求助!扇形循环的问题!
浏览:68155
在循环完成后,出现错误,如下:
There is no high edge node in a position to match low edge node 391
(location error = 1.86, maximum for all nodes). Cyclic symmetry
constraint equations will be generated between the sector edges using
a mapping procedure similar to CEINTF. This may reduce solution
accuracy, especially near the sector edges.
请问,这个是什么原因?
