ABAQUS能量平衡输出变量
Total energy output quantities
“Artificial” strain energy associated with constraints used to remove singular modes (such as hourglass control), and with constraints used to make the drill rotation follow the in-plane rotation of the shell elements.
ALLCD
Energy dissipated by creep, swelling, and viscoelasticity.
ALLEE
ALLFD
Total energy dissipated through frictional effects. (Available only for the whole model.)
ALLIE
Total strain energy. (ALLIE = ALLSE + ALLPD + ALLCD + ALLAE + ALLQB + ALLEE + ALLDMD.)
ALLJD
Electrical energy dissipated due to flow of electrical current.
ALLKE
Loss of kinetic energy at impact. (Available only for the whole model.)
ALLPD
Energy dissipated by rate-independent and rate-dependent plastic deformation.
Energy dissipated through quiet boundaries (infinite elements). (Available only for the whole model.)
ALLSD
Energy dissipated by automatic stabilization. This includes both volumetric static stabilization and automatic approach of contact pairs (the latter part included only for the whole model).
ALLSE
Recoverable strain energy.
Energy dissipated by viscous effects, not inclusive of energy dissipated by automatic stabilization and viscoelasticity.
Energy dissipated by damage
External work. (Available only for the whole model.)
Total energy balance (available only for the whole model). (ETOTAL = ALLKE + ALLIE + ALLVD + ALLSD + ALLKL + ALLFD + ALLJD – ALLWK.
Solution-dependent amplitude variables
Solution-dependent amplitude variables are given automatically with any file output or output database request.
LPF
Load proportionality factor in a static Riks analysis.
AMPCU
Current value of the solution-dependent amplitude.
RATIO
Current maximum ratio of creep strain rate and target creep strain rate.
Attributes: |
1 – Total kinetic energy (ALLKE). |
2 – Total recoverable (elastic) strain energy (ALLSE). |
3 – Total external work (ALLWK, available only for the whole model.) |
4 – Total plastic dissipation (ALLPD). |
5 – Total creep dissipation (ALLCD). |
6 – Total viscous dissipation, not including dissipation due to stabilization (ALLVD). |
7 – Total loss of kinetic energy at impacts (ALLKL, available only for the whole model). |
8 – Total artificial strain energy (ALLAE). |
9 – Total energy dissipated through quiet boundaries (ALLQB, available only for the whole model). |
10 – Total electrostatic energy (ALLEE). |
11 – Total strain energy (ALLIE). |
12 – Total energy balance (ETOTAL, available only for the whole model). |
13 – Total energy dissipated through frictional effects (ALLFD, available only for the whole model). |
14 – Total electrical energy dissipated in conductors (ALLJD). |
15 – Total static dissipation (due to stabilization, ALLSD). |
16 – Total damage dissipation (ALLDMD). |
17 – Currently not used. |
18 – Currently not used. |
