顶部banner
Logo 折叠
全网首发仿真工程师项目实训
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
ls-dyna 求解出错要怎么解决?
浏览: 3832 回答: 1
 Executing with ANSYS license
 Input file: g:\xiansh~1\01\01_files\dp0\sys\mech\lsdyna~1.k
 The native file format       : 32-bit small endian
 Memory size from default     :    20000000
 on UNIX computers note the following change:
 ctrl-c interrupts ls-dyna and prompts for a sense  switch.
 type the desired sense switch: sw1., sw2., etc. to continue
 the execution.  ls-dyna will respond as explained in the users manual
    type                      response
   quit    ls-dyna terminates.
   stop    ls-dyna terminates.
   sw1.    a restart file is written and ls-dyna terminates.
   sw2.    ls-dyna responds with time and cycle numbers.
   sw3.    a restart file is written and ls-dyna continues calculations.
   sw4.    a plot state is written and ls-dyna continues calculations.
   lpri    toggle implicit lin. alg. solver output on/off
   nlpr    toggle implicit nonlinear solver output on/off
   iter    toggle implicit output to d3iter database on/off
   prof    output timing data to messag and continue
   conv    force implicit nonlinear convergence for current time step
 ********  notice  ********  notice  ********  notice  ********
 * This is the LS-DYNA Finite Element code.                   *
 * Neither LSTC nor the authors assume any responsibility for *
 * the validity, accuracy, or applicability of any results    *
 * obtained from this system. The user must verify his own    *
 * results.                                                   *
 * LSTC endeavors to make the LS-DYNA code as complete,       *
 * accurate and easy to use as possible.                      *
 * Suggestions and comments are welcomed.  Please report any  *
 * errors encountered in either the documentation or results  *
 * immediately to LSTC through your site focus.               *
 * Copyright (C) 1990-2013                                    *
 * by Livermore Software Technology Corp. (LSTC)              *
 * All rights reserved                                        *
 Beginning of keyword reader                                   11/18/21 18:14:12
 Memory required to process keyword     :      1011586
 input of data is completed
 initial kinetic energy = 0.21784197E+04
 Memory required to begin solution      :      1316486
 Additional dynamically allocated memory:       804023
                                   Total:      2120509
 initialization completed
      35 initial penetrations were found for interface          1
 dt of cycle       1 is controlled by solid           7658 of part         2
 time...........................   0.00000E+00
 time step......................   6.72101E-05
 kinetic energy.................   2.17836E+03
 internal energy................   1.06105E-04
 spring and damper energy.......   1.00000E-20
 hourglass energy ..............   0.00000E+00
 system damping energy..........   0.00000E+00
 sliding interface energy.......   0.00000E+00
 external work..................   0.00000E+00
 eroded kinetic energy..........   0.00000E+00
 eroded internal energy.........   0.00000E+00
 eroded hourglass energy........   0.00000E+00
 total energy...................   2.17836E+03
 total energy / initial energy..   1.00000E+00
 energy ratio w/o eroded energy.   1.00000E+00
 global x velocity..............   0.00000E+00
 global y velocity..............  -1.65956E-01
 global z velocity..............   0.00000E+00
       1 t 0.0000E+00 dt 6.72E-05 flush i/o buffers            11/18/21 18:14:13
       1 t 0.0000E+00 dt 6.72E-05 write d3plot file            11/18/21 18:14:13
 cpu time per zone cycle............         0 nanoseconds
 average cpu time per zone cycle....      9364 nanoseconds
 average clock time per zone cycle..      1732 nanoseconds
 estimated total cpu time          =      1352 sec (       0 hrs 22 mins)
 estimated cpu time to complete    =      1351 sec (       0 hrs 22 mins)
 estimated total clock time        =       251 sec (       0 hrs  4 mins)
 estimated clock time to complete  =       250 sec (       0 hrs  4 mins)
 termination time                  = 1.000E+00
