接触分析
浏览:71624
*** ERROR *** CP = 118.969 TIME= 16:58:45
The normal of target element 157006 is not consistent with the normal
of target element 168294. Using ENORM command to correct it.
使用ENORM命令出现这种错误提示;
*** WARNING *** CP = 127.594 TIME= 17:03:06
No shell element normals were reversed because no selected elements
are adjacent to the starting element.
the starting element. 指的是哪一个单元?
