做的是一个滑坡-管道模型,只有中间滑坡区土壤使用的SPH方法
以下是部分运行日志
 d y n a m i c  r e l a x a t i o n   i n f o r m a t i o n
   cycle      time          current         maximum       convergence
                        distortional ke  distortional ke    factor
     250   1.36410E-04    1.32220E+05      1.39007E+05    9.51176E-01
     500   2.73227E-04    2.35674E+04      1.39007E+05    1.69541E-01
     500 t 2.7323E-04 dt 5.47E-07 write d3dump01 file          06/17/26 16:35:48
     500 t 2.7323E-04 dt 5.47E-07 flush i/o buffers            06/17/26 16:35:48
 Use this restart dump if you want to restart the
 dynamic relaxation and re-converge to a tighter tolerance
 Use the next restart dump to restart as a transient analysis
 ASCII File drdisp.sif written at end of dynamic relaxation.
 This file contains nodal displacements, rotations and temperatures.
 The file may be used for stress initialization - See
 Dynamic relaxation option #2.
 initialization complete at
    pseudo-time =  2.7323E-04
    cycle =      500
 *** Warning 40515 (SOL+515)
     Velocities cannot be reinitialized
     after restart to account for geometry
     changes whenever:
     1. "INIT" option is specified on
        command line during the initial run.
     2. dynamic relaxation restart dumpfile
        is used to restart run.
       1 t 0.0000E+00 dt 5.47E-07 flush i/o buffers            06/17/26 16:35:50
       1 t 0.0000E+00 dt 5.47E-07 write d3plot file            06/17/26 16:35:50
    1645 t 8.9956E-04 dt 5.47E-07 write d3plot file            06/17/26 16:38:42
    3290 t 1.7997E-03 dt 5.47E-07 write d3plot file            06/17/26 16:41:33
    4501 t 2.4623E-03 dt 5.47E-07 flush i/o buffers            06/17/26 16:43:39
    4935 t 2.6998E-03 dt 5.47E-07 write d3plot file            06/17/26 16:44:24
    6580 t 3.5995E-03 dt 5.47E-07 write d3plot file            06/17/26 16:47:16
    8226 t 4.4998E-03 dt 5.47E-07 write d3plot file            06/17/26 16:50:08
    9501 t 5.1972E-03 dt 5.47E-07 flush i/o buffers            06/17/26 16:52:23
    9871 t 5.3996E-03 dt 5.47E-07 write d3plot file            06/17/26 16:53:01
   11516 t 6.2996E-03 dt 5.47E-07 write d3plot file            06/17/26 16:55:53
   13162 t 7.2000E-03 dt 5.47E-07 write d3plot file            06/17/26 16:58:45
   14501 t 7.9321E-03 dt 5.46E-07 flush i/o buffers            06/17/26 17:01:06
   14808 t 8.0997E-03 dt 5.46E-07 write d3plot file            06/17/26 17:01:37
   16455 t 8.9997E-03 dt 5.47E-07 write d3plot file            06/17/26 17:04:28
   18101 t 9.8996E-03 dt 5.47E-07 write d3plot file            06/17/26 17:07:19
   19501 t 1.0665E-02 dt 5.47E-07 flush i/o buffers            06/17/26 17:09:45
   19748 t 1.0800E-02 dt 5.47E-07 write d3plot file            06/17/26 17:10:11
   21395 t 1.1700E-02 dt 5.46E-07 write d3plot file            06/17/26 17:13:02
   23043 t 1.2599E-02 dt 5.45E-07 write d3plot file            06/17/26 17:15:53
   24501 t 1.3396E-02 dt 5.47E-07 flush i/o buffers            06/17/26 17:18:24
   24690 t 1.3500E-02 dt 5.46E-07 write d3plot file            06/17/26 17:18:44
   26337 t 1.4400E-02 dt 5.46E-07 write d3plot file            06/17/26 17:21:34
   27984 t 1.5300E-02 dt 5.47E-07 write d3plot file            06/17/26 17:24:25
   29501 t 1.6129E-02 dt 5.46E-07 flush i/o buffers            06/17/26 17:27:02
   29630 t 1.6200E-02 dt 5.47E-07 write d3plot file            06/17/26 17:27:15
   31277 t 1.7100E-02 dt 5.46E-07 write d3plot file            06/17/26 17:30:05
   32924 t 1.8000E-02 dt 5.46E-07 write d3plot file            06/17/26 17:32:54
   34501 t 1.8861E-02 dt 5.47E-07 flush i/o buffers            06/17/26 17:35:35
