[50分,谢谢]一个复杂桨叶求模态的问题,具体见帖子
浏览:147422 回答:5
我已经用catia建立了一个模型,图形大致如下,我现在用的自由网格建的模型,对各个零件如图中所示的材料是不一样的
,最左端约訴,进行模态分析时,总是出现如下错误,不知该如何改正,忘高人指点,谢谢。 [50分,谢谢]一个复杂桨叶求模态的问题,具体见帖子的图1作分析时出现以下错误,不知道是怎么回事,第一个是不是连接点有问题,第二个是不是建模有问题呀,谢谢。祈求高人指点。具体错误见附件,不知道应该怎么改呀。
*** USER FATAL MESSAGE 4654 (ETETGD)
ELEMENT WITH ID = 11163
CONNECTS TWO POINTS HAVING THE SAME COORDINATES.
CONNECTION ORDER OF GRID POINTS IN QUESTION = 6 AND 8
TETRA 11177 0.15 0.03 4.71 0.71*++++ 0.00 FAIL 0.00 ++++
TETRA 11264 0.12 0.03 3.86 0.82*++++ 0.00 FAIL 0.00 ++++
TETRA 11306 0.15 0.02 7.02 0.82*++++ 0.00 FAIL 0.00 ++++
1 MSC.NASTRAN JOB CREATED ON 02-MAY-07 AT 20:56:46 MAY 2, 2007 MSC.NASTRAN 9/23/04 PAGE 18
0
E L E M E N T G E O M E T R Y T E S T R E S U L T S S U M M A R Y
TOTAL NUMBER OF TIMES TOLERANCES WERE EXCEEDED
ASPECT/ MINIMUM MAXIMUM SURFACE/FACE EDGE POINT JACOBIAN
ELEMENT TYPE SKEW ANGLE TAPER RATIO INTER. ANGLE INTER. ANGLE WARP FACTOR OFFSET RATIO LENGTH RATIO DETERMINANT
TETRA N/A 9 N/A N/A N/A N/A 5247 1103
N/A IN THE ABOVE TABLE INDICATES TESTS THAT ARE NOT APPLICABLE TO THE ELEMENT TYPE AND WERE NOT PERFORMED.
FOR ALL ELEMENTS WHERE GEOMETRY TEST RESULTS HAVE EXCEEDED TOLERANCES,
TETRA ELEMENT ID 3569 PRODUCED LARGEST ASPECT RATIO OF 6149.15 (TOLERANCE = 100.00).
TETRA ELEMENT ID 6331 PRODUCED SMALLEST EDGE COS(ANGLE) OF 0.31 (TOLERANCE = 0.87).
TETRA ELEMENT ID 11306 PRODUCED SMALLEST DET(JACOBIAN) OF 0.00 (TOLERANCE = 0.00).
TETRA ELEMENT ID 8320 PRODUCED SMALLEST VERTEX DET(JAC) -UWM 6828- OF 0.00 (TOLERANCE = 0.00).
1 MSC.NASTRAN JOB CREATED ON 02-MAY-07 AT 20:56:46 MAY 2, 2007 MSC.NASTRAN 9/23/04 PAGE 19
0
*** USER FATAL MESSAGE 7555 (EMGPRO)
EMG MODULE TERMINATING DUE TO SEVERE FAILURE OF ELEMENT GEOMETRY CHECK TESTS. THE ELEMENT TYPES, ELEMENT IDS AND FAILING
TESTS ARE IDENTIFIED ON PREVIOUS PAGES WITH THE FLAG "FAIL" PLACED AFTER THE VALUE METRIC OF THE TEST THAT FAILED.
^^^ USER WARNING MESSAGE 9031 (ERRPH1)
^^^ NOGO ENCOUNTERED IN SUBDMAP SEMG
1 MSC.NASTRAN JOB CREATED ON 02-MAY-07 AT 20:56:46 MAY 2, 2007 MSC.NASTRAN 9/23/04 PAGE 20
0
* * * * D B D I C T P R I N T * * * * SUBDMAP = PRTSUM , DMAP STATEMENT NO. 30
第二个例子:
1 MSC.NASTRAN JOB CREATED ON 05-MAY-07 AT 16:21:54 MAY 5, 2007 MSC.NASTRAN 9/23/04 PAGE 10
(5)
meihuan0601
怎么看出来错误的具体位置
2008年5月28日
我是谁
把网格尺寸调小一点,再不行就用F2删除那些网格
2008年3月27日
chalon
是的,我也经常遇到不收敛的情况。你再修改一下你的网格和你的求解设置吧
2007年5月9日
zhang
你这个是用自动化分网格做的,而且用的是4面体网格,单元质量太差,导致程序不能进行。
你这个模型看起来比较复杂,但是我看了下,不一定需要用实体网格的。你把它拆开来,不同材料的,不同性质的归为一类,重新划分,对结构影响不大的地方省略掉最好。
另外,你先大概建一个相对简单的模型看看,只保留主要结构吧,因为看起来你还不怎么熟悉,你直接这样做我看比较悬,呵呵
2007年5月7日
mgh_nx
你这是一个装配体模型,问题比较复杂 ,关键是个零件之间的约束、自由度的协调问题。从信息看是以上问题都是因为你的网格划分质量太差,畸变严重,导致Jaccobi矩阵奇异,得不到收敛结果。
2007年5月6日
