fire 求解终止问题
浏览:13568
用的是fire的ESE diesel模块 计算过程中卡在了673.6的位置 但是这一段的步长都是1 不应该有这个角度的然后计算了几次都会停在这里 之前会在最后报发散 最后一次计算没有报发散 但计算终止了fla文件提示如下:
%fire-I-SW_REZ_COPY, Start copying arrays.
% This might take some time.
%fire-I-sw_rez_calc0, Block Correction is enabled
% Performed for small volume change only
%fire-I-sw_rez_calc0, Ekin-Correction of velocities active
%fire-I-sw_rez_calc5, Volume has Significantly Changed,
% No Block Corrections Possible!
%fire-I-sw_rez_calc5, Ekin-Correction switched off!
%fire-I-cyrezon, Spray rezone finished with 0 parcels deleted
MPI Application rank 2 exited before MPI_Finalize() with status 17
d:\135-ESE-00\Calculation\ESE\start_mpi.bat: Rank 0:2: MPI_Waitall: Error code is in status
求指导,谢谢!
