顶部banner
Logo 折叠
全网首发仿真工程师项目实训
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
abaqusDSA设计敏感性分析修改inp Solver Input File Processor? 15
浏览: 2784 回答: 4
请教各位大佬,用dsa设计敏感度分析功能做悬臂梁敏感度分析,inp文件用记事本修改后提交,数据检查能过,但是然后立即出现solver input file processor exited with an error,修改了几次还是有问题。请教一下如何解决,谢谢!
悬臂梁inp文件如下百度网盘:
链接:https://pan.baidu.com/s/12kigjtldkkdfog9bpqbtgg
提取码:bd6r
inp文件简要概括如下:
*Heading
** Job name: Job-1 Model name: Model-1
** Generated by: Abaqus/CAE 2020
*Preprint, echo=NO, model=NO, history=NO, contact=NO
*PARAMETER
Pi=-10000
*DESIGN PARAMETER
Pi
** PARTS
*Part, name=Part-1
*Node
'此处省略一万多个悬臂梁网格节点坐标数据'
*Element, type=C3D8R
'此处省略几万多个悬臂梁网格数据'
*Nset, nset=Set-1, generate
     1,  12221,      1
*Elset, elset=Set-1, generate
     1,  10000,      1
** Section: Section-1
*Solid Section, elset=Set-1, material=Material-1
*End Part
** ASSEMBLY
*Assembly, name=Assembly
*Instance, name=Part-1-1, part=Part-1
*End Instance
*Node
      1, 0.0500000007, 0.0500000007,           1.
*Nset, nset=Set-1, instance=Part-1-1
  1101,  1102,  1103,  1104,  1105,  1106,  1107,  1108,  1109,  1110,  1111,  2212,  2213,  2214,  2215,  2216
  2217,  2218,  2219,  2220,  2221,  2222,  3323,  3324,  3325,  3326,  3327,  3328,  3329,  3330,  3331,  3332
  3333,  4434,  4435,  4436,  4437,  4438,  4439,  4440,  4441,  4442,  4443,  4444,  5545,  5546,  5547,  5548
  5549,  5550,  5551,  5552,  5553,  5554,  5555,  6656,  6657,  6658,  6659,  6660,  6661,  6662,  6663,  6664
  6665,  6666,  7767,  7768,  7769,  7770,  7771,  7772,  7773,  7774,  7775,  7776,  7777,  8878,  8879,  8880
  8881,  8882,  8883,  8884,  8885,  8886,  8887,  8888,  9989,  9990,  9991,  9992,  9993,  9994,  9995,  9996
  9997,  9998,  9999, 11100, 11101, 11102, 11103, 11104, 11105, 11106, 11107, 11108, 11109, 11110, 12211, 12212
 12213, 12214, 12215, 12216, 12217, 12218, 12219, 12220, 12221
*Elset, elset=Set-1, instance=Part-1-1
   991,   992,   993,   994,   995,   996,   997,   998,   999,  1000,  1991,  1992,  1993,  1994,  1995,  1996
  1997,  1998,  1999,  2000,  2991,  2992,  2993,  2994,  2995,  2996,  2997,  2998,  2999,  3000,  3991,  3992
  3993,  3994,  3995,  3996,  3997,  3998,  3999,  4000,  4991,  4992,  4993,  4994,  4995,  4996,  4997,  4998
  4999,  5000,  5991,  5992,  5993,  5994,  5995,  5996,  5997,  5998,  5999,  6000,  6991,  6992,  6993,  6994
  6995,  6996,  6997,  6998,  6999,  7000,  7991,  7992,  7993,  7994,  7995,  7996,  7997,  7998,  7999,  8000
  8991,  8992,  8993,  8994,  8995,  8996,  8997,  8998,  8999,  9000,  9991,  9992,  9993,  9994,  9995,  9996
  9997,  9998,  9999, 10000
*Nset, nset=p
 1,
*Elset, elset=_s_Surf-1_S3, internal, instance=Part-1-1
    1,    2,    3,    4,    5,    6,    7,    8,    9,   10, 1001, 1002, 1003, 1004, 1005, 1006
 1007, 1008, 1009, 1010, 2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010, 3001, 3002
 3003, 3004, 3005, 3006, 3007, 3008, 3009, 3010, 4001, 4002, 4003, 4004, 4005, 4006, 4007, 4008
 4009, 4010, 5001, 5002, 5003, 5004, 5005, 5006, 5007, 5008, 5009, 5010, 6001, 6002, 6003, 6004
 6005, 6006, 6007, 6008, 6009, 6010, 7001, 7002, 7003, 7004, 7005, 7006, 7007, 7008, 7009, 7010
 8001, 8002, 8003, 8004, 8005, 8006, 8007, 8008, 8009, 8010, 9001, 9002, 9003, 9004, 9005, 9006
 9007, 9008, 9009, 9010
*Surface, type=ELEMENT, name=s_Surf-1
_s_Surf-1_S3, S3
** Constraint: Constraint-1
*Coupling, constraint name=Constraint-1, ref node=p, surface=s_Surf-1
*Kinematic
*End Assembly
** MATERIALS
*Material, name=Material-1
*Elastic
 2e+11, 0.3
*DSA CONTROLS, FORMULATION=INCREMENTAL
** BOUNDARY CONDITIONS
** Name: BC-1 Type: Symmetry/Antisymmetry/Encastre
*Boundary
Set-1, ENCASTRE
** STEP: Step-1
*Step, name=Step-1, nlgeom=NO, inc=10000, DSA=YES
*Static
1., 1., 1e-05, 1.
