HyperView二次开发实例1
HyperView二次开发实例1
以下Tcl脚本用于在HyperView中加载和显示结果云图。
#设置名称
set proc_name "contour_stress"
#获得Session对象,名称为sess
hwi GetSessionHandle sess
 #catchC++的类似,用于处理异常
if {[catch {
 sess GetProjectHandle proj
 proj GetPageHandle page [proj GetActivePage]
 proj ReleaseHandle
 page GetWindowHandle win [page GetActiveWindow]
 win SetClientType "Animation"
 win GetClientHandle post
 win ReleaseHandle
 #以上几行获得各级对象,winwindows对象
 # AddModel在窗口中添加对象,对象的id号存储给model_id
 set model_id [post AddModel d:/samples/dyna/bumper_foam/d3plot"]
#得到Model Handle
 post GetModelHandle mod $model_id
#给这个模型设置结果,不同求解器对于不同的结果类型
 mod SetResult "d:/samples/dyna/bumper_foam/d3plot"
#得到Animationor Handle
 page GetAnimatorHandle animator
#指定frame
 animator Next
 #得到result Handle
 mod GetResultCtrlHandle res
 mod ReleaseHandle
#得到ContourCtr Handle
 res GetContourCtrlHandle contour_ctrl
 res ReleaseHandle
 contour_ctrl SetEnableState true
#设置结果显示方式为云图显示
 post SetDisplayOptions "contour" true
 #设置结果类型为 stress
 contour_ctrl SetDataType "stress"
 contour_ctrl SetShellLayer "max"
 contour_ctrl SetDimensionEnabled shell true
 contour_ctrl SetDataComponent shell "P1"
 contour_ctrl SetDimensionEnabled solid true
 contour_ctrl SetDataComponent solid "P1"
#设置完成后需要通过draw生成
 post Draw
#释放handle
 contour_ctrl ReleaseHandle
 post ReleaseHandle
 page ReleaseHandle
 sess ReleaseHandle
} result]}
 # Error handling
 puts $logfile "----- Error occured running $proc_name -----"
 puts $logfile "[sess GetError]"
 puts $logfile "--------------------------------------------"
