- procast网格划分,面网格检查都正确,但是体网格划分就出现错误了,是怎么回事? 暂无回答
小弟初步接触procast12.0版本,按照视频学的时候遇到了问题,就是我在划分网格的时候,之前的装配也都没有问题,检查都通过了。面网格也都画好了,检查也没问题,但是体网格划分的时候就错了,提示如下: Closed volumes have element edges shared by more than 2 elements! Gradual method has failed. Try wi
- ansys计算时候出现以下错误? 4个回答
*** ERROR *** SUPPRESSED MESSAGE CP = 255.904 TIME= 11:05:16 Zero volume in element 25313. *** ERROR *** SUPPRESSED MESSAGE CP = 255.904 TIME= 11:05:16 Zero volume in element 25394. *** ERROR *** SUPP
- ansys workbench设置网格时报错怎么回事? 暂无回答
The mesh generation did not complete due to poor quality elements or incorrect input. Please try meshing with another mesh method or different mesh options. The surface mesh is intersecting or close t