** LOADS
** Name: Load-1   Type: Concentrated force
*Cload
p, 2, <Pi>.
** OUTPUT REQUESTS
*Restart, write, frequency=0
** FIELD OUTPUT: F-Output-1
*Output, field, variable=PRESELECT
** HISTORY OUTPUT: H-Output-1
*Output, history, variable=PRESELECT
*DESIGN RESPONSE
*NODE RESPONSE
RF,
*Element RESPONSE
S,
*End Step
ABAQUS
全部回答 (2)
橙子_2631 2022年3月13日
后来发现关键字*Cload属下的参数<Pi>后面带了句点".",可能是浮点参数<Pi>(查了帮助文档和辅导书籍说该参数必须是浮点数,可能我输入了整数程序自动转化为浮点数),浮点数小数点又与后面的句点"."混淆。inp文件此处的句点改为逗号",",即<Pi>.改为<Pi>,然后把前面"*PARAMETER Pi=-10000"的整数"-10000"改为浮点数"-10000.0"就可以顺利计算出结果了。
2022年3月13日
评论 2 点赞 3
橙子_2631 2022年2月7日
在dat文件里面的报错信息摘选如下,知道里面英文的意思但改了很多次还是没用,请教各位如何解决谢谢
                     ***COMMENT: STARTING PARAMETER EVALUATION
                     ***COMMENT: STARTING PARAMETER SUBSTITUTION
     LINE     5
                     ***ERROR:   INVALID SYNTAX IN THE USAGE OF DESIGN PARAMETER Pa.
                                 CHECK DATA LINES ASSOCIATED WITH THE FOLLOWING KEYWORD:
                                 *CLOAD
     LINE    10      ***ERROR:   SUBSTITUTION OF DESIGN GRADIENTS FAILED
                     ***ERROR:   SUBSTITUTION OF PARAMETERS FAILED
                     ***COMMENT: EVALUATION AND SUBSTITUTION OF PARAMETERS COMPLETED
2022年2月7日
相似问题
查看全部
  • ABAQUS问题? 4个回答
    我用的是UMAT子程序,出现以下问题: The executable standard.exe aborted with system error code 1073740940. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error mess
  • 用inp文件定义局部坐标各向异性报错怎么解决? 暂无回答
    我定义了一个8单元结构,在inp文件里想通过节点建立局部坐标系来赋予各向异性材料方向,但是导入之后会有“ValueError: operands could not be broadcast together with shapes (0,) (3,) This occurred while creating part level orientation ORI-1. The region in
  • inp文件引入接触出错,请问是什么原因? 4个回答
    错误信息: *CONTACT PROPERTY ASSIGNMENT CAN ONLY REFERENCE SURFACE INTERACTIONS WHICH ARE DEFINED AS MODEL DATA. SEE THE SURFACE INTERACTION NAMED INTPROP-1. inp文件: *Heading ** Job name: Job-1 Model name:
推荐阅读
Fluent UDF视频教程
Fluent UDF视频教程
技术邻小李 技术邻小李
¥200
ANSYS新版本功能速递: HFSS微放电仿真
Ansys中国 Ansys中国
免费
基于ABAQUS和ANSYS接触分析
基于ABAQUS和ANSYS接触分析
宁博士CAE团队 宁博士CAE团队
免费
前沿技术!大数据分析及人工智能在优化软件中的应用
IDAJ中国 IDAJ中国
¥9.99
新一代智能头灯的动态设计评估与仿真
新一代智能头灯的动态设计评估与仿真
Ansys中国 Ansys中国
免费
5G终端天线仿真设计方法及其应用
5G终端天线仿真设计方法及其应用
Ansys中国 Ansys中国
免费
abaqus三维切削数值模拟(sph法)
abaquser abaquser
¥30
UG有限元基础教程
UG有限元基础教程
moonshine🤓 moonshine🤓
免费
ABAQUS钢管混凝土柱温度场及耐火性能分析(未完)
地下结构设计
¥40
一线科技工作者接受仿真咨询服务的全过程经验分享
技术邻直播 技术邻直播
免费
应用ANSYS瞬态动力学法模拟啮合齿轮的高速转动
夏日星空 夏日星空
¥35
混凝土材性试块拉压数值模拟(ABAQUS通法建模初级案例3)
大平-结构工程 大平-结构工程
¥299
UG培训第九课:自由曲面构造法
UG培训第九课:自由曲面构造法
luffy8610 luffy8610
¥20
汽车仪表模具模流分析的实战讲解
汽车仪表模具模流分析的实战讲解
北卡 北卡
免费
ABAQUS桁架结构强度分析
ABAQUS桁架结构强度分析
wj_2704 wj_2704
¥500
0#块箱梁托架法施工结构模拟
0#块箱梁托架法施工结构模拟
yudachuan1105 yudachuan1105
¥200
基于Hypermesh与ABAQUS联合仿真的摄像头模组跌落分析——工作创建以及检查
北鲲 北鲲
¥99
hypermesh_dyna小车碰撞护栏(无声)
吴文泽 吴文泽
¥18
使用已标定的车辆动力学模型提升开发效率
使用已标定的车辆动力学模型提升开发效率
VI-grade中国 VI-grade中国
免费
ADAS功能软件基础介绍
ADAS功能软件基础介绍
Alex王 Alex王
免费
