abaqus热力耦合接触问题——急寻高手解答
浏览:103121
***WARNING: THE SYSTEM MATRIX HAS 1 NEGATIVE EIGENVALUES.
NEGATIVE EIGENVALUES MEAN THAT THE SYSTEM MATRIX IS NOT
POSITIVE DEFINITE:
FOR EXAMPLE, A BIFURCATION (BUCKLING) LOAD MAY HAVE BEEN EXCEEDED.
***WARNING: SOLVER PROBLEM. NUMERICAL SINGULARITY WHEN PROCESSING NODE
SPLINE-2-1.98 D.O.F. 11 RATIO = 6.35194E+12.
SPLINE-1-1.2 D.O.F. 11 RATIO = 63.1250E+12 .
***WARNING: SOLVER PROBLEM. ZERO PIVOT WHEN PROCESSING NODE 98 INSTANCE
SPLINE-2-1 D.O.F. 11
OVERCONSTRAINT CHECKS:
An overconstraint was detected at node 98 INSTANCE SPLINE-2-1. There are multiple constraints
applied directly or chained constraints that are applied indirectly at this node.
A list of nodes and chained constraints between these nodes that most likely lead
to the detected overconstraint can be printed out to the message file by including
*constraint controls, print=yes in the input file.
***WARNING: SOLVER PROBLEM. ZERO PIVOT WHEN PROCESSING NODE 2 INSTANCE
SPLINE-1-1 D.O.F. 11
An overconstraint was detected at node 2 INSTANCE SPLINE-1-1. There are multiple constraints
***WARNING: Solver problem. Zero pivot when processing D.O.F. 11 of 2 nodes.
The nodes have been identified in node set
WarnNodeSolvProbZeroPiv_11_1_1_1_1.
***WARNING: DISPLACEMENT INCREMENT FOR CONTACT IS TOO BIG.
ELEMENT SPLINE-1-1.1 IS DISTORTING EXCESSIVELY.
ELEMENT SPLINE-1-1.3 IS DISTORTING EXCESSIVELY.
ELEMENT SPLINE-1-1.4 IS DISTORTING EXCESSIVELY.
ELEMENT SPLINE-1-1.5 IS DISTORTING EXCESSIVELY.
ELEMENT SPLINE-1-1.6 IS DISTORTING EXCESSIVELY.
