2_0 10/18/2020 ****
*** revision R12_0_0 06/19/2020 ****
*** revision R11_1_0 08/12/2019 ****
*** revision R10_2_0 03/05/2019 ****
*** revision R11_0_0 08/27/2018 ****
*** revision R9_3_0 07/09/2018 ****
*** revision R10_1_0 01/15/2018 ****
*** revision R9_2_0 08/15/2017 ****
*** revision R10_0_0 07/05/2017 ****
*** revision R9_1_0 01/19/2017 ****
*** revision R9_0_1 08/10/2016 ****
*** revision R9_0_0 07/06/2016 ****
*** revision R8_1_0 02/24/2016 ****
*** revision R8_0_0 01/22/2015 ****
*** revision R7_1_2 01/07/2015 ****
*** revision R7_1_1 04/04/2014 ****
*** revision R7_1_0 02/19/2014 ****
Executables:
Naming convention for ls-dyna
ls-dyna_TYPE_PRECISION_REVISION_MACHINE_OSVER_COMPILER_OPTION
where
TYPE: smp, mpp, hyb
PRECISION: s, d
REVISION: R13_1_0
MACHINE: x64
COMPILER: for190, nvidia209, nvidia209
OSVER: centos79,centos79
OPTION:
INSTUC: sse2, avx2, avx512
DYNALIB: sharelib
MPILIB: platformmpi, intelmpi, openmpi, mpich, etc
LS-DYNA Name Fortran Platform
-- linux.64 ------------------------------------------------------------------
ls-dyna_smp_s_R13_1_0_x64_centos79_ifort190 ifort 16.0 x64 CentOS 7.9
ls-dyna_smp_d_R13_1_0_x64_centos79_ifort190 ifort 16.0 x64 CentOS 7.9
ls-dyna_smp_s_R13_1_0_x64_centos79_nvidia209 pgf90 20.9 x64 Centos 7.9
ls-dyna_smp_d_R13_1_0_x64_centos79_nvidia209 pgf90 20.9 x64 Centos 7.9
ls-dyna_smp_d_R13_1_0_x64_centos79_aocc310 aocc 3.1.0 x64 Centos 7.9
-- winx64 --------------------------------------------------------------------
ls-dyna_smp_s_R13_1_0_winx64_ifort190 ifort 16.0 PC/Windows winx64
ls-dyna_smp_d_R13_1_0_winx64_ifort190 ifort 16.0 PC/Windows winx64
The following versions have interactive graphics
ls-dyna_smp_s_R13_1_0_x64_centos79_ifort190 ifort 16.0 x64 Centos 7.9
ls-dyna_smp_d_R13_1_0_x64_centos79_ifort190 ifort 16.0 x64 Centos 7.9
To use ANSYS license you must install the license client code
in the directory of lsdyna executable.
> cd (lsdyna installed directory)
> cp licensingclient.tar (lsdyna installed directory)
> tar xf licensingclient.tar
Note:
Command to get OS for Linux system
uname -a
Command to get Fortran version numbers
Intel compiler: ifort -V
PGI compiler: pgf90 -V
AOCC compiler: aocc -v
Other files in the current directory:
README_first This file
README_installation Installation instruction
Release_Notes_LS-DYNA_R13_1_0_rev0.txt Release note
Other files in doc/ directory:
README_smp Instruction for running Parallel
README_setenv Environment variables used by LS-DYNA
README_madymo_cpl.txt Instructure for running LS-DYNA/MADYMO coupling code
更多资讯及合作,请发邮件或者关注我的微博及微信公众号!
技术邻:http://www.jishulink.com/z/1378
Email:82085494@qq.com
微博:https://weibo.com/langya222
微信公众号:
