顶部banner
Logo 折叠
全网首发仿真工程师项目实训
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
关于ls-dyna警告Warning 20006 (STR+6)和 Warning 30069? 100
浏览: 3088 回答: 1
在计算的时候出现这样的警告要怎么修改呢?各位大神们
*** Warning 20006 (STR+6)
     reset D3PLOT output interval from 0. to 6.0000E-02
 expanding   memory to        4305 d         614 material, node and element data
 expanding   memory to        4399 d         624 mat add general damage 0
 expanding   memory to        4459 d         624 material added airbag porosity leakage
 expanding   memory to        4477 d         624 material properties
 expanding   memory to     9776896 d     1203593 element data for composite material
 expanding   memory to     9777030 d   115385350 gradient of damage data
 expanding   memory to    22214809 d   115385367 user control for contact interfaces
 contracting memory to    22214795 d   115385367 thermal expansion 0
 expanding   memory to    23416719 d   115385403 temp index array for node sorting
 contracting memory to    22214795 d   116587331 just because?
 expanding   memory to    23103195 d   118991197 arbitrary element numbering input
 contracting memory to    22214795 d   153641801 thick shell int. pt. strain
 expanding   memory to   541372113 d   154902571 process element material data
 expanding   memory to   541374119 d   154902565 load curve data
 expanding   memory to   541377519 d   154902565 time history data
 contracting memory to   541376135 d   154902589 user_define_loading_set
 expanding   memory to   541378735 d   154902589 regularize time history data
 contracting memory to   541376139 d   154902589 *DEFINE_ELEMENT_DEATH
 contracting memory to   541376139 d   154902589 rigidwall definitions
 expanding   memory to   542617289 d   154902589 nodal constraint sets
 expanding   memory to   547601722 d   154904044 contact interfaces
 expanding   memory to   550006570 d   154904044 implicit contact 1
 *** Warning 30069 (INI+69)
     node 379036 of contact interface 1 moved -7.7969E+00
     node 379037 of contact interface 1 moved -1.2755E+01
     node 379038 of contact interface 1 moved -1.4877E+01
     node 379039 of contact interface 1 moved -1.4169E+01
     node 379040 of contact interface 1 moved -1.0627E+01
     node 379041 of contact interface 1 moved -4.2524E+00
     node 379042 of contact interface 1 moved -4.2468E+00
LS-DYNA
全部回答 (1)
Wonderful仿真 2022年2月6日
20006一般不需要修改,计算机会自动增加内存,或者可以自己通过memory关键字增加内存,30069代表模型有干涉,可以检查调整,若是做干涉分析那倒不用管它
2022年2月6日
相似问题
查看全部
  • dyna在计算sph模拟的流固耦合问题时,总是中止计算,是什么原因? 1个回答
    Input file: G:\sph\1.k The native file format : 32-bit small endian Memory size from command line: 100000000 Binary file : 32 bit IEEE selected expanding memory to 100000000 starting ls-dyna ********
  • 1个回答
    *************************************************************** * ANSYS 2021 R1 LEGAL NOTICES * *************************************************************** * * * Copyright 1971-2021 ANSYS, Inc. Al
  • LS-DYNA做爆破数值模拟,运行k文件后1分钟左右无故终止? 4个回答
    Date: 08/20/2023 Time: 21:43:43 ___________________________________________________ | | | Livermore Software Technology, LLC | | | | 7374 Las Positas Road | | Livermore, CA 94551 | | Tel: (925) 449-25
推荐阅读
Fluent UDF视频教程
Fluent UDF视频教程
技术邻小李 技术邻小李
¥200
Cadence Fidelity 水泵水轮机CFD模拟解决方案和应用
Cadence楷登 Cadence楷登
免费
abaqus_python提取odb中的最大值结果3
tanquery tanquery
免费
ANSYS新版本功能速递: HFSS微放电仿真
Ansys中国 Ansys中国
免费
0#块箱梁托架法施工结构模拟
0#块箱梁托架法施工结构模拟
yudachuan1105 yudachuan1105
¥200
基于Hypermesh与ABAQUS联合仿真的摄像头模组跌落分析——工作创建以及检查
北鲲 北鲲
¥99
ABAQUS钢管混凝土柱温度场及耐火性能分析(未完)
地下结构设计
¥40
5G终端天线仿真设计方法及其应用
5G终端天线仿真设计方法及其应用
Ansys中国 Ansys中国
免费
abaqus三维切削数值模拟(sph法)
abaquser abaquser
¥30
基于ABAQUS和ANSYS接触分析
基于ABAQUS和ANSYS接触分析
宁博士CAE团队 宁博士CAE团队
免费
前沿技术!大数据分析及人工智能在优化软件中的应用
IDAJ中国 IDAJ中国
¥9.99
新一代智能头灯的动态设计评估与仿真
新一代智能头灯的动态设计评估与仿真
Ansys中国 Ansys中国
免费
UG培训第九课:自由曲面构造法
UG培训第九课:自由曲面构造法
luffy8610 luffy8610
¥20
应用ANSYS瞬态动力学法模拟啮合齿轮的高速转动
夏日星空 夏日星空
¥35
一线科技工作者接受仿真咨询服务的全过程经验分享
技术邻直播 技术邻直播
免费
混凝土材性试块拉压数值模拟(ABAQUS通法建模初级案例3)
大平-结构工程 大平-结构工程
¥299
汽车仪表模具模流分析的实战讲解
汽车仪表模具模流分析的实战讲解
北卡 北卡
免费
UG有限元基础教程
UG有限元基础教程
moonshine🤓 moonshine🤓
免费
ABAQUS桁架结构强度分析
ABAQUS桁架结构强度分析
wj_2704 wj_2704
¥500
ADAS功能软件基础介绍
ADAS功能软件基础介绍
Alex王 Alex王
免费
