首页
学院
直播
问答
悬赏
全部悬赏
发布悬赏
专家入驻
会议
社区
CAE工程师认证
CAE服务
搜索
发布
注册
登录
求助!ANSYS热分析问题
浏览:53023
回答:4
各位高手,小弟最近搞ANSYS热分析模拟激光熔覆,加载热流密度后分析结果老是显示为初始温度,不知道是何原因,请各位高手不吝赐教!!
ANSYS
CAE
结构CAE
急~急~~求助啊
谁能给份CFX的资料啊
关注问题
邀请回答
我来回答
默认
最新
叶先森
热流密度应该是热源对 嘛
2018年11月13日
评论
点赞
麦兜兜兜90
你好,我是利用表载荷加载热流密度模拟移动的激光热源,不知是加载问题还是分析设置有问题,下面是全部命令流,请帮忙看看,谢谢!
/clear,nostart
/filname,ceramicthinwall_thermal_analysis
/title,ceramicthinwall_thermal_analysis
/units,si !定义国际制单位
/prep7
ET,1,SOLID70 !定义单元类型
ET,2,SURF152
KEYOPT,2,4,1 !存在中间节点
KEYOPT,2,5,0 !没有孤立节点
KEYOPT,2,8,1 !施加热流密度,忽略对流
!定义单元类型及材料属性
MPTEMP,,,,,,,,
MPTEMP,1,20
MPTEMP,2,200
MPTEMP,3,400
MPTEMP,4,600
MPTEMP,5,1530
MPTEMP,6,1650
MPTEMP,7,2000
MPDATA,KXX,1,,17
MPDATA,KXX,1,,15
MPDATA,KXX,1,,15
MPDATA,KXX,1,,16
MPDATA,KXX,1,,20
MPDATA,KXX,1,,20.5
MPDATA,KXX,1,,21
MPTEMP,,,,,,,,
MPTEMP,1,20
MPTEMP,2,200
MPTEMP,3,400
MPTEMP,4,600
MPTEMP,5,1530
MPTEMP,6,1650
MPTEMP,7,2000
MPDATA,C,1,,500
MPDATA,C,1,,580
MPDATA,C,1,,595
MPDATA,C,1,,615
MPDATA,C,1,,760
MPDATA,C,1,,840
MPDATA,C,1,,730
MPTEMP,,,,,,,,
MPTEMP,1,20
MPTEMP,2,200
MPTEMP,3,400
MPTEMP,4,600
MPTEMP,5,1530
MPTEMP,6,1650
MPTEMP,7,2000
MPDATA,DENS,1,,4420
MPDATA,DENS,1,,4420
MPDATA,DENS,1,,4420
MPDATA,DENS,1,,4420
MPDATA,DENS,1,,4420
MPDATA,DENS,1,,4420
MPDATA,DENS,1,,4420
MPTEMP,,,,,,,,
MPTEMP,1,20
MPTEMP,2,600
MPTEMP,3,1400
MPTEMP,4,1800
MPDATA,KXX,2,,39
MPDATA,KXX,2,,9.2
MPDATA,KXX,2,,5.9
MPDATA,KXX,2,,7.1
MPTEMP,,,,,,,,
MPTEMP,1,27
MPTEMP,2,127
MPTEMP,3,227
MPTEMP,4,327
MPTEMP,5,427
MPTEMP,6,527
MPTEMP,7,627
MPTEMP,8,727
MPTEMP,9,827
MPTEMP,10,927
MPTEMP,11,1027
MPTEMP,12,1127
MPTEMP,13,1227
MPTEMP,14,1327
MPTEMP,15,1527
MPTEMP,16,1727
MPDATA,C,2,,785
MPDATA,C,2,,942
MPDATA,C,2,,1046
MPDATA,C,2,,1109
MPDATA,C,2,,1151
MPDATA,C,2,,1203
MPDATA,C,2,,1224
MPDATA,C,2,,1235
MPDATA,C,2,,1256
MPDATA,C,2,,1272
MPDATA,C,2,,1285
MPDATA,C,2,,1297
MPDATA,C,2,,1308
MPDATA,C,2,,1308
MPDATA,C,2,,1308
MPDATA,C,2,,1308
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,DENS,2,,3900
!*CSET,1,2, 2,3,
MPCOPY, ,2,3
TBCOPY,ALL,2,3
!**********建立模型***************
L1=0.1 !定义参数
W1=0.1
H1=0.009
L2=0.02
W2=0.01
H2=0.009
L3=0.015
W3=0.004
H3=0.0003
R=0.002
!***************定义点************
K,1,0,0,0,
K,2,L1,0,0,
K,3,L1,W1,0,
K,4,0,W1,0,
K,5,0,0,H1,
K,6,L1,0,H1,
K,7,L1,W1,H1,
K,8,0,W1,H1,
K,9,(L1-L2)/2,(W1-W2)/2,0,
K,10,(L1+L2)/2,(W1-W2)/2,0,
