ansys workbench mechanical 所有命令
Category: Commands: Duplicate Without Results(Duplicate) Cut Copy Paste Delete Find Expand All(Tree) Collapse All (Tree) Collapse Environments(Tree) Refresh Display(Beta)(Tree) Resource Prediction Static Structural(Load Result File) Transient Structural (Load Result File) Eigenvalue Bucking(Load Result File) Harmonic Response(Load Result File) Modal (Load Result File) Random Vibration (Load Result File) Response Spectrum (Load Result File) Steady-State Thermal (Load Result File) Transient Thermal(Load Result File) Magnetostatic(Load Result File) Electric(Load Result File) Thermal-Electric (Load Result File) Harmonic Acoustics (Load Result File) Modal Acoustics(Load Result File) Static Acoustics(Load Result File) Coupled Field Static(Load Result File) Coupled Field Transient(Load Result File) Coupled Field Harmonic(Load Result File) Coupled Field Modal(Load Result File) Explicit Dynamics(Analysis) Rigid Dynamics(Analysis) Static Structural(Analysis) Structural Optimization(Analysis) Transient Structural (Analysis) Eigenvalue Buckling(Analysis) Harmonic Response(Analysis) Modal (Analysis) Random Vibration(Analysis) Response Spectrum(Analysis) Substructure Generation(Analysis) Steady-State Thermal(Analysis) Transient Thermal(Analysis) Magnetostatic(Analysis) Electric(Analysis) Thermal-Electric(Analysis) Harmonic Acoustics(Analysis) Modal Acoustics(Analysis) Static Acoustics(Analysis) Coupled Field Static(Analysis) Coupled Field Transient(Analysis) Coupled Field Harmonic(Analysis) Coupled Field Modal (Analysis) LS-DYNA(Analysis) Named Selection Coordinate System Remote Point Commands Comment Chart Figure(Images) Image(Images) Image from File..(Images) Image Plane from File..(Images) Image to File.…(Images) Image to Clipboard (Images) Section Plane Annotation |
Key assignments: |
Metric(m,kg,N,s,V,A)(Units) Metric(cm,g,dyne,s,V,A)(Units) Metric(mm,kg,N,s,mV,mA)(Units) Metric(mm,t,N,s,mV,mA)(Units) Metric(mm,dat,N,s,mV,mA)(Units) Metric(mm,kg,kN,ms,mV,mA)(Units) Metric(um,kg,μN,s,V,mA)(Units) u.s.Customary(ft,lbm,Ibf,F,s,V,A)(Units) u.s.Customary(in,lbm,Ibf,F,s,V,A)(Units) Degrees(Units) Radians(Units) rad/s(Units) RPM(Units) Celsius(For Metric Systems)(Units) Kelvin(For Metric Systems)(Units) Worksheet
Selection Information Unit Converter Print Preview ReportPreview Key Assignments Ful Screen Graphics Toolbar(Manage) Status Bar(Manage) Outine(Manage) Details (Manage) Messages(Manage) Mobile Body View(Manage) Reference Body View(Manage) Tabular Data(Manage) Graph (Manage) Scripting(Manage) Annotations(Manage) Mesh Metrics(Manage) object Generator(Manage) Section Planes(Manage) Layout 1(User Defined) Layout 2(User Defined) Layout 3(User Defined) Layout 4(User Defined) Layout 5(User Defined) Store Layout...(User Defined) Remove Layout.…(User Defined) |
Press new shortcut key: |
Reset Layout |
Category:
Display Tab
Commands:
Restore Default(Isometric) Look At Isometric View(Views) Front(Views) Back(Views) Right(Views) Left(Views) Top(Views) Bottom (Views) Previous Next Rotate +Sx Rotate +Sy Rotate +Sz Rotate -Sx Rotate -Sy Rotate -Sz Pan Up Pan Left Zoom In Pan Down Pan Right Zoom Out Random Rescale Preferences shaded Exterior and Edges(Display) shaded Exterior(Display) Wireframe(Display) Show Mesh Thick Shells and Beams Cross Section Remote Point Connections Body Color(Display Style) Part Color(Display Style) Assembly Color(Display Style) shellThickness(Display Style) Material(Display Style) Nonlinear Material Effects(Display Style) stiffness Behavior(Display Style) shell Thickness(Visible Part)(Display Style) Condensed Parts Color(Display Style) By Cross Section(Display Style) Body Type(Display Style) show Vertices Close Vertices Direction Mesh Connection Thicken By Body Color(Color) By Connection(Color) By Body Connection(Color) Black(Color) Hide Free(Free) Show Free(Free) Thick Free(Free) Hide Single(Single) Show Single(Single) Thick Single(Single) Hide Double(Double) Show Double(Double) Thick Double(Double) Hide Triple(Triple) Show Triple(Triple) Thick Triple(Triple) Hide Multiple(Multiple) Show Multiple(Multiple) Thick Multiple(Multiple) Reset Move Springs/Beams with Parts One Viewport(Viewports) Two Horizontal Viewports(Viewports) Two Vertical Viewports (Viewports) Four Viewports(Viewports) Sync Viewports Auto face draw(Draw Face Mode) Draw front faces(Draw Face Mode) Draw both faces (Draw Face Mode) |
Description:
prient your model to a desired view and select this option to define a new default view for the Isometric option.
