基于LS-DYNA的复合材料内聚力失效仿真(双臂梁,隐式求解)
以DCB复合材料双悬臂梁实验为研究对象,基于LS-DYNA隐式算法+内聚力单元(MAT138),给出了完整的k文件!
                                      裂纹尖端的应力云图
基于LS-DYNA的复合材料内聚力失效仿真(双臂梁,隐式求解)的图2
                                     内聚界面的损伤演化
求解设置:
    内聚力单元采用了mat138
    复合材料体系和几何特征为:
    AS4/PEEK carbon fiber reinforced composite was simulated and compared with available beam
theory solutions. The specimen length, L, is given in Fig. 6 and 20.0 mm wide with two, 2h, 1.55
mm-thick arms, the latter providing a mode mixity of G II /G T = 43% for the FRMM models. The
initial delamination length is a 0 = 35 mm. The material properties of the AS4/PEEK specimen are
as follows: E 11 = 120 GPa, E 22 = E 33 = 11 GPa, ν 12 = ν 13 = 0.32, ν 23 = 0.45, G 12 = G 13 = 5.5 GPa,and G 23 = 3.7 GPa. The properties of the interface are given in Table 3. The average size of thecontinuum and cohesive elements in the direction of crack propagation is 0.5 mm
隐式求解设置:
基于LS-DYNA的复合材料内聚力失效仿真(双臂梁,隐式求解)的图3
*CONTROL_ENERGY
$#    hgen      rwen    slnten     rylen
         2         2         2         2
*CONTROL_TIMESTEP
$#  dtinit    tssfac      isdo    tslimt     dt2ms      lctm     erode     ms1st
       0.0       0.9         0       0.0       0.0         0         0         0
$#  dt2msf   dt2mslc     imscl    unused    unused     rmscl
       0.0         0         0                           0.0
*CONTROL_IMPLICIT_GENERAL
$#  imflag       dt0    imform     nsbs       igs     cnstn      form
         1      0.01
*CONTROL_IMPLICIT_SOLUTION
$  nlsolvr    ilimit    maxref     dctol     ectol     rctol     lstol
         0         0         0      0.00      0.00         0         0
$    dnorm   divflag   inistif   nlprint
         1         0         0         0
*CONTROL_IMPLICIT_AUTO
$    iauto    iteopt    itewin     dtmin     dtmax
         1       50         20      1E-6      0.02
*CONTROL_IMPLICIT_STABILIZATION
$      ias     scale    tstart      tend
         1      0.00         0         0
*DATABASE_BINARY_D3PLOT
0.5000E-02
*CONTROL_TERMINATION
$$  ENDTIM    ENDCYC     DTMIN    ENDENG    ENDMAS     NOSOL
         1         0       0.0       0.0       0.0
计算结果和理论的对比:
   基于LS-DYNA的复合材料内聚力失效仿真(双臂梁,隐式求解)的图4
以下内容为付费内容,请购买后观看
   9人购买
5
15
