刚遇到的问题 请多指教
浏览:12712 回答:1
The volume of 79 elements is zero, small, or negative. Check coordinates or node numbering, or modify the mesh seed. In the case of a tetrahedron this error may indicate that all nodes are located very nearly in a plane. The elements have been identified in element set ErrElemVolSmallNegZeroABAQUS输入文件计算时提示的内容
求具体应对办法 重新划了网格 然而没有多少效果