   34571 t 1.8899E-02 dt 5.46E-07 write d3plot file            06/17/26 17:35:42
   36218 t 1.9800E-02 dt 5.47E-07 write d3plot file            06/17/26 17:38:30
   37865 t 2.0700E-02 dt 5.47E-07 write d3plot file            06/17/26 17:41:18
   39501 t 2.1594E-02 dt 5.47E-07 flush i/o buffers            06/17/26 17:44:06
   39511 t 2.1600E-02 dt 5.47E-07 write d3plot file            06/17/26 17:44:07
   41157 t 2.2500E-02 dt 5.47E-07 write d3plot file            06/17/26 17:46:54
   42803 t 2.3400E-02 dt 5.47E-07 write d3plot file            06/17/26 17:49:42
   44449 t 2.4300E-02 dt 5.47E-07 write d3plot file            06/17/26 17:52:30
   44501 t 2.4328E-02 dt 5.47E-07 flush i/o buffers            06/17/26 17:52:36
   46094 t 2.5200E-02 dt 5.47E-07 write d3plot file            06/17/26 17:55:19
   47740 t 2.6100E-02 dt 5.47E-07 write d3plot file            06/17/26 17:58:08
   49386 t 2.7000E-02 dt 5.47E-07 write d3plot file            06/17/26 18:00:56
   49501 t 2.7062E-02 dt 5.47E-07 flush i/o buffers            06/17/26 18:01:09
   51033 t 2.7900E-02 dt 5.47E-07 write d3plot file            06/17/26 18:03:44
   52679 t 2.8800E-02 dt 5.47E-07 write d3plot file            06/17/26 18:06:33
   54325 t 2.9700E-02 dt 5.47E-07 write d3plot file            06/17/26 18:09:24
   54501 t 2.9796E-02 dt 5.47E-07 flush i/o buffers            06/17/26 18:09:43
   55971 t 3.0600E-02 dt 5.47E-07 write d3plot file            06/17/26 18:12:13
   57617 t 3.1500E-02 dt 5.47E-07 write d3plot file            06/17/26 18:15:01
   59264 t 3.2400E-02 dt 5.47E-07 write d3plot file            06/17/26 18:17:51
   59501 t 3.2529E-02 dt 5.47E-07 flush i/o buffers            06/17/26 18:18:16
   60910 t 3.3300E-02 dt 5.47E-07 write d3plot file            06/17/26 18:20:41
   62557 t 3.4200E-02 dt 5.47E-07 write d3plot file            06/17/26 18:23:30
   64204 t 3.5100E-02 dt 5.46E-07 write d3plot file            06/17/26 18:26:19
   64501 t 3.5262E-02 dt 5.46E-07 flush i/o buffers            06/17/26 18:26:50
   65851 t 3.6000E-02 dt 5.47E-07 write d3plot file            06/17/26 18:29:09
   67498 t 3.6900E-02 dt 5.47E-07 write d3plot file            06/17/26 18:31:59
   69145 t 3.7800E-02 dt 5.46E-07 write d3plot file            06/17/26 18:34:49
   69501 t 3.7994E-02 dt 5.46E-07 flush i/o buffers            06/17/26 18:35:27
   70792 t 3.8700E-02 dt 5.46E-07 write d3plot file            06/17/26 18:37:39
   72439 t 3.9600E-02 dt 5.46E-07 write d3plot file            06/17/26 18:40:30
   74087 t 4.0500E-02 dt 5.46E-07 write d3plot file            06/17/26 18:43:22
   74501 t 4.0726E-02 dt 5.46E-07 flush i/o buffers            06/17/26 18:44:06
   75735 t 4.1400E-02 dt 5.46E-07 write d3plot file            06/17/26 18:46:14
   77382 t 4.2300E-02 dt 5.46E-07 write d3plot file            06/17/26 18:49:06
   79031 t 4.3200E-02 dt 5.46E-07 write d3plot file            06/17/26 18:51:58
   79501 t 4.3457E-02 dt 5.46E-07 flush i/o buffers            06/17/26 18:52:47
   80679 t 4.4100E-02 dt 5.46E-07 write d3plot file            06/17/26 18:54:50
   82327 t 4.5000E-02 dt 5.46E-07 write d3plot file            06/17/26 18:57:42
   83976 t 4.5900E-02 dt 5.46E-07 write d3plot file            06/17/26 19:00:34
   84501 t 4.6186E-02 dt 5.46E-07 flush i/o buffers            06/17/26 19:01:29
   85624 t 4.6800E-02 dt 5.46E-07 write d3plot file            06/17/26 19:03:26
   87273 t 4.7700E-02 dt 5.46E-07 write d3plot file            06/17/26 19:06:17
   88922 t 4.8600E-02 dt 5.46E-07 write d3plot file            06/17/26 19:09:08
   89501 t 4.8916E-02 dt 5.46E-07 flush i/o buffers            06/17/26 19:10:09
