流固耦合问题
浏览:41962 回答:1
*** WARNING *** CODE ADF6033:
Absolute residual 1.98E+21 of velocity is too large.
Absolute residual 2.90E+23 of pressure is too large.
Absolute residual 1.33E+24 of temperature is too large.
Absolute residual 1.31E+46 of velocity is too large.
Absolute residual 9.12E+51 of pressure is too large.
Absolute residual 1.51E+51 of temperature is too large.
*** WARNING *** CODE ADF6064:
Fluid model could be wrong! The factorized diagonal 0.0000E+00 of
equation 6567 is too small.
A constant pivot has been assigned to this equation.
equation 6531 is too small.
equation 6511 is too small.
equation 6138 is too small.
*** WARNING *** CODE ADF6065:
Fluid model could be unstable! The factorized diagonal NaN of
equation 6133 is too small.
equation 6512 is too small.
equation 6530 is too small.
equation 6535 is too small.
equation 6589 is too small.
equation 6590 is too small.
equation 6494 is too small.
equation 6499 is too small.
equation 6517 is too small.
Too many error/warning messages for code number ADF6065 have been
encountered.
equation 1108 is too small.
equation 1113 is too small.
*** ERROR *** CODE ADF2005:
Iteration limit is reached without convergence.
Equilibrium is not established from time: 0.00000E+00
to time: 1.00000E-05
Here are some suggestions for improving convergence:
* Resolve all error/warning messages.
* Use proper units to avoid machine round-off errors.
* Apply a proper force or displacement relaxation factor in
fluid-structure interaction analyses.
* Use a proper CFL number in automatic time stepping method.
* In transient analyses, use smaller time steps.
* In steady-state analyses, incrementally apply loads (prescribed
velocities, normal-tractions, etc.) step-by-step, or/and use
time-dependent materials, starting with easier material values and
eventually approaching to the real values.
* In transient analyses of fluid-structure interactions, a good initial
condition of fluid variable is crucial. One can achieve that by
using a very large fictitious first time step, which provides a good
initial condition for the really transient analyses starting at
second time step. One can also achieve that by using a restart run,
in which the (steady-state) result of first run provides initial
conditions for the (transient) analysis in the second run.
*** ERROR *** CODE ADF3044:
Unsuccessful in fluid model for fluid-structure interaction. Last status
in fluid model is "COMPUTE ".
encountered.
我困惑了很久了
郁闷啊
