Abaqus批量提交作业
浏览:2459
# -*- coding: utf-8 -*-
from abaqus import *
from abaqusConstants import *
import os
import time
def clean_residual_files(job_name):
"""清理残留文件函数"""
residual_ext = ['.lck', '.prt', '.sim', '.sta',
'.abq', '.com', '.dat', '.msg','.odb',
'.log', '.odb', '.inp']
for ext in residual_ext:
file_path = job_name + ext
if os.path.exists(file_path):
try:
os.remove(file_path)
print("Residual files have been cleaned up: %s" % file_path)
except Exception as e:
print("Failed file cleanup: %s - %s" % (file_path, str(e)))
# 作业列表与参数配置
jobs = []
以下内容为付费内容,请购买后观看
批量提交作业,每个作业提交时会给出一个当前时间,运算完会给出一个结束时间,最后全部计算完了会给出一个总耗时。