Category:
Context Tab-Connections
Commands:
Connection Group Weld Group(Beta)
Body-Ground (Spring)
Body-Body(Spring)
Body-Ground (Beam)
Body-Body(Beam)
Body-Ground(Bearing)
Body-Body(Bearing) Spot Weld
End Release
Body Interaction AM Bond
Interstage
Bonded(Contact)
No Separation(Contact)
Frictionless(Contact)
Frictional(Contact)
Rough(Contact)
Forced Frictional(Contact)
Contact Tool
Solution Information Fixed(Body-Ground)
Revolute(Body-Ground)
cylindrical (Body-Ground)
Translational(Body-Ground)
slot (Body-Ground)
Universal(Body-Ground)
Spherical (Body-Ground)
Planar(Body-Ground)
General(Body-Ground)
Parallel (Body-Ground)
In-Plane (Body-Ground)
In-Line(Body-Ground)
Orientation(Body-Ground)
Bushing(Body-Ground)
In-Plane Radial Gap(Body-Ground)
Spherical Gap (Body-Ground)
General(Samcef)(Body-Ground)
Bushing(Samcef)(Body-Ground)
Screw (Body-Ground)
Constant Velocity(Body-Ground)
Distance(Body-Ground)
Fixed (Body-Body)
Revolute(Body-Body)
Cylindrical (Body-Body)
Translational(Body-Body)
slot(Body-Body)
Universal(Body-Body)
Spherical(Body-Body)
Planar(Body-Body)
General(Body-Body)
Parallel(Body-Body)
In-Plane(Body-Body)
In-Line(Body-Body)
Orientation(Body-Body)
Bushing(Body-Body)
Point On Curve(Body-Body)
In-Plane Radial Gap(Body-Body)
Spherical Gap(Body-Body)
General(Samcef)(Body-Body)
Bushing(Samcef)(Body-Body)
Screw(Body-Body)
Constant Velocity(Body-Body)
Distance(Body-Body)
Configure Assemble Set
Revert
Co-simulation Pin Worksheet
Body Views
Sync Views Description:
Key assignments:
Assign
Remove
Reset All
Insert a Connections group folder.Use this folder to add various contact-based features as well as to automatically generate Contact or Joint objects for the whole model or for a group of bodies.
Category:
Commands:
Body-Body(Spring)
Body-Ground (Beam)
Body-Body(Beam)
End Release
Interstage
Bonded(Contact)
Frictional(Contact)
Rough(Contact)
Contact Tool
slot (Body-Ground)
Planar(Body-Ground)
Screw (Body-Ground)
Fixed (Body-Body)
Revolute(Body-Body)
slot(Body-Body)
Planar(Body-Body)
General(Body-Body)
Parallel(Body-Body)
In-Plane(Body-Body)
In-Line(Body-Body)
Bushing(Body-Body)
Screw(Body-Body)
Distance(Body-Body)
Revert
Body Views
Key assignments:
Assign
Remove
Reset All
Category:
Context Tab-Environment(Main) Commands:
Physics Region 人
Acceleration (Inertial)
Standard Earth Gravity (Inertial)
Rotational Velocity(Inertial)
Rotational Acceleration (Inertial)
Mass Source(Acoustic Excitations)
Surface Velocity(Acoustic Excitations)
Diffuse Sound Field(Acoustic Excitations)
Incident Wave Source(Acoustic Excitations)
Port In Duct(Acoustic Excitations)
Mass Source Rate(Acoustic Excitations)
Surface Acceleration(Acoustic Excitations)
Temperature(Acoustic Loads)
Impedance Sheet(Acoustic Loads)
Static Pressure(Acoustic Loads)
Pressure(Acoustic Boundary Conditions)
Impedance Boundary(Acoustic Boundary Conditions)
Absorption Surface(Acoustic Boundary Conditions)
Radiation Boundary(Acoustic Boundary Conditions)
Absorption Element(Acoustic Boundary Conditions)
Free Surface(Acoustic Boundary Conditions)
Thermo-Viscous BLI Boundary(Acoustic Boundary Conditior Rigid Wall (Acoustic Boundary Conditions)
Symmetry Plane(Acoustic Boundary Conditions)
Port(Acoustic Boundary Conditions)
Far-field Radiation Surface(Acoustic Boundary Conditions) Transfer Admittance Matrix(Acoustic Models)
Low Reduced Frequency Model(Acoustic Models)
Pipe Pressure (Loads)
Hydrostatic Pressure(Loads)
Remote Force(Loads)
Bearing Load (Loads)
Bolt Pretension (Loads)
Generalized Plane Strain(Loads)
Line Pressure(Loads)
Thermal Condition(Loads)