K,11,(L1+L2)/2,(W1+W2)/2,0,
K,12,(L1-L2)/2,(W1+W2)/2,0,
K,13,(L1-L2)/2,(W1-W2)/2,H2,
K,14,(L1+L2)/2,(W1-W2)/2,H2,
K,15,(L1+L2)/2,(W1+W2)/2,H2,
K,16,(L1-L2)/2,(W1+W2)/2,H2,
K,17,(L1-L3)/2,(W1-W3)/2,H2,
K,18,(L1+L3)/2,(W1-W3)/2,H2,
K,19,(L1+L3)/2,(W1+W3)/2,H2,
K,20,(L1-L3)/2,(W1+W3)/2,H2,
K,21,(L1-L3)/2,(W1-W3)/2,H2+H3,
K,22,(L1+L3)/2,(W1-W3)/2,H2+H3,
K,23,(L1+L3)/2,(W1+W3)/2,H2+H3,
K,24,(L1-L3)/2,(W1+W3)/2,H2+H3,
K,25,(L1-L3)/2,L1/2,H2+H3+R,
K,26,(L1+L3)/2,L1/2,H2+H3+R,
!***************连线************
LSTR,1,2
LSTR,2,3
LSTR,3,4
LSTR,4,1
LSTR,1,5
LSTR,2,6
LSTR,3,7
LSTR,4,8
LSTR,5,6
LSTR,6,7
LSTR,7,8
LSTR,8,5
LSTR,9,10
LSTR,10,11
LSTR,11,12
LSTR,12,9
LSTR,9,13
LSTR,10,14
LSTR,11,15
LSTR,12,16
LSTR,13,14
LSTR,14,15
LSTR,15,16
LSTR,16,13
LSTR,17,18
LSTR,18,19
LSTR,19,20
LSTR,20,17
LSTR,17,21
LSTR,18,22
LSTR,19,23
LSTR,20,24
LSTR,21,22
LSTR,22,23
LSTR,23,24
LSTR,24,21
LSTR,25,26
LARC,21,25,24,0.002
LARC,24,25,21,0.002
LARC,22,26,23,0.002
LARC,23,26,22,0.002
!***************建面************
AL,1,2,3,4
AL,1,5,9,6
AL,2,6,10,7
AL,3,7,11,8
AL,4,5,12,8
AL,9,10,11,12
AL,13,14,15,16
AL,13,17,21,18
AL,14,18,22,19
AL,15,19,23,20
AL,16,17,24,20
AL,21,22,23,24
AL,25,26,27,28
AL,25,29,33,30
AL,26,31,34,30
AL,27,32,35,31
AL,28,29,36,32
AL,33,34,35,36
AL,36,38,39
AL,34,40,41
AL,35,39,37,41
AL,33,38,40,37
!***************建体************
VA,1,2,3,4,5,6
VA,7,8,9,10,11,12
VA,13,14,15,16,17,18
VA,19,20,21,22,18
!**********实体布尔运算***********
VOVLAP,1,2,3,4 !搭接运算
VGLUE,6,3,4,5 !粘结运算(搭接后体的编号改变)
!**********定义模型材料和单元属性***********
Vsel,s,,,6
Vsel,a,,,5
Vatt,1,,1
ALLSEL,ALL
VSEL,s,,,3
Vatt,2,,1
ALLSEL,ALL
VSEL,s,,,4
Vatt,3,,1
ALLSEL,ALL
!**********扫掠网格划分薄壁结构3,4***********
LESIZE,32,,,3,,,,,1
LESIZE,28,,,20,,,,,1
LESIZE,27,,,75,,,,,1
LESIZE,25,,,75,,,,,1
LESIZE,38,,,20,,,,,1
LESIZE,39,,,20,,,,,1
VSEL,s,,,3,4
VSWEEP,ALL
ALLSEL,ALL
!**********自由网格划分基座5,6***********
ESIZE,0.001,0, !交互操作自动生成的命令流
MSHAPE,1,3D
MSHKEY,0
CM,_Y,VOLU
VSEL, , , , 5
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
ESIZE,0.005,0,
CM,_Y,VOLU
VSEL, , , , 6
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
!SMRT,off
!ESIZE,0.0005,,
!Vmesh,5
!SMRT,off
!ESIZE,0.005,,
!Vmesh,6
!ALLSEL,ALL
!**********建立表面效应单元***********
TYPE,2
MAT,3
REAL,
ASEL,S,AREA,,21
ASEL,A,AREA,,22
NSLA,S,1
ESURF
ALLSEL
!**********定义热流密度表载荷***********
