我的显卡不能开OPENGL 模式!请教高手!
浏览:303776 回答:4
我想玩荣誉勋章2,可是我的opengl模式打不开.我的显卡是NVIDIA RIVA TNT2 Model64/Model64 Pro 想知道那里可以下载支持openGL模式驱动?
另外,我照网上说的地址去下了,还是不行,是不是显卡要设置一下模式啊?请教了!谢谢
下面是我启动游戏后,出现问题后的提示!
--- Common Initialization ---
Medal of Honor Allied Assault 1.11 win-x86 Apr 19 2002
----- FS_Startup -----
Current search path:
C:\Mohaa_spearhead/main
C:\Mohaa_spearhead\main\pak7tc1.pk3 (51 files)
C:\Mohaa_spearhead\main\pak7tc.pk3 (225 files)
C:\Mohaa_spearhead\main\pak6tc.pk3 (64 files)
C:\Mohaa_spearhead\main\pak5fix.pk3 (106 files)
C:\Mohaa_spearhead\main\Pak5.pk3 (259 files)
C:\Mohaa_spearhead\main\pak4.pk3 (593 files)
C:\Mohaa_spearhead\main\pak3.pk3 (669 files)
C:\Mohaa_spearhead\main\pak2.pk3 (4722 files)
C:\Mohaa_spearhead\main\pak1.pk3 (772 files)
C:\Mohaa_spearhead\main\Pak0.pk3 (11175 files)
18636 files in pk3 files
execing default.cfg
execing menu.cfg
execing newconfig.cfg
Config: unnamedsoldier.cfg
execing configs/unnamedsoldier.cfg
couldn't exec localized.cfg
execing autoexec.cfg
Unknown command "fov"
couldn't exec custom.cfg
...detecting CPU, found Intel Pentium III
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
------- Input Initialization Complete ------- 72
You are now setup for easy mode.
----- Client Initialization -----
Called FadeSound with: 0.000000
----- Initializing Renderer ----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\System32\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using colorsbits of 16
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...GLW_ChoosePFD failed
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
GLW_StartOpenGL() - could not load OpenGL subsystem
下面是我启动游戏后,出现问题后的提示!
execing default.cfg
execing menu.cfg
----- R_Init -----
...initializing QGL
...calling CDS: ok
...35 PFDs found
...35 PFDs found
...initializing QGL
![[免费案例]Pointwise官方英文系列教程](https://img.jishulink.com/cimage/72f86490b660eb7861b5bd63702c26e0.jpg?image_process=resize,fw_576,fh_320,)
![[案例专题]基于Pointwise的M6机翼黏性网格生成实例](https://img.jishulink.com/cimage/4585056150f952b8a96c6f386e0f0917.jpg?image_process=resize,fw_576,fh_320,)