Pipe Temperature (Loads)
Joint Load(Loads)
Fluid Solid Interface (Loads)
System Coupling Region (Loads)
Rotating Force(Loads)
Detonation Point(Loads)
Imported CFD Pressure(Loads)
Imported Remote Loads (Loads) Force
Moment
Pressure
Remote Displacement(Supports)
velocity(Supports)
Impedance Boundary(Supports)
Limit Boundary(Supports)
Compression Only Support(Supports)
Cylindrical Support(Supports)
Simply Supported(Supports)
Fixed Rotation(Supports)
Elastic Support(Supports)
Fixed
Frictionless
Displacement
Coupling(Conditions)
voltage Coupling(Conditions)
Constraint Equation(Conditions)
Pipe Idealization(Conditions)
Nonlinear Adaptive Region(Conditions)
Element Birth and Death(Conditions)
Contact Step Control (Conditions)
Body Control(Conditions)
Plastic Heating(Conditions)
Viscoelastic Heating(Conditions)
Nodal Orientation (Direct FE)
Nodal Force(DirectFE)
Nodal Pressure(Direct FE)
Nodal Displacement (Direct FE)
NodalRotation(Direct FE)
EM Transducer(Direct FE) Optimization Region
Excusion Region
Objective
Volume Constraint(Response Constraint)
Mass Constraint (Response Constraint)
Center of Gravity Constraint(Response Constraint)
Moment of Inertia Constraint(Response Constraint)
Compliance Constraint(Response Constraint)
Displacement Constraint (Response Constraint)
Reaction Force Constraint(Response Constraint)
Global Stress Constraint(Response Constraint)
Local von-Mises Stress Constraint(Response Constraint)
Natural Frequency Constraint(Response Constraint)
Dynamic Compliance Constraint(Response Constraint) Thermal Compliance Constraint(Response Constraint) Temperature Constraint (Response Constraint)
Criterion Constraint(Response Constraint)
Member Size(Manufacturing Constraint)
Pull Out Direction(Manufacturing Constraint)
Extrusion(Manufacturing Constraint)
AM Overhang Constraint(Manufacturing Constraint) Cyclic Repetition(Design Constraint)
Symmetry(Design Constraint)
Uniform(Design Constraint)
Pattern Repetition(Design Constraint)
Attribute Group Temperature
Convection Radiation
Heat Flow(Heat)
Perfectly Insulated (Heat)
Heat Flux(Heat)
Internal Heat Generation(Heat) Mass Flow Rate
Fluid Solid Interface(Conditions)
System Coupling Region(Conditions) Magnetic Flux Parallel
Source Conductor
voltage
Current
Thermal Condition(Conditions)
Imported Load(Result File) Electric Charge
Voltage(Ground)
Surface Charge Density
Volume Charge Density Snecma(Imported Loads)
Body Force Density (Imported Loads)
Body Temperature (Imported Loads)
Thermal Condition(Imported Loads)
Displacement(Imported Loads)
Cut Boundary Constraint(Imported Loads)
Cut Boundary Remote Force(Imported Loads)
Cut Boundary Remote Constraint(Imported Loads) Force(Imported Loads)
Pressure(Imported Loads)
Surface Force Density(Imported Loads)
Velocity(Imported Loads)
Convection Coefficient(Imported Loads)
Heat Flux(Imported Loads)
Heat Generation (Imported Loads)
Temperature(Imported Loads)
Initial Stress(Imported Loads)
Initial Strain (Imported Loads)
Thickness (Imported Loads) validation
Smooth Contours(Variable Data)
Contour Bands(Variable Data)
Isolines(Variable Data)
single(Isoline Thickness)
Double(Isoline Thickness)
Triple(Isoline Thickness)
Maximum
Minimum
Drop Test Wizard
Co-simulation Pin
Write Input File...
Export Nastran File
Manage Loads.. (Beta)
Keyword Manager(Beta) Worksheet
Graph
Tabular Data
Body Views
Sync Views
Key assignments:
Assign
Remove
Reset All
Description: Jse the Physics Region object to specify the geometry bodies belonging to the single or applicable combination of physics types such as
Structural,Acoustics and Thermal etc.