 termination cycle                 =  10000000
     149 t 9.9463E-03 dt 6.72E-05 write d3plot file            11/18/21 18:14:15
     298 t 1.9958E-02 dt 6.72E-05 write d3plot file            11/18/21 18:14:18
     447 t 2.9968E-02 dt 6.72E-05 write d3plot file            11/18/21 18:14:20
 *** termination due to energy ***
     energy ratio     =  8.9461E-01
     447 t 3.0036E-02 dt 6.72E-05 write d3dump01 file          11/18/21 18:14:20
     447 t 3.0036E-02 dt 6.72E-05 write d3plot file            11/18/21 18:14:20
 E r r o r   t e r m i n a t i o n                             11/18/21 18:14:20
 Memory required to complete solution   :      1316486
 Additional dynamically allocated memory:       821438
                                   Total:      2137924
 T i m i n g   i n f o r m a t i o n
                        CPU(seconds)   %CPU  Clock(seconds) %Clock
  Keyword Processing ... 0.0000E+00    0.00     1.8700E-01    2.20
    KW Reading ......... 0.0000E+00    0.00     5.5000E-02    0.65
    KW Writing ......... 0.0000E+00    0.00     9.5000E-02    1.12
  Initialization ....... 0.0000E+00    0.00     7.5700E-01    8.89
    Init Proc Phase 1 .. 0.0000E+00    0.00     2.8200E-01    3.31
    Init Proc Phase 2 .. 0.0000E+00    0.00     5.0000E-03    0.06
  Element processing ... 1.0000E+00   12.50     9.8400E-01   11.56
    Solids ............. 1.0000E+00   12.50     9.1600E-01   10.76
  Binary databases ..... 0.0000E+00    0.00     4.0000E-03    0.05
  ASCII database ....... 0.0000E+00    0.00     1.0000E-03    0.01
  Contact algorithm .... 0.0000E+00    0.00     8.1000E-02    0.95
    Interf. ID         1 0.0000E+00    0.00     8.1000E-02    0.95
  Rigid Bodies ......... 0.0000E+00    0.00     3.0000E-03    0.04
  Other ................ 7.0000E+00   87.50     6.4980E+00   76.31
  T o t a l s            8.0000E+00  100.00     8.5150E+00  100.00
 Problem time       =    3.0036E-02
 Problem cycle      =       447
 Total CPU time     =         8 seconds (   0 hours  0 minutes  8 seconds)
 CPU time per zone cycle  =      1843 nanoseconds
 Clock time per zone cycle=      1744 nanoseconds
 Number of CPU's    1
 NLQ used/max     136/  136
 Start time   11/18/2021 18:14:12
 End time     11/18/2021 18:14:20
 Elapsed time       8 seconds(   0 hours  0 min.  8 sec.) for     447 cycles
LS-DYNA
全部回答 (1)
TechmanLXS 2021年11月23日
已经有一些计算结果了,你可以从你的计算结果中查找问题。
明确提示 :*** termination due to energy *** 那就先看下你的能量,看看哪里出问题了。
2021年11月23日
评论 点赞 2
相似问题
查看全部
  • s-ale模拟爆炸计算无法进行? 1个回答
    模拟辛春亮老师第二版书中7.1例子,用sale方法模拟炸药炸钢板,用ls-run计算。几个小时进度一直在0%。 这是lsrun.out文件 License option : check ansys licenses only *************************************************************** * ANSYS 2022 R2 LEGAL N
  • SPH in bucket sort of particles time? 1个回答
    在做伪二维sph爆炸模拟时,求解出现警告后就卡住了,不知道哪里出现了什么问题,求大佬指点! Beginning of keyword reader 11/06/23 23:20:58 Memory required to process keyword : 1172409 Additional dynamic memory required : 4913553 input of data is c
  • lsdyna爆炸流固耦合? 7个回答
    按照别人的模型做了几个流固耦合的案例,但是求解的时候老是出现警告和求解时间特别大该怎么解决呢? Beginning of keyword reader 07/06/22 15:15:11 *** Warning 11199 (KEY+1199) DCT should be -1 in *CONTROL_ALE *** Warning 10302 (KEY+302) CHECKING MATERIA
推荐阅读
Fluent UDF视频教程
Fluent UDF视频教程
技术邻小李 技术邻小李
¥200
基于ABAQUS和ANSYS接触分析
基于ABAQUS和ANSYS接触分析
宁博士CAE团队 宁博士CAE团队
免费
汽车仪表模具模流分析的实战讲解
汽车仪表模具模流分析的实战讲解
北卡 北卡
免费
hypermesh_dyna小车碰撞护栏(无声)
吴文泽 吴文泽
¥18
使用已标定的车辆动力学模型提升开发效率
使用已标定的车辆动力学模型提升开发效率
VI-grade中国 VI-grade中国
免费
solidworks 2016基础操作入门到精通
新征程学院 新征程学院
免费
热力学理论入门基础(上)
热力学理论入门基础(上)
引垂思汀 引垂思汀
¥30
ABAQUS钢管混凝土柱温度场及耐火性能分析(未完)
地下结构设计
¥40
前沿技术!大数据分析及人工智能在优化软件中的应用
IDAJ中国 IDAJ中国
¥9.99
新一代智能头灯的动态设计评估与仿真
新一代智能头灯的动态设计评估与仿真
Ansys中国 Ansys中国
免费
abaqus三维切削数值模拟(sph法)
abaquser abaquser
¥30
5G终端天线仿真设计方法及其应用
5G终端天线仿真设计方法及其应用
Ansys中国 Ansys中国
免费
UG有限元基础教程
UG有限元基础教程
moonshine🤓 moonshine🤓
免费
ANSYS新版本功能速递: HFSS微放电仿真
Ansys中国 Ansys中国
免费
基于Hypermesh与ABAQUS联合仿真的摄像头模组跌落分析——工作创建以及检查
北鲲 北鲲
¥99
0#块箱梁托架法施工结构模拟
0#块箱梁托架法施工结构模拟
yudachuan1105 yudachuan1105
¥200
abaqus_python提取odb中的最大值结果3
tanquery tanquery
免费
Cadence Fidelity 水泵水轮机CFD模拟解决方案和应用
Cadence楷登 Cadence楷登
免费
一线科技工作者接受仿真咨询服务的全过程经验分享
技术邻直播 技术邻直播
免费
UG培训第九课:自由曲面构造法
UG培训第九课:自由曲面构造法
luffy8610 luffy8610
¥20
