spaceclaim的手势和快捷键好用
安装目录下“ANSYS Inc\v202\scdm\Library\Welcome”文件里面有一个名字为qrc.zh-hanS的PDF文档,这个就是了
spaceclaim的手势和快捷键好用
Open the Radial Menu
B Blend
C Circle
I Combine
Esc Escape
E Measure
F Fill
H Home
L Line
P Pull
R Rectangle
S select
D 3D mode
V Plan view
X Section mode
K Sketch mode
U Up To tool guide
M Move
T Trim Away
Spin
Shift+drag with middle mouse button Pan
Ctrl+drag up and down with middle mouse button Zoom
Alt+Z Zoom Extents
Shift+double-click middle mouse button Snap view
Left arrow Previous view
Right arrow Next view
Alt+F File menu
Ctrl+F4 Close document
Enter Complete
Ctrl+C
Ctrl+Shift+C
Copy
Copy Faces
Ctrl+G Create Group
Ctrl+X
Ctrl+Shift+X
Cut
Cut Faces
Del Delete
Ctrl+D Detach face
Alt+F4 Exit
Ctrl+Shift+I Invert selection
Ctrl+Tab Display next Design window
Ctrl+Shift+Tab Display previous Design window
Ctrl+right arrow Move sketch grid in
Ctrl+left arrow Move sketch grid out
Nudgeprimary (active)dimensionUpbynormal amount Shift+up arrow
Shift+down arrow Nudge primary (active) dimension Down by normal
amount
Nudge primary (active) dimension Up by small amount Alt+Shift+up arrow
Nudgeprimary (active)dimensionDownby smallamount Alt+Shift+down arrow
Ctrl+Shift+up arrow Nudge primary (active) dimension Up by large amount
Nudgeprimary (active)dimensionDownby large amount Ctrl+Shift+down arrow
Nudge secondary (inactive) dimension Down by normal Shift+left arrow
amount
Shift+right arrow Nudge secondary (inactive) dimension Up by normal
amount
Shift+Alt+left arrow Nudge secondary (inactive) dimension Down by small
amount
Shift+Alt+right arrow Nudge secondary (inactive) dimension Up by small
amount
Nudge secondary (inactive) dimension Down by large
amount
Ctrl+Shift+right arrow Nudge secondary (inactive)dimension Up by large
amount
Ctrl+N New
Ctrl+O Open
Ctrl+V Paste
Ctrl+P Print
Ctrl+F2 Print Preview
Ctrl+Y Redo
Ctrl+S Save
Ctrl+Shift+S
Alt+Shift+S
Save As
Save As New
Alt+S Share As File
Ctrl+Alt+S Save As New Version
Ctrl+A select all of same type as selected
Ctrl+B Bold text
Ctrl+I Italicize text
Ctrl+U Underline text
Ctrl+H Hide object
Alt+H Hide others
Ctrl+Z Undo
Ctrl+ + Zoom In
Ctrl+ - Zoom Out
Ctrl+T Set spin center
Ctrl+L Locate spin center
Ctrl+Q Clear spin center
' * ' on number pad Expand entire node in Structure tree
' + ' on number pad Expand selected node in Structure tree
' - ' on number pad Collapse selected node in Structure tree
Ctrl+Shift+A Activate Component
Ctrl+Shift+H Show All
Ctrl+Shift+F Initiate FlyThrough mode