Category:
Commands:
Body-Body(Spring)
Body-Ground (Beam)
Body-Body(Beam)
End Release
Interstage
Bonded(Contact)
Frictional(Contact)
Rough(Contact)
Contact Tool
slot (Body-Ground)
Planar(Body-Ground)
Screw (Body-Ground)
Fixed (Body-Body)
Revolute(Body-Body)
slot(Body-Body)
Planar(Body-Body)
General(Body-Body)
Parallel(Body-Body)
In-Plane(Body-Body)
In-Line(Body-Body)
Bushing(Body-Body)
Screw(Body-Body)
Distance(Body-Body)
Revert
Body Views
Key assignments:
Assign
Remove
Reset All
Category:
Physics Region 人
Remote Force(Loads)
Joint Load(Loads)
Moment
Pressure
velocity(Supports)
Fixed
Frictionless
Displacement
Excusion Region
Objective
Heat Flow(Heat)
Heat Flux(Heat)
Source Conductor
voltage
Current
Voltage(Ground)
Maximum
Minimum
Drop Test Wizard
Co-simulation Pin
Write Input File...
Export Nastran File
Graph
Tabular Data
Body Views
Sync Views
Key assignments:
Assign
Remove
Reset All
Category:
Context Tab-Solution(Main)
Commands:
Total Deformation(Deformation) △
Total(Deformation)
Directional(Deformation)
Total Velocity(Deformation)
Directional Velocity(Deformation)
Total Acceleration(Deformation)
Directional Acceleration(Deformation)
Equivalent(von-Mises)(Strain)
Maximum Principal(Strain)
Middle Principal(Strain)
Minimum Principal(Strain)
Maximum Shear(Strain)
Intensity(Strain)
Normal (Strain)
shear(Strain)
Vector Principal(Strain)
Thermal (Strain)
Equivalent Plastic(Strain)
Equivalent Creep(Strain)
Equivalent Total (Strain)
Accumulated Equivalent Plastic(Strain)
Equivalent(von-Mises)(Stress)
Maximum Principal(Stress)
Middle Principal(Stress)
Minimum Principal (Stress)
Maximum Shear(Stress)
Intensity(Stress)
Normal(Stress)
Shear(Stress)
Vector Principal(Stress)
Error(Stress)
Membrane Stress(Stress)
Bending Stress(Stress)
Bottom Peak Stress (Beta)(Stress)
Top Peak Stress (Beta)(Stress)
Stabilization Energy(Energy)
Strain Energy(Energy)
Mulins Damage Variable(Damage)
Mulins Max Previous Strain Energy(Damage) Max Failure Criteria(Damage)
Fiber Tensile Failure Criterion(Damage)
Fiber Compressive Failure Criterion (Damage) Matrix Tensile Failure Criterion(Damage)
Matrix Compressive Failure Criterion(Damage) Damage Status(Damage)
Fiber Tensile Damage Variable(Damage)
Fiber Compressive Damage Variable(Damage) Matrix Tensile Damage Variable(Damage)
Matrix Compressive Damage Variable(Damage) shear Damage Variable(Damage)
Energy Dissipated Per Unit Volume(Damage) Equivalent(von-Mises)(Linearized Stress)
Maximum Principal (Linearized Stress) Middle Principal(Linearized Stress)
Minimum Principal (Linearized Stress) Maximum Shear (Linearized Stress) Intensity (Linearized Stress)
Normal (Linearized Stress)
Normal Gasket Pressure(Gasket)
shear Gasket Pressure(Gasket)
Normal Gasket Total Closure(Gasket) shear Gasket Total Closure(Gasket) Gasket Line Pressure(Beta)(Gasket) Pressure(Acoustics)
Total Velocity(Acoustics)
Directional Velocity(Acoustics)
Kinetic Energy(Acoustics)
Potential Energy(Acoustics)
Temperature(Thermal)
Total Heat Flux(Thermal)
Directional Heat Flux(Thermal) Error (Thermal)
Fluid Flow Rate (Thermal)
Fluid Heat Conduction Rate(Thermal) Volume
Shape Finder
Electric Potential (Electromagnetic)
Total Magnetic Flux Density(Electromagnetic)
Directional Magnetic Flux Density(Electromagnetic) Total Magnetic Field Intensity (Electromagnetic)
Directional Magnetic Field Intensity (Electromagnetic) Total Force(Electromagnetic)
Directional Force(Electromagnetic)
Current Density (Electromagnetic)
Inductance(Electromagnetic)
Flux Linkage(Electromagnetic)
Error (Electromagnetic)
Electric Voltage (Electric)
Total Electric Field Intensity(Electric)
Directional Electric Field Intensity (Electric)
Total Current Density(Electric)
Directiona Current Density(Electric)
Total Electric Flux Density (Electric)
Directional Electric Flux Density (Electric)
Joule Heat(Electric)
Directional Magnetic Field Intensity (Electromagnetic) Total Electric Field Intensity (Electromagnetic)