   90570 t 4.9499E-02 dt 5.46E-07 write d3plot file            06/17/26 19:11:59
   92220 t 5.0400E-02 dt 5.46E-07 write d3plot file            06/17/26 19:14:51
   93869 t 5.1299E-02 dt 5.46E-07 write d3plot file            06/17/26 19:17:42
   94501 t 5.1644E-02 dt 5.46E-07 flush i/o buffers            06/17/26 19:18:49
   95520 t 5.2200E-02 dt 5.45E-07 write d3plot file            06/17/26 19:20:35
   97171 t 5.3100E-02 dt 5.45E-07 write d3plot file            06/17/26 19:23:28
   98822 t 5.4000E-02 dt 5.45E-07 write d3plot file            06/17/26 19:26:20
   99501 t 5.4370E-02 dt 5.45E-07 flush i/o buffers            06/17/26 19:27:31
  100474 t 5.4900E-02 dt 5.45E-07 write d3plot file            06/17/26 19:29:12
  102127 t 5.5800E-02 dt 5.44E-07 write d3plot file            06/17/26 19:32:05
  103781 t 5.6700E-02 dt 5.44E-07 write d3plot file            06/17/26 19:35:04
  104501 t 5.7092E-02 dt 5.44E-07 flush i/o buffers            06/17/26 19:36:21
  105434 t 5.7600E-02 dt 5.44E-07 write d3plot file            06/17/26 19:38:01
  107089 t 5.8500E-02 dt 5.44E-07 write d3plot file            06/17/26 19:40:58
  108743 t 5.9399E-02 dt 5.44E-07 write d3plot file            06/17/26 19:43:55
  109501 t 5.9812E-02 dt 5.44E-07 flush i/o buffers            06/17/26 19:45:17
  110399 t 6.0300E-02 dt 5.43E-07 write d3plot file            06/17/26 19:46:52
  112055 t 6.1200E-02 dt 5.43E-07 write d3plot file            06/17/26 19:49:50
  113711 t 6.2100E-02 dt 5.43E-07 write d3plot file            06/17/26 19:52:49
  114501 t 6.2529E-02 dt 5.43E-07 flush i/o buffers            06/17/26 19:54:15
  115369 t 6.3000E-02 dt 5.43E-07 write d3plot file            06/17/26 19:55:49
  117026 t 6.3900E-02 dt 5.43E-07 write d3plot file            06/17/26 19:58:48
  118685 t 6.4800E-02 dt 5.42E-07 write d3plot file            06/17/26 20:01:49
  119501 t 6.5242E-02 dt 5.42E-07 flush i/o buffers            06/17/26 20:03:19
  120346 t 6.5700E-02 dt 5.42E-07 write d3plot file            06/17/26 20:04:51
  122007 t 6.6600E-02 dt 5.41E-07 write d3plot file            06/17/26 20:07:54
  123670 t 6.7500E-02 dt 5.41E-07 write d3plot file            06/17/26 20:10:58
  124501 t 6.7949E-02 dt 5.41E-07 flush i/o buffers            06/17/26 20:12:31
  125334 t 6.8400E-02 dt 5.41E-07 write d3plot file            06/17/26 20:14:03
  127000 t 6.9300E-02 dt 5.40E-07 write d3plot file            06/17/26 20:17:10
  128667 t 7.0200E-02 dt 5.40E-07 write d3plot file            06/17/26 20:20:19
  129501 t 7.0649E-02 dt 5.39E-07 flush i/o buffers            06/17/26 20:21:54
  130337 t 7.1100E-02 dt 5.39E-07 write d3plot file            06/17/26 20:23:30
  132008 t 7.2000E-02 dt 5.38E-07 write d3plot file            06/17/26 20:26:42
  133681 t 7.2900E-02 dt 5.38E-07 write d3plot file            06/17/26 20:29:55
  134501 t 7.3340E-02 dt 5.38E-07 flush i/o buffers            06/17/26 20:31:31
  135357 t 7.3800E-02 dt 5.36E-07 write d3plot file            06/17/26 20:33:11
  137034 t 7.4699E-02 dt 5.37E-07 write d3plot file            06/17/26 20:36:29
  138714 t 7.5600E-02 dt 5.35E-07 write d3plot file            06/17/26 20:39:49
  139501 t 7.6021E-02 dt 5.36E-07 flush i/o buffers            06/17/26 20:41:24
  140396 t 7.6500E-02 dt 5.35E-07 write d3plot file            06/17/26 20:43:13
  142078 t 7.7400E-02 dt 5.36E-07 write d3plot file            06/17/26 20:46:46
  143790 t 7.8300E-02 dt 5.36E-07 write d3plot file            06/17/26 20:50:44
  144501 t 7.8301E-02 dt 1.16E-16 flush i/o buffers            06/17/26 22:16:32
是在超算上进行计算的,总是出现时间步骤降最终不能正常终止,请问这是什么原因
暂无数据