!**********参数定义***********
tm=3
tinc=0.04
esize=0.2e-3
v=0.005
R=2e-3
pi=3.1415926
max_time=76
max_x=76
max_y=21
power=800
power_max=800/(pi*R*R)
!**********表载荷定义***********
*DIM,laser,TABLE,MAX_X,MAX_Y,MAX_TIME,X,Y,TIME
*DO,K,1,MAX_TIME,1
*DO,I,1,MAX_X,1
laser(I,0,K)=(I-1)*ESIZE
*ENDDO
*DO,J,1,MAX_Y,1
laser(0,J,K)=(J-1)*ESIZE
*ENDDO
*DO,I,1,MAX_X,1
*DO,J,1,MAX_Y,1
YCENTER=L1/2
XCENTER=V*(K-1)*TINC+(L1-L3)/2
DISTANCE=SQRT(((I-1)*ESIZE-XCENTER)**2+((J-1)*ESIZE-YCENTER)**2)
*IF,DISTANCE,LE,R,THEN
laser(I,J,K)=power_max !激光的表面热流
*ELSE
laser(I,J,K)=0
*ENDIF
*ENDDO
*ENDDO
laser(0,0,K)=(K-1)*TINC
*ENDDO
!**********进行稳态分析***********
/SOLU
NROPT,FULL,, !设置牛顿-拉夫森选项
ESEL,S,MAT,,2
ESEL,A,MAT,,3
Ekill,ALL !杀死熔覆层及表面效应单元
ALLSEL,ALL
TOFFST,273 !设置温度偏移量
ESEL,S,MAT,,1
NSEL,S
D,ALL,,25,,,,TEMP,,,,, !定义基座初始温度
ALLSEL,ALL
ANTYPE,TRANS !定义为瞬态热分析
TIMINT,OFF !关闭时间积分,设定为稳态分析
TIME,1E-6 !设定只有一个子步的时间很小的载荷步
KBC,0 !斜坡方式施加载荷
DELTIM,1 !设定求解时间子步
SOLVE !求解
!**********进行瞬态分析***********
/SOLU
ALLSEL,ALL
DDELET,ALL,TEMP !删除稳态分析中定义的节点温度
ASEL,S,,,2,3,4,5,24,25 !施加对流换热系数(应该为随温度变化)
ASEL,A,,,7,23
SFA,ALL,,CONV,50,25
ALLSEL,ALL
ASEL,S,,,14,15,16,17,19,20,21,22
SFA,ALL,,CONV,750,25
!**********循环加载求解***********
ALLSEL,ALL
*SET,M,1
*DO,T,0.01,tm,tinc
!**********逐步激活激光照射到的薄壁件单元***********
VSEL,S,MAT,,2
VSEL,A,MAT,,3
NSLV,S,1
NSEL,R,LOC,X,(M-1)*0.015/75+(L1-L3)/2,(M-1)*0.015/75+2*R+(L1-L3)/2
ESLN,S,1
EALIVE,ALL
ALLSEL
ESEL,S,type,,2
NSLE,S,ALL,,
ESLN,S,1
EALIVE,ALL
ALLSEL
!**********施加薄壁件第一层热源***********
TIME,t
TIMINT,ON
KBC,1
AUTOTS,ON
DELTIM,,,,1
ESEL,s,TYPE,,2
SFE,ALL,1,HFLUX,,%laser%
ALLSEL
OUTRES,ALL,ALL
SOLVE
SFDELE,ALL,HFLUX !计算后删除热源,便于下一步加载
*SET,M,M+1
*enddo
FINISH
2013年12月12日
评论 1
点赞
liang_song
分析设置部分截个图看看
2013年12月11日
评论
点赞
推荐阅读
转子旋转的周期性模型-水冷电机散热仿真
技术邻小李
¥100
ALTAIR
免费
坚固型数据采集系统在恶劣环境条件下的测试应用
HBK测试与测量
免费
汽车冲模零件3D展开与工艺排布
来meisu
免费
陈东陈
免费
B&K声级计全系列介绍及新款解密
HBK声学与振动
免费
混合弯头的流体流动与传热
CFD流
免费
场景仿真加速智能网联开发测试进程
海克斯康设计与仿真
免费
后保险杠低速碰撞分析
Crisby_Vectory_TrHo
¥70
Mathcad基本操作
HYT
¥89
活泼可男_matlab教学
¥10
CEL分析技术的理论与应用
赤子Sim
¥5
复杂电驱动系统动态实时功率测试
HBK测试与测量
免费
【推荐】基于DAMASK和ABAQUS的晶体塑性有限元分析全教程
枕流漱石
¥399
OptiStruct梁单元截面尺寸优化
谢晓峰
免费
应用VI-grade仿真解决方案进行赛车圈速仿真和性能优化
VI-grade中国
免费
Fluent中升力和阻力的计算
宁博士CAE团队
免费
热力学理论入门基础(上)
引垂思汀
¥30
隔热螺栓的优化仿真案例分享
钛闻软件
¥29
Creo/Proe曲面实战-摆钟高级曲面
creo/proe●一加一教育
¥16.8
工程师
必备
项目客服
培训客服
平台客服
热流密度应该是热源对 嘛