Directional Electric Field Intensity(Electromagnetic) Current Density (Electromagnetic)
Topology Density
Topology Elemental Density Lattice Density
Lattice Elemental Density Smoothing
DA Result
Nodal Triads(Coordinate Systems)
Nodal Euler XY Angle(Coordinate Systems)
Nodal Euler YZ Angle(Coordinate Systems)
Nodal Euler XZ Angle(Coordinate Systems) Elemental Triads(Coordinate Systems)
Elemental Euler XY Angle(Coordinate Systems)
Elemental Euler YZ Angle(Coordinate Systems)
Elemental Euler XZ Angle(Coordinate Systems) User Defined Result
Python Result
Primary Criterion
Composite Criterion Deformation(Probe)
Strain(Probe)
Stress(Probe)
Position(Probe)
Rotation(Beta)(Probe)
Flexible Rotation (Probe)
velocity (Probe)
Angular Velocity (Probe)
Acceleration(Probe)
Angular Acceleration(Probe)
Energy(Probe)
Volume(Probe)
Force Reaction(Probe)
Moment Reaction (Probe)
Joint (Probe)
Spring(Probe)
Bearing(Probe)
Beam(Probe)
Bolt Pretension(Probe)
Generalized Plane Strain(Probe)
Response PSD(Probe)
Temperature(Probe)
Heat Flux(Probe)
Reaction (Probe)
Radiation(Probe)
Charge Reaction(Electric Probe)
Electromechanical Coupling Coefficient(Electric Probe)
Volume
Flux Density(Probe)
Field Intensity (Probe)
Force Summation(Probe)
Torque(Probe)
Energy(Probe)
Magnetic Flux(Probe)
Electric Voltage(Probe)
Field Intensity(Probe)
Current Density(Probe)
Reaction(Probe)
Joule Heat(Probe)
Current Reaction(Probe)
Heat Reaction(Probe) Contact Tool
Stress Tool(Toobox)
Fatigue Tool (Toolbox)
Contact Tool (Toolbox)
Bolt Tool (Toolbox)
Beam Tool (Toolbox)
Fracture Tool(Toobox)
Composite Failure Tool (Toolbox) Response PSD Tool (Toolbox)
Expansion Settings (Toolbox)
Axial Force(Beam Results)
Bending Moment(Beam Results) Torsional Moment(Beam Results) Shear Force(Beam Results)
shear-Moment Diagram(Beam Results) Campbell Diagram
Write Input File...
Read Result Files. Worksheet
Graph
Tabular Data
Fiber (Direction)
Transverse (Direction) Normal (Direction)
Element Reference(Direction)
Element Normal(Direction)
Key assignments:
ssign
Remove
Reset All
Description: Total deformation generated from bending loads.
Category:
Context Tab-ConnectionsCommands:Key assignments:Connection GroupWeld Group(Beta)Body-Ground (Spring)Body-Body(Spring)Body-Ground (Beam)Body-Body(Beam)Body-Ground(Bearing)Body-Body(Bearing)Spot WeldEnd ReleaseBody InteractionAM BondInterstageBonded(Contact)No Separation(Contact)Frictionless(Contact)Frictional(Contact)Rough(Contact)Forced Frictional(Contact)Contact ToolSolution InformationFixed(Body-Ground)Revolute(Body-Ground)cylindrical (Body-Ground)Translational(Body-Ground)slot (Body-Ground)Universal(Body-Ground)Spherical (Body-Ground)Planar(Body-Ground)General(Body-Ground)Parallel (Body-Ground)In-Plane (Body-Ground)In-Line(Body-Ground)Orientation(Body-Ground)Bushing(Body-Ground)In-Plane Radial Gap(Body-Ground)Spherical Gap (Body-Ground)Radial Gap(Body-Ground)General(Samcef)(Body-Ground)Bushing(Samcef)(Body-Ground)Screw (Body-Ground)Constant Velocity(Body-Ground)Distance(Body-Ground)Fixed (Body-Body)Revolute(Body-Body)Cylindrical (Body-Body)Translational(Body-Body)slot(Body-Body)Universal(Body-Body)Spherical(Body-Body)Planar(Body-Body)General(Body-Body)Parallel(Body-Body)InPlane(Body-Body)In-Line(Body-Body)Orientation(Body-Body)Bushing(Body-Body)Point On Curve(Body-Body)In-Plane Radial Gap(Body-Body)Spherical Gap(Body-Body)Radial Gap(Body-Body)General(Samcef)(Body-Body)Bushing(Samcef)(Body-Body)Screw(Body-Body)Constant Velocity(Body-Body)Distance(Body-Body)ConfigureAssembleSetRevertCo-simulation PinWorksheetBody ViewsPress new shortcut key:Sync Views
Description:
Assign
Remove
Reset All
inserta Connections group folder.Use this folder to add various contact-based features as well as to automatically generate Contact orJoint objects for the whole model or for a group of bodies.
