板材振动分析的边界条件问题
浏览:114031 回答:2
三块拼接起来的板的竖向振动,四边简支。在模态分析时,若每边的边界条件均耦合到一个点上,会出现这样的错误:12 nodes are used more than once as a slave node in *TIE keyword. These constraints are not removed either due to the presence of *CONSTRAINT CONTROLS,NO CHANGES keyword or because removing the constraints might affect the model. The nodes have been identified in node set ErrNodeOverconTieSlave.我觉得原因是同一个板角的node不能同时耦合到两个面上。
当我把耦合去掉,边界条件直接加到面上,就会出现这样的错误:
Three factorizations in a row failed. Check the model. It is possible that the model contains the kinematic coupling definition set up in a way that a degree of freedom has neither mass nor stiffness。
想了很长时间,不知道什么原因,希望大家帮帮忙,先谢谢大家了!
把你的模型传上来看看. 另外, 你用的什么FEA软件?
