钢管混凝土ABAQUS模拟
浏览:90832
1)Slave node 180 instance duanban-1 will not be tied to the master surface assembly__pickedsurf18. The distance from the master surface is greater than the position tolerance value.
2)Shell node 504 instance gangguan-1 met the position tolerance for *shell to solid coupling but only one coupling node was found. Increasing the value of the influence distance may be needed.
钢管混凝土柱模拟时提示这两个问题,忘高手指点