Category:
Key assignments:
Commands:
Physics RegionAcceleration (Inertial)Standard Earth Gravity (Inertial)Rotational Velocity(Inertial)Rotational Acceleration (Inertial)Mass Source(Acoustic Excitations)Surface Velocity(Acoustic Excitations)Diffuse Sound Field(Acoustic Excitations)Incident Wave Source(Acoustic Excitations)Port In Duct(Acoustic Excitations)Mass Source Rate(Acoustic Excitations)Surface Acceleration(Acoustic Excitations)Temperature(Acoustic Loads)Impedance Sheet(Acoustic Loads)Static Pressure(Acoustic Loads)Pressure(Acoustic Boundary Conditions)Impedance Boundary(Acoustic Boundary Conditions)Absorption Surface(Acoustic Boundary Conditions)Radiation Boundary(Acoustic Boundary Conditions)Absorption Element(Acoustic Boundary Conditions)Free Surface(Acoustic Boundary Conditions)Thermo-Viscous BLI Boundary(Acoustic Boundary ConditiorRigid Wall (Acoustic Boundary Conditions)Symmetry Plane(Acoustic Boundary Conditions)Port(Acoustic Boundary Conditions)Far-field Radiation Surface(Acoustic Boundary Conditions)Transfer Admittance Matrix(Acoustic Models)Low Reduced Frequency Model (Acoustic Models)Pipe Pressure (Loads)Hydrostatic Pressure(Loads)Remote Force(Loads)Bearing Load (Loads)Bolt Pretension (Loads)Generalized Plane Strain(Loads)Line Pressure(Loads)Thermal Condition(Loads)Pipe Temperature (Loads)Joint Load(Loads)Fluid Solid Interface (Loads)System Coupling Region (Loads)Rotating Force(Loads)Detonation Point(Loads)Imported CFD Pressure(Loads)Imported Remote Loads (Loads)ForceMomentPressureRemote Displacement(Supports)velocity(Supports)Impedance Boundary(Supports)Limit Boundary(Supports)Compression Only Support(Supports)Cylindrical Support(Supports)Simply Supported(Supports)Fixed Rotation(Supports)Elastic Support(Supports)FixedFrictionlessDisplacementCoupling(Conditions)voltage Coupling(Conditions)Constraint Equation(Conditions)Pipe Idealization(Conditions)Nonlinear Adaptive Region(Conditions)Element Birth and Death(Conditions)Contact Step Control(Conditions)Body Control(Conditions)Plastic Heating(Conditions)Viscoelastic Heating(Conditions)Nodal Orientation (Direct FE)Nodal Force(DirectFE)Nodal Pressure(Direct FE)Nodal Displacement (Direct FE)NodalRotation(Direct FE)EM Transducer(Direct FE)Optimization RegionExcusion RegionObjectiveVolume Constraint(Response Constraint)Mass Constraint (Response Constraint)Center of Gravity Constraint(Response Constraint)Moment of Inertia Constraint(Response Constraint)Compliance Constraint(Response Constraint)Displacement Constraint (Response Constraint)Reaction Force Constraint(Response Constraint)Global Stress Constraint(Response Constraint)Local von-Mises Stress Constraint(Response Constraint)Natural Frequency Constraint(Response Constraint)Dynamic Compliance Constraint(Response Constraint)Thermal Compliance Constraint(Response Constraint)Temperature Constraint (Response Constraint)Criterion Constraint(Response Constraint)Member Size(Manufacturing Constraint)Pull Out Direction(Manufacturing Constraint)Extrusion(Manufacturing Constraint)AM Overhang Constraint(Manufacturing Constraint)Cyclic Repetition(Design Constraint)Symmetry(Design Constraint)Uniform(Design Constraint)Pattern Repetition(Design Constraint)
Attribute GroupTemperatureConvectionRadiationHeat Flow(Heat)Perfectly Insulated (Heat)Heat Flux(Heat)Internal Heat Generation(Heat)Mass Flow RateCoupling(Conditions)Fluid Solid Interface(Conditions)System Coupling Region(Conditions)Magnetic Flux ParallelSource ConductorvoltageCurrentThermal Condition(Conditions)Imported Load(Result File)Electric ChargeVoltage(Ground)Surface Charge DensityVolume Charge DensitySnecma(Imported Loads)Body Force Density (Imported Loads)Body Temperature (Imported Loads)Thermal Condition(Imported Loads)Displacement(Imported Loads)Cut Boundary Constraint(Imported Loads)Cut Boundary Remote Force(Imported Loads)Cut Boundary Remote Constraint(Imported Loads)Force(Imported Loads)Pressure(Imported Loads)Surface Force Density(Imported Loads)Velocity(Imported Loads)Convection Coefficient(Imported Loads)Heat Flux(Imported Loads)Heat Generation (Imported Loads)Temperature(Imported Loads)Initial Stress(Imported Loads)Initial Strain (Imported Loads)Thickness (Imported Loads)validationSmooth Contours(Variable Data)Contour Bands(Variable Data)Isolines(Variable Data)single(Isoline Thickness)Double(Isoline Thickness)Triple(Isoline Thickness)MaximumMinimumDrop Test WizardCo-simulation PinWrite Input File...Export Nastran FileManage Loads...(Beta)Keyword Manager(Beta)WorksheetGraphTabular DataBody ViewsPress new shortcut key:Sync Views
Description:
Assign
Remove
Reset All
Use the Physics Region object to specify the geometry bodies belonging to the single or applicable combination of physics types such asStructural,Acoustics and Thermal etc.
