请教:f06文件FATAL MESSAGE 5270 (ETETGD)
浏览:52821
我想计算在某个扭矩下花键齿根应力
将UG中画的花键实体模型倒入Patran,自动画网格,约束:端面固定,花键节圆加载CID Distributed Load,计算:fo6错误:FATAL MESSAGE 5270 (ETETGD),请问这个错误原因是什么?请高手指教,谢谢!
*** USER FATAL MESSAGE 5270 (ETETGD)
ZERO ELEMENT VOLUME DETECTED FOR ELEMENT WITH ID = 412648
ZERO ELEMENT VOLUME DETECTED FOR ELEMENT WITH ID = 412664
TETRA 412669 8.05 0.05 151.31 FAIL N/A- ONLY 4 NODE N/A- ONLY 4 NODE NO TEST N/A- ONLY 4 NODE
TETRA 412675 7.99 0.00 ********* FAIL N/A- ONLY 4 NODE N/A- ONLY 4 NODE NO TEST N/A- ONLY 4 NODE
ZERO ELEMENT VOLUME DETECTED FOR ELEMENT WITH ID = 412685
TETRA 412690 9.99 0.04 278.78 FAIL N/A- ONLY 4 NODE N/A- ONLY 4 NODE NO TEST N/A- ONLY 4 NODE
TETRA 412695 9.99 0.00 ********* FAIL N/A- ONLY 4 NODE N/A- ONLY 4 NODE NO TEST N/A- ONLY 4 NODE
TETRA 412709 3.03 0.00 ********* FAIL N/A- ONLY 4 NODE N/A- ONLY 4 NODE NO TEST N/A- ONLY 4 NODE
TETRA 412711 10.03 0.04 280.00 FAIL N/A- ONLY 4 NODE N/A- ONLY 4 NODE NO TEST N/A- ONLY 4 NODE
TETRA 412724 3.03 0.00 ********* FAIL N/A- ONLY 4 NODE N/A- ONLY 4 NODE NO TEST N/A- ONLY 4 NODE
ZERO ELEMENT VOLUME DETECTED FOR ELEMENT WITH ID = 412729
TETRA 412731 10.05 0.09 108.53 FAIL N/A- ONLY 4 NODE N/A- ONLY 4 NODE NO TEST N/A- ONLY 4 NODE
ZERO ELEMENT VOLUME DETECTED FOR ELEMENT WITH ID = 412734
ZERO ELEMENT VOLUME DETECTED FOR ELEMENT WITH ID = 412746
ZERO ELEMENT VOLUME DETECTED FOR ELEMENT WITH ID = 412750
ZERO ELEMENT VOLUME DETECTED FOR ELEMENT WITH ID = 412752
ZERO ELEMENT VOLUME DETECTED FOR ELEMENT WITH ID = 412764
ZERO ELEMENT VOLUME DETECTED FOR ELEMENT WITH ID = 412777
TETRA 412779 10.03 0.09 108.26 FAIL N/A- ONLY 4 NODE N/A- ONLY 4 NODE NO TEST N/A- ONLY 4 NODE
另:我在节圆上加载Distributed Load出错。。
