ICEM合并节点出现一个提示this family is not selected for merging
浏览:75543
采用混合网格,交界面上两种网格进行节点合并,出现如下提示:
503 shells from the variable region deleted
671 bars from the variable region deleted
vertex 145 on the variable side of the merge
is adjacent to a shell element in the family GROUND
18758 vertices included
7641 vertices removed
expecting 6045 pyras, have 0 already
以上红色部分应该是出现问题的地方,这个大致原因是什么呢?是不是GROUND这个part里有元素没有归并到交界面上?