Category:
Key assignments:
Commands:
Total Deformation(Deformation)Total(Deformation)Directional(Deformation)Total Velocity(Deformation)Directional Velocity(Deformation)Total Acceleration(Deformation)Directional Acceleration(Deformation)Equivalent(von-Mises)(Strain)Maximum Principal(Strain)Middle Principal(Strain)Minimum Principal(Strain)Maximum Shear(Strain)Intensity(Strain)Normal (Strain)shear(Strain)Vector Principal(Strain)Thermal (Strain)Equivalent Plastic(Strain)Equivalent Creep(Strain)Equivalent Total (Strain)Accumulated Equivalent Plastic(Strain)Equivalent(von-Mises)(Stress)Maximum Principal(Stress)Middle Principal(Stress)Minimum Principal (Stress)Maximum Shear(Stress)Intensity(Stress)Normal(Stress)Shear(Stress)Vector Principal(Stress)Error(Stress)Membrane Stress(Stress)Bending Stress(Stress)Bottom Peak Stress (Beta)(Stress)Top Peak Stress (Beta)(Stress)Stabilization Energy(Energy)Strain Energy(Energy)Mulins Damage Variable(Damage)Mulins Max Previous Strain Energy(Damage)Max Failure Criteria(Damage)Fiber Tensile Failure Criterion(Damage)Fiber Compressive Failure Criterion (Damage)Matrix Tensile Failure Criterion(Damage)Matrix Compressive Failure Criterion(Damage)Damage Status(Damage)Fiber Tensile Damage Variable(Damage)Fiber Compressive Damage Variable(Damage)Matrix Tensile Damage Variable(Damage)Matrix Compressive Damage Variable(Damage)shear Damage Variable(Damage)Energy Dissipated Per Unit Volume(Damage)Equivalent(von-Mises)(Linearized Stress)Maximum Principal (Linearized Stress)Middle Principal(Linearized Stress)Minimum Principal (Linearized Stress)Maximum Shear (Linearized Stress)Intensity (Linearized Stress)Normal (Linearized Stress)Shear (Linearized Stress)Normal Gasket Pressure(Gasket)shear Gasket Pressure(Gasket)Normal Gasket Total Closure(Gasket)shear Gasket Total Closure(Gasket)Gasket Line Pressure(Beta)(Gasket)Pressure(Acoustics)Total Velocity(Acoustics)Directional Velocity(Acoustics)Kinetic Energy(Acoustics)Potential Energy(Acoustics)Temperature(Thermal)Total Heat Flux(Thermal)Directional Heat Flux(Thermal)Error (Thermal)Fluid Flow Rate (Thermal)Fluid Heat Conduction Rate(Thermal)VolumeShape FinderElectric Potential (Electromagnetic)Total Magnetic Flux Density(Electromagnetic)Directional Magnetic Flux Density(Electromagnetic)Total Magnetic Field Intensity (Electromagnetic)Directional Magnetic Field Intensity (Electromagnetic)Total Force(Electromagnetic)Directional Force(Electromagnetic)Current Density (Electromagnetic)Inductance(Electromagnetic)Flux Linkage(Electromagnetic)Error (Electromagnetic)Electric Voltage (Electric)Total Electric Field Intensity(Electric)Directional Electric Field Intensity (Electric)Total Current Density(Electric)Directiona Current Density(Electric)Total Electric Flux Density (Electric)Directional Electric Flux Density (Electric)Joule Heat(Electric)Total Magnetic Field Intensity (Electromagnetic)Directional Magnetic Field Intensity (Electromagnetic)Total Electric Field Intensity (Electromagnetic)Directional Electric Field Intensity(Electromagnetic)
Current Density (Electromagnetic)Topology DensityTopology Elemental DensityLattice DensityLattice Elemental DensitySmoothingDA ResultNodal Triads(Coordinate Systems)Nodal Euler XY Angle(Coordinate Systems)Nodal Euler YZ Angle(Coordinate Systems)Nodal Euler XZ Angle(Coordinate Systems)Elemental Triads(Coordinate Systems)Elemental Euler XY Angle(Coordinate Systems)Elemental Euler YZ Angle(Coordinate Systems)Elemental Euler XZ Angle(Coordinate Systems)User Defined ResultPython ResultPrimary CriterionComposite CriterionDeformation(Probe)Strain(Probe)Stress(Probe)Position(Probe)Rotation(Beta)(Probe)Flexible Rotation (Probe)velocity (Probe)Angular Velocity (Probe)Acceleration(Probe)Angular Acceleration(Probe)Energy(Probe)Volume(Probe)Force Reaction(Probe)Moment Reaction (Probe)Joint (Probe)Spring(Probe)Bearing(Probe)Beam(Probe)Bolt Pretension(Probe)Generalized Plane Strain(Probe)Response PSD(Probe)Temperature(Probe)Heat Flux(Probe)Reaction (Probe)Radiation(Probe)Charge Reaction(Electric Probe)Electromechanical Coupling Coefficient(Electric Probe)VolumeFlux Density(Probe)Field Intensity (Probe)Force Summation(Probe)Torque(Probe)Energy(Probe)Magnetic Flux(Probe)Electric Voltage(Probe)Field Intensity(Probe)Current Density(Probe)Reaction(Probe)Joule Heat(Probe)Current Reaction(Probe)Heat Reaction(Probe)Contact ToolStress Tool(Toobox)Fatigue Tool (Toolbox)Contact Tool (Toolbox)Bolt Tool (Toolbox)Beam Tool (Toolbox)Fracture Tool(Toobox)Composite Failure Tool (Toolbox)Response PSD Tool (Toolbox)Expansion Settings (Toolbox)Axial Force(Beam Results)Bending Moment(Beam Results)Torsional Moment(Beam Results)Shear Force(Beam Results)shear-Moment Diagram(Beam Results)Campbell DiagramWrite Input File...Read Result Files.WorksheetGraphTabular DataFiber (Direction)Transverse (Direction)Normal (Direction)Element Reference(Direction)Press new shortcut key:Element Normal(Direction)
Description:
ssign
Remove
Reset All
Category:
Commands:Key assignments:Previous人Nextshaded Exterior and EdgesShaded ExteriorWireframeShow MeshBounding Mesh Edges (beta)Rotate About Axis(Rotate)Free Rotate(Rotate)PanZoomBox ZoomZoom To FitZoom To SelectionToggle Magnifier Window On/OffSingle Select (Mode)Box Select(Mode)Box Volume Select(Mode)Lasso Select(Mode)Lasso Volume Select(Mode)Smart SelectVertexEdgeFaceBodyNodeElement FaceElementHit Point CoordinateLabelImported Data HighightDirectionAIlInvertAdd Selection to Clipboard(Clipboard)Remove Selection from Clipboard(Clipboard)Clear Clipboard(Clipboard)Select Items in Clipboard(Clipboard)Add Clipboard to Selection(Clipboard)Remove Clipboard from Selection(Clipboard)Adjacent(Extend)Limits(Extend)Connection(Extend)Instances(Extend)Mesh by Id(Select By)Select All Entities With the Same X Location(Location)Select All Entities With the Same YLocation (Location)Select AllEntities With the Same Z Location(Location)Select All Coplanar Entities With the Same XLocation (LocaSelect All Coplanar Entities With the Same YLocation (LocaSelect All Coplanar Entities With the Same Z Location(LocaSelect All Entities With the Same Size(Size)Select All Entities Smaller than Selection (Size)Select All Entities Smaller than.…(Size)Select All Entities Larger than Selection(Size)Select All Entities Larger than…(Size)Common Edges(Select By)Cylindrical Faces(Select By)All Vertices(Shared Topology)AIl Edges(Shared Topology)All Faces(Shared Topology)Same Material (Select By)Grow Element(Select By)Bodies(Convert)Faces(Convert)Edges(Convert)Vertices(Convert)Nodes(Convert)Elements(Convert)StartFirstPreviousNextLastReselect AllOne Viewport(Viewports)Two Horizontal Viewports(Viewports)Two Vertical Viewports(Viewports)Four Viewports(Viewports)Sync ViewportsFrontBackRightLeftTopBottomPress new shortcut key:Look At
Graphics Toobar
Description:
Assign
Bemove
Reset All
Scrollthrough the previously used views.
